Old Thu, Mar-29-2012, 02:21:23 PM   #91
meccanoble
///M3CCANOBLE
Reputation: 0 meccanoble is on a distinguished road
Default Re: Is 32 psi the correct tire pressure for 19"?
245/35/19 and 285/30/19. Running about 35 all around with no issues. I was tempted to go higher when I read beginning of this thread but after hearing about uneven wear, etc, I will stay the way I am. No issues, no uneven wear, just a wish for better gas mileage but my foot may have more control over that than an extra PSI or 5.
///M3CCANOBLE
SOLD 03 Steel Grey 6MT
Eisenmann Race 83mm + section II| RE Rasp Pipe| D/A Street Software| Vogtland Springs| KONI Yellow Adjustables| Kenwood KDC X994| smoked LED tails & corners| 330 SSK/knob/boot| Dynaudio 362 Comps (custom kicks) & 2X 10" Alpine type r subs| Alpine PDX 4.150 & 1.1000| Matte gille/grille| Clifford 50.7x pager alarm| Clutchstop (1 1/4")| CDV Delete| Stoptech SS lines/Powerslot Slotted Rotors/OEM pads| Poly RTABS| Armrest Delete| Umnitza V4 Opaque AE|
R.I.P.
04 Mystic Blue w/ Cinnamon SMG (STOCK)
Jump to top meccanoble is offline   Reply With Quote
Old Thu, Mar-29-2012, 03:34:58 PM   #92
kevblah
kevblah's Avatar
Reputation: 0 kevblah is on a distinguished road
I saw this thread last night and almost **** my pants, I've been running 41/48 for a little over 3 weeks now. I knew that those numbers seemed high, but I figured why would they put anything other than the recommended pressures in the door jam.
I will be dropping my pressures down to 33/35. I hope my tread isn't FUBAR'ed.
Jump to top kevblah is offline   Reply With Quote
Old Thu, Mar-29-2012, 04:22:56 PM   #93
bmwm3smg2
forever stock...
bmwm3smg2's Avatar
Reputation: 0 bmwm3smg2 is on a distinguished road
You should be fine. 3 weeks won't do much damage unless you were doing donuts. I'm still around 35 psi on my second set of tires and it's wearing down evenly.
Erwin
Jump to top bmwm3smg2 is offline   Reply With Quote
Old Thu, Mar-29-2012, 06:35:25 PM   #94
Silvertail
Reputation: 0 Silvertail is on a distinguished road
33/35 or 35 all around. From my experience with my last set of tires which was running 38 all around was having wear result from over-inflation. Now I'm just running 33/35 and so far wear on tire has been even. I never have more than 4 people in my car so there is never a need for higher psi pressure.
Jump to top Silvertail is offline   Reply With Quote
Old Mon, Apr-23-2012, 06:08:06 AM   #95
uscbeemerM3
uscbeemerM3's Avatar
Reputation: 0 uscbeemerM3 has disabled reputation
I do 36 all around. Too bad there is no right answer to this question, it would make things easier. If you think about it, the tire pressure you inflate it too only stays the same for a week or so, over time you lose cold tire pressure. So just a thought, I fill my tires with air when it gets down to 32psi, about a month or 2, so technically I've run anywhere from 32-36 psi due to normal tire pressure loss. Just a thought.
Current Car; 2008 S63 AMG. Still active on m3f, benz forums are empty.
Sold to my cousin; 2005 SMG II. Imola Red Inside
Koni Yellow struts/shocks with stock springs. M Track Mode (with M Track Mode light in the cluster),
CSL factory software via autologic (launch control is at 4800rpm), genuine CSL sway bars; front (30.8mm/hollow/8lb) and rear (22.5mm/solid/8lb), brake light mod all LEDs enabled when braking.
Jump to top uscbeemerM3 is offline   Reply With Quote
Old Thu, May-26-2016, 03:56:37 PM   #96
TAckhouse1
Reputation: 0 TAckhouse1 is on a distinguished road
Sorry to dig up an old thread, I recently upgraded to 19" Apex Racing PS-7's, 245/35F and 275/30R (Michelin Pilot Super Sport tires).
My manual lists 33/35 f/r for normal pressure. I'm wondering since my tires are wider than stock, if that would change the pressure requirement?
Thanks in advance!
Jump to top TAckhouse1 is offline   Reply With Quote
Old Thu, May-26-2016, 04:09:43 PM   #97
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
Thanks in advance!
No they shouldn't. But I would increase the pressure to the 39/46 which I iirc is the pressure max ocupants.
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Thu, May-26-2016, 04:18:42 PM   #98
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
You know what though, experiment a little, just don't surpass the max/min numbers. High pressures will increase response, decrease smoothness and lower pressures will do the opposite. I would not exceed the max rated tire pressure molded on the tire, nor ride around at that pressure.
Last edited by sergbaja5t; Fri, May-27-2016 at 02:46:53 PM. Reason: auto-correct sucks
Old Thu, May-26-2016, 04:45:34 PM   #99
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
Lower pressure increases grip, until the tire starts to cup or roll over. On the street I run 36psi all the way around. Tire wear has been pretty good. I got 25k miles out of my last set of RE11 on my setup where I can't rotate...mostly street miles and few track days mixed in.
255/275 on a 19" wheel.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Thu, May-26-2016, 05:12:47 PM   #100
KubinB
BMMMR
KubinB's Avatar
Reputation: 0 KubinB is on a distinguished road
Thanks in advance!
im running the same size tires and the same pressure (33/35), im doing good id say youre fine. you dont want to go too hard imo
///M3 2002 TiAg / Imola 6MT
The Transformation
Jump to top KubinB is online now   Reply With Quote
Tire Pressure...40 PSI Front and 50 PSI Rear? dafunguy E46 M3 (2001-2006) 28 Sat, Oct-07-2006 07:07:43 AM
correct tire pressure for 19" Kai Haase E46 M3 (2001-2006) 1 Sat, Sep-06-2003 01:43:38 PM
Correct tire pressure? cohibadad E46 M3 (2001-2006) 5 Mon, Jun-16-2003 05:08:58 AM
Correct Tire Pressure for stock 18" wheels ziggy723 E46 M3 (2001-2006) 1 Sat, Aug-10-2002 01:34:21 PM
Rear tire pressure 46 psi?!? MattsMthree E46 M3 (2001-2006) 4 Sat, Apr-13-2002 08:34:00 PM
Discussing Is 32 psi the correct tire pressure for 19"? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
