Old Mon, Mar-28-2016, 06:06:25 AM   #1
Smoove1
Smoove1's Avatar
Reputation: 0 Smoove1 is on a distinguished road
Default Geoff's '01 M3 Journal
I'm starting this journal to keep track of the progress of my newly acquired 2001 TiAg M3. It's a 100% option car with black interior, one owner car that was purchased with 100,349 miles on the clock. It was owned by a long time customer of my friend's independent BMW repair shop. It started making a bottom end noise and decided with the potential cost of repairs and being 71 years old it was time to let it go. Before taking it home my friend took care of the rod bearing and got all services up to date for me. With it being as mechanically perfect as it can be the fun begins. As she sits, my plan is to make it a fun weekend driver and capable DE car
Here it is the first day home:
And with the rest of it's family:
I decided to take some pictures of the car in it's original state before making as modifications. I figure they'd be nice to have incase I ruin it. You know, poor choices in modding and what not.
Week 2 of ownership I decided to install a group of parts I consider to be an essential starter pack. It's comprised of LED tail lights, clear front bumper reflectors, a regrettably loud exhaust, CSL style front lip and diffuser, and suspension.
After a week of shopping for suspension I was fortunate enough to find a clean set of AST 4100 single adjustable coilovers. I had a set of their 4200s on my old track prepped E36 M3 and liked them a lot. I'm hopeful for the same outcome. I decided to spend a saturday to get everything installed. I pulled the car into the shop at 8:45am and was finished by 12:30pm. The only issues I ran into were the sway bar end links were too long. I should have known better. I set the ride height to "good enough for now" and decided I was hungry. Here is the end results:
I decided a shake down for the car was necessary and what better way to test your car then to enter round 1 of the Redline Time Attack Series.
I was able to get enough break in miles on the rod bearing about 3 days before the event. My friend did an oil change for me and installed some E36 M3 sway bar end links so that I can lower the front a bit more. I was fortunate enough to have a co-worker willing to do an alignment for me after hours the Thursday before the event:
I decided to start off with -3.5 degrees camber up front and -2.5 degrees in the rear. Toe was set at 1/8" toe out in front and stock toe setting in the rear. Typically I wouldn't start with that much camber up front but with the stock size Michelin Pilot Super Sports I figured I could use it.
Saturday came soon enough and after about three weeks in here we are at Willow Springs International Raceway.
It's been a couple years since my last track day and my times were less than stellar. I ended up only running a 1:42.726 as my best of the day. Not a very impressive time by any means but I was still good enough for 3rd place in enthusiast class.
Overall the car did better than expected. The oil temps and water temps behaved themselves. The tires understeered quite a bit but after some pressure adjustments I was able to make it manageable. Stock brake pads didn't inspire confidence at the end of the front straight. The suspension managed the bumps of turn 8 well and the car felt planted.
Here are some pics on track:
Well, that's it for now. I'll post again once my wheels get back from getting refinished. I have a set of 18x9.5 et18 Forgeline RSs that I've ran on 3 other cars I've owned in the past. I'm hoping they're going to look as good as I envision in my head. Add some stickier, wider tires and race pads. Those are the changes I'd like to make before round 2 of RLTA.
My Build Thread
Jump to top Smoove1 is offline   Reply With Quote
Old Mon, Mar-28-2016, 04:04:09 PM   #2
FK
Default Re: Geoff's '01 M3 Journals
Dem ducks.
Old Fri, Apr-08-2016, 03:37:33 PM   #3
Smoove1
Smoove1's Avatar
My wheels finally came back from getting repaired and refinished. 18x9.5 Forgeline RS street versions et18
My Build Thread
Old Fri, Apr-08-2016, 04:29:51 PM   #4
GodHandzE46
GodHandzE46's Avatar
Reputation: 0 GodHandzE46 is on a distinguished road
Can you show me around Chuckwalla too?
Subscribed
Jump to top GodHandzE46 is offline   Reply With Quote
Old Fri, Apr-08-2016, 04:33:25 PM   #5
BMWjunkie11
That guy
BMWjunkie11's Avatar
Reputation: 0 BMWjunkie11 is on a distinguished road
Lowered on OEM 18's; such a classic look that never gets old. I can't tell you how many times I've thought of ditching the works and running square OEM 18's.
2002 Jet Black/Grey ///M3
Full Supersprint Race Exhaust l PSDesigns Velocity Stack Kit l TMS Pulleys l TTFS Custom Alpha-N Tune l Work Brombachers
"Bags are for dead hookers"
Jump to top BMWjunkie11 is offline   Reply With Quote
Old Fri, Apr-08-2016, 08:07:53 PM   #6
Smoove1
Smoove1's Avatar
Subscribed
Of course man. I'll try to find my communicator so I don't have to yell this time.
My Build Thread
Old Fri, Apr-08-2016, 10:04:49 PM   #7
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Looking good Geoff!
E46 ///M325i Touring journal
Old Sat, Apr-09-2016, 12:14:08 AM   #8
Romango3
Romango3's Avatar
Reputation: 0 Romango3 is on a distinguished road
Mount them on the e46 already dammit
IG: @ROMANGO3
Jump to top Romango3 is offline   Reply With Quote
Old Sun, Apr-10-2016, 05:51:20 AM   #9
Smoove1
Smoove1's Avatar
Here ya go
My Build Thread
Old Mon, Apr-11-2016, 01:40:48 AM   #10
Romango3
Romango3's Avatar
Ok that's perfect . Maybe space the rear out slightly
IG: @ROMANGO3
Discussing Geoff's '01 M3 Journals in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
