Old Wed, Feb-08-2017, 11:19:35 PM   #1
youinreverse
Reputation: 0 youinreverse is on a distinguished road
Default Jared's E46 M3 Sedan Swap
Hey all,
I've been lurking for a long time reading through build threads from cyberkaa, kaiv, Redshift, and JeppeJ, and I've been dreaming about building my own someday. I started pouring over IAAI and Copart every day searching for the perfect donor car. In December, one popped up on IAAI at a yard just 40 minutes north of Salt Lake City. It was a 2001 M3 with a six speed with just enough body damage that someone looking to restore one would avoid it, because it had damage on almost every panel. It was just what I needed. I swear I checked that page three times a day for the next month before it finally went up for auction. I found someone from the local enthusiast group that worked as a broker to help purchase the car. We won the car with $100 under our max bid. After fees it ended up costing about $4,100. Good thing I'm getting a nice tax return this year.
I got the car picked up on Friday. I took off work early and went up to the wrecking yard to pick it up. Here she is...
The car was listed as non running/non driving. I got it home and popped the trunk open and immediately found the cause of the problem - one of the battery cables wasn't fastened down. Bingo! I checked the fluids and fired it up. The car started up pretty quickly, but there were a few misfires, and around 8 codes. I let it run for a while and things smoothed up a little.
We got it up on the lift to check things out. It was filthy underneath. Grime built up on everything. There was about 1/4 inch on top of the sway bar.
Found a few good surprises though. It's got Turner Motorsport sway bars on front and rear, plus a UUC Corsa exhaust that retails for $1,900. The bushings and suspension looked to be in good shape, and there were no real obvious problems other than the oil leak.
We decided it would be good to clean things up before trying to tear it down. We pulled the car out of the garage and drove down to use the wash bay at my work. The clutch was slipping terribly. It revved super high but the speedometer didn't match. We limped it down there and got to work with the pressure washer and degreaser.
After cleaning, we limped it back and checked the codes again. Three codes left. One for an oil temperature sensor, one for an EGT sensor, and one for implausible engine temperature, which I'm guessing goes along with the faulty oil temperature sensor.
We got it on the lift and began teardown.
Jump to top youinreverse is online now   Reply With Quote
Old Wed, Feb-08-2017, 11:24:56 PM   #2
TheCoder
TheCoder's Avatar
Reputation: 0 TheCoder is on a distinguished road
Default Re: Jared's E46 M3 Sedan Swap
Subscribed ! Sounds like a long, painful and fun project.
Sent from my SM-G930P using Tapatalk
2002 Titanium Silver BMW 325Ci SOLD
2003 Estoril Blue BMW M3
2003 Estoril Blue BMW M3 Journal
How to Import a car from Canada
Jump to top TheCoder is offline   Reply With Quote
Old Thu, Feb-09-2017, 01:33:10 AM   #3
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
In for the Jared party. Your pics aren't working, try hosting them elsewhere. I use Photobucket personally; I don't like it but it works.
JaredMV's M3 Touring Build: http://www.m3forum.net/m3forum/showthread.php?t=604213
Originally Posted by Jaredomin View Post
8k shipped. Lmk thanks
Jump to top JaredMV is online now   Reply With Quote
Old Thu, Feb-09-2017, 05:52:54 AM   #4
youinreverse
Strange. I've never had any problems with Imgur before.
Are they not showing for anyone else?
Old Thu, Feb-09-2017, 06:15:26 AM   #5
Jt_e46m3
Reputation: 0 Jt_e46m3 is on a distinguished road
Nope, pictures aren't working
Jump to top Jt_e46m3 is offline   Reply With Quote
Old Thu, Feb-09-2017, 01:28:58 PM   #6
DBurke
Reputation: 0 DBurke is on a distinguished road
No pics here either.
Jump to top DBurke is offline   Reply With Quote
Old Thu, Feb-09-2017, 04:41:43 PM   #7
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Imgur and this website don't mesh at all, that is why. OP hopefully you'll fix it because the pics are awesome. I was able to see them by right clicking and grabbing the image address.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Old Thu, Feb-09-2017, 04:44:45 PM   #8
TheCoder
TheCoder's Avatar
I can see them
Old Thu, Feb-09-2017, 11:18:08 PM   #9
youinreverse
I've rehosted the images on Flickr and edited the post. Hopefully they're showing up now.
Old Fri, Feb-10-2017, 04:52:52 AM   #10
youinreverse
We got the car back in the garage and started on disassembly. First we removed the front bumper and all the associated supports. It's going to be way easier to get this engine out.
From the outside, and interior, the car looked pretty badly neglected. Grime all over the engine, tons of trim pieces were broken, the slipping clutch, and other things pointed me to the assumption that the previous owner didn't give this car much love. Draining all the fluids was a pleasant surprise though. Power steering fluid had a small leak, but the fluid was pretty full and looked good. The coolant was the OEM blue, and it looked crystal clear.
Once all the fluids were drained, we removed the radiator, condenser, oil cooler, and fan shroud assemblies. Now that we're in the standard Audi service position we can really get to work.
Removing the radiator revealed just how bad the oil leaks are on this engine. Everything on the passenger side of the block is completely COATED.
I think there's a BMW engine somewhere underneath all this...
...oh, there it is.
Discussing Jared's E46 M3 Sedan Swap in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
