Old Sat, Mar-05-2005, 07:04:38 PM   #1
sameguy
sameguy's Avatar
Reputation: 0 sameguy is on a distinguished road
Default Rear Jacking Point
I'm about to do my RSM's' and I was wondering where is a safe place to jack the rear of the car with a floor jack? Can I even get it high enough w/ a floor jack to get jack stands under there, or should I just use the handy BMW jack?
Jump to top sameguy is offline   Reply With Quote
Old Sat, Mar-05-2005, 07:48:26 PM   #2
Eric1855
#55 Street Modified KYR SCCA
Eric1855's Avatar
Reputation: 0 Eric1855 is on a distinguished road
You can either use a floor jack on the factory jack points, or use a floor jack from behind and jack up the entire car. Just put it on a crossmember in the rear, or use a piece of wood and put it on the differential.
Remember, though, make sure you chock the front wheels if you are going to put both rears in the air.
1997 BMW M3
#55 Street Modified
Jump to top Eric1855 is offline   Reply With Quote
Old Sat, Mar-05-2005, 08:28:26 PM   #3
sameguy
sameguy's Avatar
thank you very much. Just tore out the trunk, time to jack.
Old Sat, Mar-05-2005, 09:58:36 PM   #4
Stinky
Reputation: 0 Stinky is on a distinguished road
People advise against jacking on the differential due to adding stress on the diff bolts.
Jump to top Stinky is offline   Reply With Quote
Old Sun, Mar-06-2005, 12:10:34 AM   #5
Eric1855
Eric1855's Avatar
I wouldn't put the jack directly on there, but if you put a block of wood and only jack long enough to get jackstands under the factory jack points it wont put any undue strain on the diff.
Just dont let it set for extended amounts of time on the jack, get it to jackstands ASAP.
1997 BMW M3
#55 Street Modified
Old Sun, Mar-06-2005, 05:53:19 AM   #6
shim
Volkswagen Factory Driver
shim's Avatar
Reputation: 0 shim has disabled reputation
South Korea
as mentioned, just jack it up under the rear x-member, but chock first
VW Jetta TDI Cup #29
Induktion Motorsports Soldier Design Allsports GP
Jump to top shim is offline   Reply With Quote
Old Sun, Mar-06-2005, 10:54:10 AM   #7
Stinky
My jack has a rubber pad and it's wide so a block of wood wouldn't make a difference, but I know what you mean. That's true about letting it sit there for extended amounts of time, but I'd rather use the crossmember. Especially since I jack my car up pretty often.
Old Mon, Mar-07-2005, 03:48:15 PM   #8
sameguy
sameguy's Avatar
well, I started attempting to jack my rear with a big wood block on top of my shiny new floor jack under the rear dif, but I had to be on my belly, almost under the car to reach the jack, and I couldn't get much leverage on the jack, also had trouble as the car is so low, I couldn't get much action out of the jack handle. I figured after about 5 minutes, and the tires still on the ground, that I'd just use the handy jack that came w/ the car. That little sucker is the best free jack I've ever used, beats the hell out of the scissor hack that came w/ my GSX.
Old Mon, Mar-07-2005, 03:55:20 PM   #9
DTampa
Reputation: 0 DTampa is on a distinguished road
Sameguy, you must have ESP. I was unsuccessful in located a secondary rear jacking point this weekend and was going to ask. My car is so low b/c of the GC coilovers that I cannot reach the differential with a jack. With apologies for the ignorant, noobie question, where is the crossmember and what does it look like? I spent a lot of time looking and found a couple of spots where I can safely say do not jack ever, but could not find any likely candidates for the secondary point.
Jump to top DTampa is offline   Reply With Quote
Old Mon, Mar-07-2005, 04:59:15 PM   #10
Stinky
http://www.unofficialbmw.com/all/too..._your_car.html
If you plan on doing work on your car frequently I suggest buying a good jack. No problem jacking the rear of the car with my jack. Long handle and jacks with very little movement.
Help - rear end is sagging to the point of tires rubbing the wheel well on turns/dips Wicked_M3 E36 M3 (1992-1999) 9 Tue, Mar-06-2007 03:49:10 PM
$46 M3 Rear jack point broken/collapsed ? pbilling Faults, Fixes and DIY 4 Thu, Apr-13-2006 07:29:41 PM
Rear Jack Point Failure Prima E36 General BMW Discussion 11 Sun, Aug-14-2005 12:22:53 AM
Jacking up the M????? DarkVader E46 M3 (2001-2006) 2 Mon, Apr-18-2005 02:26:49 PM
What's the point of a rear diffuser? M3zie E46 M3 (2001-2006) 5 Thu, Jun-26-2003 09:54:20 PM
Discussing Rear Jacking Point in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
