Old Fri, May-18-2018, 11:08:52 PM   #1
kokgo20
kokgo20's Avatar
Default Rotrex C38-92 disassembly and possible repairs
After 35K miles on the blower it decided to seize up on me. After that i found out that that Rotrex aren't rebuildable.
I Found this company here that rebuilds them, but was't too comfortable in sending it in for inspection without me knowing what caused it or taking a look inside, nor i was comparable enough to the guy who is rebuilding them.
I Found this gentleman's pictures on flicker who was kind enough to walk me thought how to open the blower. He is far more experienced than the gentleman at the company above.
Now let the fun begin.
Fist i had to build a tool that i can use to torque the pulley bolt very well in order for me to use that bolt to unscrew the internal plate from the annulus. Hint why Rotrex says don't rotate the pulley counter clock wise? as it will damage the blower! it doesn't damage the blower but it will unscrew the plate internally but simply once you rotate it correctly it will screw it self back on.
Once i was able to open the blower and everything is exposed, i can see how it's built and function.
Noticed a wear on the rollers housing and the drive plate. I attempted to unscrew the 3 bolts holding the rollers housing and noticed that they were loose / maybe finger tight. Hmmmm that's the reason that caused the housing to get in touch with the plate creating metal shavings that caused the blower to seize.
Now i couldn't find a small enough 2 jaw puller to fit between the annulus and the casing, so i ground the sides of the 2 jaws to fit in and pull the annulus out just enough to be able to slide the plate to one side and get it out.
I forgot to take a pic of this process but you can see the ground part of the puller on this pic
Now finished pulling the annulus & pulled the rollers housing
I had to press the shaft out from the impeller to separate both apart.
Now some pictures of the pitting on the shaft and the rollers
Are these pitting on the rollers very critical? since they are dipped inside without adding any extra thickness to the roller? is it reusable?
The pitting one the sun shaft can be milled also. would that be an option to reuse after milling just the pitting?
Any recommendations on bearings replacement?
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Fri, May-18-2018, 11:24:17 PM   #2
kokgo20
kokgo20's Avatar
A possible seized bearing also that shows the shiny part inside the rollers holder / cup
Old Fri, May-25-2018, 04:52:33 AM   #3
kokgo20
kokgo20's Avatar
Default Re: Rotrex C38-92 disassembly and possible repairs
Oil pump
Found some metal shavings inside the pump also after removing the short shaft.
Old Wed, Jun-06-2018, 05:56:57 PM   #4
05M3power
Reputation: 0 05M3power is on a distinguished road
Any update on this? how did it act when it seized on you? could you tell beforehand?
Jump to top 05M3power is offline   Reply With Quote
Old Fri, Jul-27-2018, 03:14:46 PM   #5
kokgo20
kokgo20's Avatar
It took a while for me to get it back working due to work and other things
But she just came back alive last night.
Loud grinding noise, turned that car off then back on and the belt started to slip while the pulley is seized.
Nothing that had alarmed me or anything.
Old Wed, Aug-01-2018, 04:58:36 PM   #6
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
I wish I knew what a Rotrex was supposed to sound like, I'm used to the Vortech marbles
Topo Chico
Old Thu, Aug-02-2018, 12:51:17 AM   #7
kokgo20
kokgo20's Avatar
Rotrex has a whistle to it
Old Tue, Sep-04-2018, 01:00:03 AM   #8
kokgo20
kokgo20's Avatar
Happy to report today the blower has 1000 miles on it after the repair with lots of redlining. Still holding strong and full boost
Old Tue, Sep-04-2018, 01:09:36 AM   #9
nuc1
Meh
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
Originally Posted by kokgo20 View Post
Happy to report today the blower has 1000K miles on it after the repair with lots of redlining. Still holding strong and full boost
World record.
Mike
02 TiAg/Black 6MT
16 X5 Xdrive35i Imperial Blue/Terra/ Family Truckster
11 Tundra Super White/Black Actual Truckster
Jump to top nuc1 is offline   Reply With Quote
Old Tue, Sep-04-2018, 06:05:27 AM   #10
kokgo20
kokgo20's Avatar
Originally Posted by nuc1 View Post
World record.
Mike
Lol isnít that something!
Discussing Rotrex C38-92 disassembly and possible repairs in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
