Old Thu, Jul-21-2016, 11:59:11 PM   #1
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
Default paffy GTS4 build
I've lost 2 M3s at HPDEs in last 10 months. I've contemplated quitting the hobby.
Instead I've decided to go W2W racing. Turns out I had almost all the necessary parts to build a race car left over. Naturally NASA GTS3/4 was my choice.
I'm really curious how much time gets dumped into project like this, so I'll try to keep track of hours as I progress, hence the journal.
I've picked up an almost bare shell to start with:
http://www.msstuning.com/ - serving your MSS5x flashing needs
2014 BMWCCA NY autox E class champion
My GTS4 build journal - http://www.m3forum.net/m3forum/showthread.php?t=551613
Jump to top paffy is offline   Reply With Quote
Old Fri, Jul-22-2016, 12:04:19 AM   #2
paffy
Czech_Republic
Default Re: paffy GTS4 build
Day 1&2, 7 hours total:
Stripping everything, removing some extra sheetmetal.
Old Fri, Jul-22-2016, 12:06:26 AM   #3
paffy
Czech_Republic
Found pretty major RACP issues, but nothing that can't be fixed:
Old Fri, Jul-22-2016, 12:08:35 AM   #4
paffy
Czech_Republic
Day 3&4, 7 hours total:
Remove all soundproofing, prepare wiring harness for splitting, more sheetmetal removal, minor things.
Old Fri, Jul-22-2016, 12:11:31 AM   #5
paffy
Czech_Republic
Day 5,6&7, 16 hours total.
Harness thinning - what a quagmire. I've ended up separating everything, since I've started with unlabeled harness from a previous SMG car and ended up with a huge tangled mess several hours into it.
Not going to use:
Will go back into car:
Old Fri, Jul-22-2016, 12:16:00 AM   #6
paffy
Czech_Republic
Day 8, 3 hours:
Cleanup the shell where metal was removed, protect with primer.
Ooops, found another RACP crack on the right side, the whole RACP will need to be lifted 3-4mm back in its place on that side somehow
Old Fri, Jul-22-2016, 12:20:07 AM   #7
paffy
Czech_Republic
Since I'll be building a subframe support into the cage, I'll use it to align the RACP back using bolts.
I've used some aluminum tubing to protect threads in the RACP while drilling all the way through:
Success:
Old Fri, Jul-22-2016, 12:25:03 AM   #8
Abad46
Abad46's Avatar
Reputation: 0 Abad46 is on a distinguished road
Wow! This is super exciting and can't wait to watch this build unfold!
Jump to top Abad46 is offline   Reply With Quote
Old Fri, Jul-22-2016, 12:31:13 AM   #9
paffy
Czech_Republic
I've actually started designing the cage before I got the shell using a crashed car.
Took a bunch of measurements from the bottom of B pillar and spent several evenings in Solidworks.
Old Fri, Jul-22-2016, 12:34:59 AM   #10
paffy
Czech_Republic
Day 9, 5 hours:
Prepare trunk metal for plasma cutting:
20 seconds later - EVERYBODY SHOULD OWN a PLASMA CUTTER
Opps - another crack in the RACP hiding in there !!! I wonder how many cars have this
Discussing paffy GTS4 build in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
