Old Thu, Jun-08-2017, 05:57:38 AM   #1
Oogie_M
o_O
Oogie_M's Avatar
Reputation: 0 Oogie_M is on a distinguished road
Taiwan
Default Oogie's 97 M3 Journal
Iíve been documenting a build for the last couple of years and figured it would be a good time to share with the community (especially since a lot of fixes and how-tos were learned from this forum). A lot of aspiration was gleaned from other great journals in this section.
This is a work in progress with no end date in mind. Main goal is to completely restore the vehicle, with some aspirations for ďOEM plusĒ and tasteful modifications along the way. Itís surprisingly how fun the car is on weekends just in stock form with a fresh suspension. Iím not trying to build a show car or high horsepower monster. I just prefer to take my time, do it right (or not at all), and try my best to be meticulous.
Iíll start with the project acquisition ĖJuly 2015.
-Alpine white, 1 owner, Texas car
-78K miles, all paperwork (minus window sticker)
-Style24 wheels all around + spare
The price was so low that I had to jump on it (after a 3rd party inspection), bought it the first day it went on market.
Arriving home in CA
Ready to start this project!
Filed everything away
Jump to top Oogie_M is offline   Reply With Quote
Old Thu, Jun-08-2017, 06:03:10 AM   #2
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Default Re: Oogie's 97 M3 Journal
The car looked decent in photos, but in-person inspection meant a lot of work was ahead.
Door Card Condition
Got my mobile leather guy to repair and took off the door cards to re-glue everything
Glovebox De-laminated, had to get creative
Rest of the interior is in good shape
New Boot and E-brake leather added on
All completed
Old Thu, Jun-08-2017, 06:25:01 AM   #3
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Exterior Problem Areas
Stripped
New seals, cowl, gaskets, trim, corner lights, etc
Mobile Paint Touch-up
All done, a quick morning drive before the next phase
Old Thu, Jun-08-2017, 06:46:59 AM   #4
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Wanted to start off on a clean slate, so figured might as well just start replacing everything. Vanos line, coils, spark plugs, filters, engine/diff/tranny oil, etc.
Spark plugs were wet, replaced the valve cover gasket, and did a compression test -190+ psi across all cylinders.
Cleaned and back together
Started preparing for CA smog. Since the battery was disconnected, I had to get the ECU ready by completing a drive cycle:
http://www.instructables.com/id/How-...or-Smog-Check/
Ready to Rock-n-Roll
PASSED
Celebration by repairing the burnt out bulbs with LEDs
Old Thu, Jun-08-2017, 07:00:02 AM   #5
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Time to start cleaning. Just kind of taking my time with a toothbrush, degreaser, and steam tool.
Old Thu, Jun-08-2017, 07:06:11 AM   #6
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Time to start fixing or upgrading. Just minor annoyances or opportunities to get everything nice and new.
Seats out for new clutch pedal, clutch pedal bushings (delrin), and brake switch.
Insulation was missing behind the knee panel underneath the steering wheel. Bought some insulation from Amazon.com and cut my own templates to re-glue.
Figured since I'm taking stuff apart already, might as well fix the gauge cluster. Many thanks to Braymond141 for the write-up. Off goes the steering wheel.
Cluster fixed put back together. Fix one thing and another problem rears it's ugly head -error for the brake pedal travel sensor.
Timing was good, didn't want to put the old steering wheel back on and the new euro wheel from Tainik came in from Germany.
Daytime shot below with new shifter
Old Thu, Jun-08-2017, 02:18:21 PM   #7
JitteryJoe
Nice low mileage car. Great to see it in good hands. Good luck!
Old Thu, Jun-08-2017, 03:55:41 PM   #8
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Thanks! I wish I was more mechanically-inclined so I can pull the engine and subframe like your build
Old Thu, Jun-08-2017, 04:14:31 PM   #9
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
I wanted to clean the rear wheel wells, figured might as well just pull the suspension off to do it (and inspect the RSM since there was an occasional clunk while driving).
Turns out the rear passenger side shock tower had a slight crack. Called around a few shops, no one really cared to take the business. Found a race shop in Irvine called Lang Racing to help me out. Their facility has a dyno, alignment machine, fabrication shop, and engine building room.
I opted to do the left and right side with AKG RSM reinforcements. Plates were welded on, factory etch coat / primer applied, then painted white to match.
I had some extra money from an insurance settlement, so went a little crazy. Figured "while it was in the shop" I had the following done:
-new subframe and rear bushings all replaced (every piece of rubber with new OE)
-new RTAB bushings with limiters
-new FCAs and "lollipops"
-new engine and transmission bushings
-new shifter bushings and linkage
-new front and rear shocks
Drive back to the office was full of smiles!
Old Thu, Jun-08-2017, 04:24:40 PM   #10
Oogie_M
o_O
Oogie_M's Avatar
Taiwan
Dash error lights seriously bother the hell out of me! Cleaned the wheel sensors for the ABS/ASC light, nothing. Scantool didn't show any codes. Swapped in new wheel sensors in an attempt to detect if a particular one was the culprit, nothing. Finally just replaced the brake travel sensor.... FIXED!
M-Rain interior came in, picked up at the Greyhound station. Also acquired some spare OE fabric for color matching (the rear side pieces didn't come in Alcantara). Seats are in good condition, passenger side and rear fabric is mint, but the vinyl seat backing needs some repair for scuffs and a small tear. I joined the group buy with M-Fabrics in the UK (https://www.m-fabrics.com/) for reproduction grey M-rain cloth. Waiting for everything to come in before finding an upholstery shop.
Discussing Oogie's 97 M3 Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
