Old Mon, Jul-25-2005, 11:19:15 PM   #1
rcurley55
Reputation: 0 rcurley55 has disabled reputation
Default What should I do - (yes, another tire thread)
Here's the situation - I have Michelin Pilot Sport all around on my 19" BBS LM's. The road home from work - all 2 miles of it is all right handers - and they are taken hard - my front left tire as a result is damn near gone, with the front pass. not that far behind. The rears were replaced fairly recently and as a result have plenty of tread.
So here's the dilemma - I can't find the Pilot Sports ANYWHERE in a 245/35/19 - so I can either replace JUST the fronts and go mixed matched, or bite the bullet, buy the Toyo T1-R's and try to sell the Michelins.
What would you do?
Life's too short not to be M-Powered!!!
Jump to top rcurley55 is offline   Reply With Quote
Old Mon, Jul-25-2005, 11:22:12 PM   #2
Kevin034
Kevin034's Avatar
Reputation: 0 Kevin034 has disabled reputation
drive backwards.
Jump to top Kevin034 is offline   Reply With Quote
Old Mon, Jul-25-2005, 11:29:12 PM   #3
kt22cliffjumper
kt22cliffjumper's Avatar
Reputation: 0 kt22cliffjumper has disabled reputation
Default something doesn't add up
If it's all right handers, wouldn't it be all left handers coming back home???
What would you do?
Jump to top kt22cliffjumper is offline   Reply With Quote
Old Mon, Jul-25-2005, 11:29:16 PM   #4
E46M3Rod
E46M3Rod's Avatar
Reputation: 0 E46M3Rod has disabled reputation
What would you do?
Seems to me the first thing you should do is adjust your alignment in the front. Sounds like the outsides of your tires are wearing. Probably need more camber if you continue to drive the way you do. / \
I'd say buy the Toyo T1-R's entire set and see how you like them and keep the Michelin's for the rear. But alot depends on how many miles you drive and how long you plan on keep your car.
19x8.5F 19x10R Work Wheels RezaxII Toyo T1-R
Jump to top E46M3Rod is offline   Reply With Quote
Old Mon, Jul-25-2005, 11:31:55 PM   #5
rcurley55
totally different roads on the way home then on the way there - it's a loop - I have a stop light out of the office, takes me to a straight away where I hit about 60, then dive into a right hander to enter the freeway - then another straight all the way to a hairpin - u-turn - then more straight, a sweeping right, then one quarter of a "clover leaf" then it's a straight drive home - it's a great drive!
Old Mon, Jul-25-2005, 11:34:44 PM   #6
rcurley55
The car tracks fine, it's really the outside of the driver's side that's taking most of the beating - the shoulder is scrubbed pretty good, but the tire is wearing evenly across the rest of the surface. Tire pressure seems good too.
Maybe I can take some photos...
I only drive about 150 miles a week - so not that far...I'll be keeping the car for a while.
At first I was going to go to PS2's all around, but for the price, I really can't find a reason not to go with the Toyo's
I would prefer not to run mix-matched rubber.
Old Tue, Jul-26-2005, 02:45:22 AM   #7
stealthauto
Reputation: 11 stealthauto is on a distinguished road
I wouldn't run mixed max rubber. Just bite the bullet.
Just my $.02
M3 & just another slow, blacked-out, full bolt-on Cobra
Jump to top stealthauto is offline   Reply With Quote
Old Tue, Jul-26-2005, 12:32:53 PM   #8
Chris S
This is how I roll...
Chris S's Avatar
Reputation: 0 Chris S is on a distinguished road
agreed. Do not run mixed-matched rubber. Not a good idea at all with high perf. tires. If the rear have plenty of tread, remove them and sell them. Someone else will be in a similar situation as you (but need rears) and will snatch them up. Pilot sports are becoming harder and harder to find in any size. Get the toyos!
2008 Alpine/Black e92 M3, 6MT, loaded...
SOLD!!!!!: 2003 Alpine/Imola M3, 2002 996TT White/Natural
Jump to top Chris S is offline   Reply With Quote
Read every tire thread and still. . . Rule12b Parts for Sale/Wanted 15 Wed, Dec-17-2008 04:10:31 AM
Another Tire Thread 1320ms E46 M3 (2001-2006) 4 Wed, Feb-07-2007 07:21:35 PM
Another tire thread 285/35?/19 Rated///M E46 M3 (2001-2006) 11 Sat, Aug-12-2006 03:48:03 AM
Oh boy, another tire thread please read Neel E36 M3 (1992-1999) 22 Fri, Jun-10-2005 07:42:18 PM
The Last Tire Thread T2 E36 M3 (1992-1999) 15 Fri, Jun-03-2005 11:29:09 PM
Discussing What should I do - (yes, another tire thread) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
