Old Sun, Sep-25-2005, 11:44:03 PM   #1
mfree
mfree's Avatar
Reputation: 0 mfree is on a distinguished road
Default locked keys in car! HELP
I am going to borrow a slim jim to try to get into my car. Anything out of the ordinary I should know about?
Jump to top mfree is offline   Reply With Quote
Old Sun, Sep-25-2005, 11:51:51 PM   #2
Sirius
How many licks..
Sirius's Avatar
Good luck slim jiming a BMW, as they are very difficult to do. (Tried many times when I worked for BMW).
Also, if the car is double locked, you won't be able to slim jim the door as the door won't unlock.
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Mon, Sep-26-2005, 12:02:44 AM   #3
1997e36dinanm3
1997e36dinanm3's Avatar
Reputation: 0 1997e36dinanm3 has disabled reputation
Dont u have another pair of keys??
--Earl
2007 Audi S4 phantom black pearl/black ebony, fully loaded, except bose
97 estoril sold
mods: smoked lenses all around, 35% rear tint and 20% rear window tint, beltronics vector 995, shark injector, UUC RK6 adjustable shift knob
Jump to top 1997e36dinanm3 is offline   Reply With Quote
Old Mon, Sep-26-2005, 12:13:19 AM   #4
Sirius
How many licks..
Sirius's Avatar
I am also curious, but how exacty did you manage to lock the keys in your car?
When I worked for BMW I learned that the only real way to lock a key in a BMW is via the trunk. (This was for the more recent models E46+). As you have to lock the doors with the remote while the trunk is open, then put the keys in the trunk and close the trunk which then arms the alarm.
The E36 is a bit different however, as you either have to arm the alarm with the remote (if you have one), which requires the doors to be closed, ALL of them including the trunk. Or manually lock the car with the key (trunk can be open). I guess the only way I could see this happening is if you locked the car (via the door lock) and then were messing around in the trunk and droped the keys in there and closed it.
97' M3. '10 R6.
Old Mon, Sep-26-2005, 12:25:15 AM   #5
mfree
mfree's Avatar
I locked the car, then went out with some freinds and got drunk and lost the keys. (have not lost a set of keys in over 10 years) My spare set is IN the car( I am in the process of moving so the car is packed full)
If I can reach the lock button will the doors unlock?
If I can pull the lever will the door open?
Old Mon, Sep-26-2005, 12:59:04 AM   #6
Sirius
How many licks..
Sirius's Avatar
Ahhh. Makes sense.
If the car is double locked then you cannot open the locks or door with the button or lever.
(I am not sure if the car only double locks with the alarm system installed or if it always does that).
97' M3. '10 R6.
Old Mon, Sep-26-2005, 01:30:17 AM   #7
95blkbimm3r
95blkbimm3r's Avatar
Reputation: 0 95blkbimm3r is on a distinguished road
w/ my factory alarm, you had to arm the system twice, the first was regular locking, then the second button double locked it...
if you locked the car w/ the key: you will not be able to get in w/o the key
if you locked the car w/ remote: the door pull will still work same w/ lock pin
your best bet would be just go to the dealership and order a new key... they are like $35 and it only takes a day or two to get it...i recently ordered two keys because i lost mine at work. just remeber to bring proof of ownership (title)
-Shaun
Mods: AA DSB, Gen 3 Exh w/ Track Pipe, AA Radiator; HIOP V2 Header; V1, Kenwood KVT-911DVD, KNA-DV4100 Navigation, Depo Euro w/Xtec 6000k lows, X-brace, homemade Clutch Stop for $1.29... Tint 3M Color Guard 20% all around; MA Shaw Carbon Fiber Hood, Viper 791XV Remote Start,
~SIRIUS SUBSCRIBER FOR LIFE~ Up next: EvoIII SSK
My Videos/Homepage
Jump to top 95blkbimm3r is offline   Reply With Quote
Old Mon, Sep-26-2005, 05:52:01 AM   #8
CarQz17
In Debt And Lovin' It
CarQz17's Avatar
Reputation: 0 CarQz17 is on a distinguished road
I have always just manually pushed down the door lock pull as i stepped out of the car to lock it....anyone else do that?
FOR SALE
Jump to top CarQz17 is offline   Reply With Quote
Old Mon, Sep-26-2005, 06:28:32 AM   #9
nickanas
nickanas's Avatar
Reputation: 0 nickanas is on a distinguished road
Forget about slim-jimming your car, it 'll only do damage.
Do what car thieves do, its effective and simple. (Actually, I hope I do not get into trouble for writing this)
1. Get a blood pressure manometer with a hand pump (like the ones that wraps around your arm used by nurses for taking your blood pressure).
2. Insert the inflatable bag (bladder) under the upper corner of the window. Be careful not to use sharp tools as you can cut the door seal.
3. Inflate the bladder. This will pull the window away from the rubber seal. Inflate the bag just enough so that you don't damage the window and you make enough space for a coat hander to slide in.
4. Use a properly bent coat hanger, mentioned in 3., to "hook" the door handle. Once hooked pull to open.
Its easy and it shouldn't take more than 5 minutes.
98 M3 EVO S50B32 (321HP)
PSS9, X-Brace, flared fenders front and rear, 265/35R18 10.5" 30mm H&R spacers -rear, 225/35R18 8.5" 20mm momo spacers -front, ANTERAS TYPE-343
Jump to top nickanas is offline   Reply With Quote
Old Mon, Sep-26-2005, 11:16:28 AM   #10
95blkbimm3r
you cant do this, the lock physically wont let you do it if the door is open... not on the M3
-Shaun
My Videos/Homepage
HELP: Keys locked in boot phat///M3 E46 M3 (2001-2006) 32 Fri, Feb-15-2008 09:36:36 PM
Locked my keys in the trunk! (VERT) lorkar E46 M3 (2001-2006) 23 Wed, Oct-10-2007 06:59:24 AM
Damn, locked my keys in the trunk! HELP! Duck360198 E46 M3 (2001-2006) 57 Tue, Dec-06-2005 03:06:19 AM
Carlos Mencia Cartoon - I Locked My Keys In The Car Grimm333 Off Topic 10 Thu, Sep-15-2005 01:43:10 PM
locked my keys in the trunk! cjm82000 General BMW Discussion 15 Tue, Jun-29-2004 03:08:09 AM
Discussing locked keys in car! HELP in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
