Old Thu, May-26-2005, 04:32:03 PM   #1
e36_m3_Turbo
e36_m3_Turbo
e36_m3_Turbo's Avatar
Reputation: 0 e36_m3_Turbo has disabled reputation
Default High Compression Pistons?
Are they worth it. 13:1 ratio. Would there be any performance gains.
Side Note: Im ording some AA headers this Friday.
Jump to top e36_m3_Turbo is offline   Reply With Quote
Old Thu, May-26-2005, 04:57:36 PM   #2
Sirius
How many licks..
Sirius's Avatar
I would imagine that for the cost of labor to install them, you may be better off getting cams.
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Thu, May-26-2005, 04:58:12 PM   #3
95RogueM3
^Needs More Garage Space..
Reputation: 0 95RogueM3 has disabled reputation
13:1 is WAY WAY too high. Stock is 10.5...most high compression motors dont go above 12:1
'98 M3 Sedan - Built 2JZ Swap - 915whp, 791wtq
'95 M3 - 37k Miles
Jump to top 95RogueM3 is offline   Reply With Quote
Old Thu, May-26-2005, 05:11:44 PM   #4
e36_m3_Turbo
e36_m3_Turbo
Then why the hell are there 13:1 then? Lol. Makes no sense. Ok what would performance gains be on the 12:1? And Siruis, cam kit is in the near future also. I was thinking maybe it would be an add on of the cam kit.
Old Thu, May-26-2005, 05:12:51 PM   #5
e36_m3_Turbo
e36_m3_Turbo
Wait wait wait, if I also added a head gasket to lower the compression, then I would be fine, no?
Old Thu, May-26-2005, 05:15:43 PM   #6
Sirius
How many licks..
Sirius's Avatar
I don't know much about engine internals, but I do know that using a headgasket to lower compression is a half-assed way to do it.
97' M3. '10 R6.
Old Thu, May-26-2005, 05:19:57 PM   #7
badgtho
Team Nexen Racing
badgtho's Avatar
Reputation: 0 badgtho is just really nice
jesus! 13.5:1 never never never on pump gas! your cats will not function, and i have a feeling that your knock sensor will not know what hit it. not to mentio your head, headgasket, rods and crank are not designed for that much compression. the 10.5 that the M has to start is very high.. in fact i dont know of any production vehicles that are significantly higher.
Current - '99 estoril/mulberry coupe || Past - '97 alpine/anthrazit coupe || 10,000+ post club || OG club
Badgtho can be rude but he certainly knows more than you.
A Moment of Zen, brought to you by BadGTho:
Originally Posted by salty View Post
At any rate, our MDX is running 5w20 and it can tow 3500 pounds.
Jump to top badgtho is offline   Reply With Quote
Old Thu, May-26-2005, 05:21:17 PM   #8
e36_m3_Turbo
e36_m3_Turbo
Ok. Did you see my side note? I was thinking it would give me some extra N/A power with the cam kit.
Old Thu, May-26-2005, 05:21:43 PM   #9
badgtho
Team Nexen Racing
badgtho's Avatar
so wait.. now you want to raise the compression with pistons, then lower it with a gasket.. that will blow every 30 seconds unless you o ring it. i wouldn;t even do that on a dirt bike. one can raise compression slightly by decking the head. going to a higher compression or dome top piston will raise it siginificantly, more so than your engine is designed for.
Old Thu, May-26-2005, 05:23:22 PM   #10
badgtho
Team Nexen Racing
badgtho's Avatar
some extra power!!! a jump of 3:1! you would have a monster if it held together// and you would need like 105 octane! open a book on the internal combustion engine, read it, then rethink.
at 13.5 why not make it a diesel?
Thinking of rebuilding engine with high comp pistons mugm3 E36 M3 (1992-1999) 21 Wed, May-07-2008 12:45:05 AM
High compression & Mid Boost Pressure TWINTURBOM3 Forced Induction (F/I) 38 Sun, Jul-22-2007 07:40:18 AM
13:1 Compression Pistons allmotorM3 General BMW Discussion 2 Mon, Apr-17-2006 06:05:00 AM
New high-compression N/A kit from BHS Divexxtreme E46 M3 (2001-2006) 161 Fri, Oct-14-2005 03:41:11 PM
Drove my BHS High-Compression Animal... panas001 E46 M3 (2001-2006) 58 Sun, May-01-2005 04:13:04 PM
Discussing High Compression Pistons? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
