![]() Location: Bay Area, CA, USA
Hi everyone,
So I decided to finally install my Hawker Lightweight battery and I ran into a little snag. All of the DIYs (such as this one: http://www.m3forum.net/m3forum/showt...hlight=battery) indicate that all that is needed is something to lift the battery up in order to get it high enough for the stock battery clamp to be used. The problem is, I don't seem to have the stock battery clamp The pics in the thread above show a brass-looking overhead clamp that comes down from above. I don't have that. Instead, I have a long metal screw with a clamp on the bottom end that clamps down onto a lip at the bottom of the battery. I have attached some photos to illustrate. The long screw can be seen on the right hand side of the battery and I also showed a close up of the clamp. Anyway, with this setup, it does not seem possible to install the Hawker battery. Has anyone else encountered this? Am I the only one with this type of bettery clamp? Is there a way I can get the other (top clamping type)? Any other advice for how I might do this install? Any and all advice would be much appreciated. Thanks! |
![]() Location: SoCal
Can you could get your hands on a later model year battery tray by ordering one from a dealer, I bet its a simple one for one swap.
2005 AW 6MT Blk_leather Xenon nothing else SOLD
![]() Location: Cape Cod
I have no idea how you could secure it with that screw.
My only recommendation would be to go to the dealer and buy the clamp. It looks like it should fit. Another tip, use a hockey puck in between the battery and the clamp to bridge the gap. |
#4 | |
Is there a readily available battery box that will work in our cars and will fit the Hawker? If not, I guess I'll need to look into a custom box. Thanks. |
#5 |
bimmerhaus carries a holder for the battery
#6 | |
#7 | |
I have done this mod so I am 100% positive that the tray will have the clamp assembly integrated with it. If you compare your pic with the pics from Red's DIY, you will see what I mean about the 2 holes on the trunk metal work.
#8 | |
Thanks Battle!
I'll call the dealer today and see if I can get that part. Quote:
#9 | |
http://www.m3forum.net/m3forum/showthread.php?t=78986
| Battery is deaded 4 times now, what and where to buy Hawker? | RhaceM3 | E46 M3 (2001-2006) | 0 | Sun, May-06-2007 11:56:46 PM |
| LTW Battery | whatcop? | E46 M3 (2001-2006) | 13 | Sun, Apr-29-2007 03:41:04 PM |
| Hawker LTW Battery Install Tips | BattleWagon | Faults, Fixes and DIY | 1 | Tue, Aug-09-2005 01:02:11 PM |
| Hawker LTW Battery Install Help | BattleWagon | Faults, Fixes and DIY | 5 | Mon, Jan-31-2005 03:45:03 PM |
| Evosport Battery Box for Hawker arrived | Nixlimited | Member Photos and Videos | 16 | Sun, Dec-12-2004 01:55:47 AM |
