Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Thu, Mar-21-2019, 11:14:37 PM   #1
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Talking FEELER: Cat-Cams' Camshaft Group-Buy Thread
Please submit payments ASAP before this opportunity closes for good! =)
This Group-Buy is for Cat-Cam's 280/272 camshafts and 288/280 camshafts with the option to add followers.
280/272 -- Cat-Cams Sport Camshaft Details
288/280 -- Cat Cams Race Camshaft Details:
*If interest in other durations exist, I can add these to the Group-Buy as well, however the above 2 options are the most popular and most documented.
(Optional) Follower options:
It is recommended to replace the followers when installing cams. Both the camshaft and followers wear together and by not swapping followers, you do risk the possibility of accelerated wear on the new camshafts. That being said, followers are an "optional" inclusion to this Group-Buy. There are plenty of forum members that have chosen to reuse their stock followers when installing 280/272 cams and have had no negative consequences. If you decide to reuse the stock followers, you do so at your own risk. If there is visible wear on the stock followers/stock cams or high-mileage on the motor, it is advised to replace them with new followers.
Cat-Cam's DLC Coated cam followers with oil feed from the rocker arm to the cam lobe. "This kit includes an "oil bridge" to bring oil from the exhaust to the intake rocker arm shaft (which has no oil pressure), from where it is fed to the rocker arms. The rocker arm shafts need to be drilled, which can either be organized by the customer, or we [Cat-Cams] can supply new modified rocker arm shafts (sourced from BMW). The oil bridge can be moved left/right in order to torque the head studs and set the valve clearance just by removing the rocker arm brackets."
Pricing For Cams (with 21+ participants):
-Cat-Cams (280/272 or 288/280): $850 + shipping from SC to your doorsteps.
*Usual retail is around $1,145.95 + shipping. Saving you $295.95 (26% off).
Pricing for optional Cat-Cam Followers (with 11+ participants):
-Cat Cam's x24 Coated Cam Followers + oil bridge (NO ROCKER ARM SHAFT): $1,350 + shipping.
*Usual Retail $1600 + shipping. Saving you $250 (16% off) -- Approx. $56.25 per rocker arm + includes Cat-Cam's oil bridge.
BMW Rocker Arm Shaft Pre-Drilled by Cat to accept Oil-Bridge (no minimum order participation):
If you need new BMW modified rocker arm shafts, Cat can supply these for (pre-drilled for the Cat-Cam Oil-Bridge) for $400
NOTE: When installing these cams, you will need to transfer the pressure regulating valve over from your stock cams to the new Cat-Cams.
If you are serious and interested in participating, please include the following in a ordered list comment down below:
1. forum name, cam duration you are interested in, as well as if you want followers or not or any other options available, and a zip-code for shipping
Cat-Cams is unable to drop-ship these individually to participants. Instead, a bulk package of all the Cat-Cam camshafts will be sent to me directly and I will need to resend these packages out to each of you individually. I will need your zip-code in order to get an accurate individual shipping quote for each person participating and you will be responsible for this cost as per the Group-Buy. If you live local to me (SC/NC/Ga area) you can also avoid the reshipping cost by local pickup once the package arrives. If you would like to get a shipping estimate on your own, my sending zipcode is 29205 and the box details are: "730x210x110mm - 8.5kg for 1 box containing 1 camshaft set." As per Cat-Cams "They are shipped inside another box for extra protection."
Lead Times (from Cat-Cams):
"Lead times depend strongly on availability of semi finished camshafts, but when these are available it will be close to 3 weeks."
For this Group-Buy to move forward, at a minimum I'd like to hit 21+ participants for cams (this can be in any combination of 280/272 or 288/280 cams) and 11+ for Followers.
*Once I have your Zip-code, I will begin to get domestic shipping quotes. Last I checked from, SC to Cali (likely the furthest transit) was around $48-50 bucks.
*Payment instructions will be sent out if we can hit the Group-Buy goal.
Additionally, I'd like to also offer the OE CSL Camshafts for those that want to keep things factory BMW and for cool factor, as well as OE CSL Exhaust Valves, and OE BMW (Non-Coated) Followers. For those with CSL airboxes, the CSL Cams should keep things simpler as you could run the base CSL tune file without worrying about adjusting for cam values. Please note that these cams do not count toward the 21+ orders needed for the Cat-Cams Group-Buy. There is no minimum order for these OE BMW CSL parts.
OE BMW CSL Camshafts (268/264): Pricing to come shortly
*for reference, the stock M3 camshafts are 260/260. source
OE BMW Cam Followers (non-coated x24): Pricing to come shortly
OE BMW CSL Exhaust Valves (x12): Pricing to come shortly
("geometry of the valve has been improved in order to reduce the work needed to expel the burned fuel from the combustion chamber.")
Direct shipping on these OE BMW CSL Parts:
-Shipping for OE CSL Cams + OE Followers + OE CSL Exhaust Valves: £128.58
-Shipping for just the two OE CSL cams: £124.33
-Shipping for just the OE CSL cams and OE CSL rocker arms: £126.71
-Shipping for just the OE CSL exhaust valves: £88.47
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2, HTE Tuning Group-Buy OE CSL Wheel
Jump to top Dr M3an M3 is offline
Rate Seller View Rating
Old Thu, Mar-21-2019, 11:19:44 PM   #2
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
Default FEELER: Cat-Cams' Camshaft Group-Buy Thread
Been waiting for this so long to come around sign me up for:
Cat-cams 280/272
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced Vince bar & plates, 996 Brembo brakes PFC 08 pads, CDV delete, F10 M5 shift knob, CSL diffuser, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, 350F/750R Flat ride Ohlins Custom GC Weight Jacks, GC Street Camber Plates, Hotchkiss sway NO rear bar, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2082 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is offline   Reply With Quote
Old Thu, Mar-21-2019, 11:24:30 PM   #3
Good
@GOOD_M3
Good's Avatar
Default Re: FEELER: Cat-Cams' Camshaft Group-Buy Thread
I'm in 280/272
EXTERIORVÖRSTEINER CSL BUMPER | MILE END CSL 1X1 DIFFUSER & FLIPPERS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OE SNORKEL + CSL DUCTING | VANOS BEISAN LOCKDOWN
TRANSMISSION ▌SMG HCU RELOCATED & REBUILT W/ NEW SEALS, ACCUMULATOR & BURKHART KIT
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V3 COILOVERS | ROGUE RSM | GROUNDCONTROL STREET CAMBER PLATES | SDW RTABS
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | STOCK2 | SPORT (GEN 2) SEC 3
BRAKES ▌CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌OEM CSL BBS 19" | 75MM ECS/TMS WHEEL STUDS
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Thu, Mar-21-2019, 11:27:39 PM   #4
Dr M3an M3
Dr M3an M3's Avatar
Awesome guys! Let's get a list going! Please include the following:
I particularly need zip-codes to get individual shipping quotes for once these bulk land in the USA. If you are close and willing to drive to SC, local pick up is fine too.
IG: DrM3anM3
Old Thu, Mar-21-2019, 11:30:05 PM   #5
Radekxpl
Radekxpl's Avatar
Poland
1. Radekxpl Cat-Cams 280/272 only, zip 06418
2006 M3 Silver Grey
Old Thu, Mar-21-2019, 11:53:18 PM   #6
chsbmw
Reputation: 0 chsbmw is on a distinguished road
How are these vs Schrick?
Jump to top chsbmw is online now   Reply With Quote
Old Fri, Mar-22-2019, 12:07:33 AM   #7
Dr M3an M3
Dr M3an M3's Avatar
Great. Plenty of guys are running Cat Cams on here with zero issues. Schrick are great too, but over twice the cost. I looked at offering Schricks but the pricing just couldn't be justified...and they are planned to go up in pricing too from what I was told.
IG: DrM3anM3
Old Fri, Mar-22-2019, 12:07:56 AM   #8
whips333
whips333's Avatar
1. Radekxpl 272/280 zip 06418
2. Whips333 280/272 + followers for now zip 06053
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old Fri, Mar-22-2019, 12:32:54 AM   #9
95bullet
95bullet's Avatar
Reputation: 0 95bullet is on a distinguished road
Interested. Do you have more info on the process to drill the rocker arm shafts? Are any special tools or jigs required?
Jump to top 95bullet is offline   Reply With Quote
Old Fri, Mar-22-2019, 12:41:20 AM   #10
Dr M3an M3
Dr M3an M3's Avatar
I will have to ask them more about this and what all is involved. Perhaps they can include instructions if they don't already. Will report back.
IG: DrM3anM3
Discussing FEELER: Cat-Cams' Camshaft Group-Buy Thread in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
