Old Sat, Aug-12-2017, 09:38:43 PM   #1
Dave B
M3 collector
Dave B's Avatar
Italy
Default 17" Apex BBK clearance
Sorry, this wasn't all that easy a search term to come up with.
What brake kits do the 17" ARC-8s clear and not clear?
I assume they can clear some good ones, since they're a popular track wheel. And I know I've shoved an 18x9.5et22 over a 380mm Brembo (4 piston) kit. But I'm curious about which popular kits out there don't fit under a 17" ARC-8.
I'm not totally opposed to just being limited to 18s, but I guess it'd be nice to have a 17" option as well.
Old Sat, Aug-12-2017, 10:36:55 PM   #2
bigjae1976
Default Re: 17" Apex BBK clearance
I know 17" ARC8s clear Stoptech ST40/355mm kits. I think it will clear brembos. You'll need a spacer unless you're running 17x10s. Typically a 3-5mm spacer is all you need for the more aggressive offsets.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Discussing 17" Apex BBK clearance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
