Old Sat, Mar-05-2016, 02:31:10 AM   #1
Gtfour
Gtfour's Avatar
Reputation: 0 Gtfour is on a distinguished road
Default Street legal.Pretty much. E46 M3 ZCP Track car build
Hi guys,
Here is a journal for the 2nd BMW E46 M3 track car that I am building. I also decided to included all the different BMW that I've owned between my first and second build threads. As you will see, I like to change car very often. Hope you guys enjoy!
Vehicle Specifications
BMW E46 M3
Build Date: XX/2005
Competition package
6MT
Carbon Black
Black Nappa Leather
Premium Package
Cold weather package
Xenon Headlights
Harmon Kardon
Sunroof
Modification list
Drivetrain
Geoff Steel Racing CSL carbon fiber airbox with FRP snorkel
TTFS CSL air rail and MAP sensor
TTFS Custom Alpha-N tune
Supersprint Stepped V1 headers
Supersprint V1 section 1
Supersprint resonated section 2
Dinan Free Flow exhaust
ATi harmonic balancer with underdrive pulley
AKG Motorsport 75D engine mounts
AKG Motorsport 75D transmission mounts
AKG Motorsport 75D differential mounts
RE coolant overflow line
CSF radiator
CSF oil cooler
BMW Motorsport 55 degrees thermostat
Bimmerworld oil diverter valve
ECS Tuning coolant silicone hoses
Aluminum coolant bleeder screw
UUC braided SS clutch line
Wrinkle black painted oil filter cap
42 DraftDesign wrinkle black oil catch can
BMW Motorsport 4.10 ring/pinion diff
JB Racing lightweight flywheel
ClutchMaster FX400
Exterior
Lang Racing carbon fiber roof
Aeromotions wing with custom brackets
OEM amber sides and corners reflectors signal
Lamin-X amber taillights film
Color match painted front reflectors
HARD Motorsport sliding front tow hook
Gutted OEM trunk
Allstar duct in front bumper for CSL intake
Custom block off plate front bumper passanger side fog light hole
Ziza 6000k halogens headlights bulbs
Suspension
JRZ RS 2-way non-remote dampers
Eibach springs 6''/2.25''/700 front - 5''/2.25''/800 rear
Ground Control race camber plates
Ground Control rear suspension mounts
Hotchkis hollow adjustable front swaybar
Ground Control front adjustable swaybar links with spherical bearings ends
VAC Motorsport roll center correction tie-rods
AKG Motorsport Rear Trailing Arm spherical bearings
AKG Motorsport 75D Front Control Arm Bushings
AKG Motorsport 75D rear subframe mounts
Turner Motorsport rear subframe reinforcement
Rogue Engineering Race strut brace
Rogue Engineering Rear Control Arm spherical bearings
Rogue Engineering rear camber arms
Brakes
AP Racing CP8350/325 front BBK
325x32mm 2-pieces rotors J-Hook
Performance Friction race pads compound 01 / 13
OEM ZCP rear calipers
DBA 4000 rear rotors
Performance Friction race pads compound 11
ECS Tuning Stainless steel braided lines
Brass guide pin bushings
Interior
Custom roll bar tied-in to rear subframe
Custom aluminum door cards
MotoMaster carpet
OMP WRC-R seat
OMP Corsica 350mm steering wheel
OMP 1010 pedals
VAC Motorsport floor mounts
VAC Motorsport side mounts
VAC Motorsport harness anti sub mounting
VAC Motorsport lap belt mounting bracket kit
Sparco slider
Schroth Profi III harness
Rogue Engineering Octane SSK
AKG brass clutch pedal sleeves
AKG delrin brake pedal sleeves
IND style tall delrin shift knob
Alcantara shift boot ///M tri-stitched
Alcantara hand brake boot ///M tri-stitched
Armrest delete center console
Braille 17Lbs lightweight AGM battery
Rogue Engineering clutch stop
Tinted windows 35% front 20% rear
Radio delete panel
Bimmerworld windshield defrost kit (not installed yet)
Wheels
2 sets of APEX ARC-8 in satin black
18x9.5 et35 18x10 et25
90mm studs kit
Muteki SR48 nuts
12mm spacers for front wheels
Pirelli DH slicks 275-645-18
1 set of APEX ARC-8 in satin black
18x9.5 et35
10mm spacers for rear wheels
Nitto NT01 275/35/18
Fluids
GULF RBF1000 brake fluid
Redline transmission fluid
LiquiMoly 10w60 engine oil
Gulf 75w140 diff fluid
Parts removed
AC delete (compressor, condenser, lines, air dryer)
Heater core
Mechanical fan
Xenon to halogens headlights conversion
Headlight auto-levelling switches
Headlights washer nozzles
Windshield washer reservoir
Brakes backing plates
Leather interior
Fog lights
Headliner/sunvisors
Audio with wiring harness
Airbags and module
Clutch delay valve
Rear bulkhead
Sunroof
SAP/EGR delete with custom block off plate
Charcoal canister
Rear swaybar
Handbrake
New OEM parts/Maintenance done
VANOS line
VANOS filter
Water pump
Fuel pump
Fuel pressure regulator
Bosch alternator
Valve cover gasket with spark plugs seals
Throttle body boots with reusable clamps
Fuel filter
Transmission selector rod seal
Guibo flex disc
Driveshaft center bearing
Oil level sensor gasket
Oil pump pick up gasket
Constant pressure valve o-ring
Crankshaft position sensor
Camshaft position sensor (intake and exhaust)
Oil pressure sensor
Water temp sensor
Valeo starter
Coolant overflow reservoir
DriveShaft center bearing
Windshield
Jump to top Gtfour is offline   Reply With Quote
Old Sat, Mar-05-2016, 02:31:43 AM   #2
Gtfour
Gtfour's Avatar
Default 2002 E46 M3 steel grey track car
I always wanted another E46 M3 dedicated track car from the day I sold my last E46 M3 race car back in December 2011. I sold the car and my 18'x8.5' Brimar open trailer because I didn't had a garage back then. My car was always at my sponsor's garage VAG Motorsport but the business was growing and space was missing for my M3. I didn't want to rent a storage space because you can't do any mechanic in them.
Here is the build up thread of my last E46 M3, some might remember it:
http://www.m3forum.net/m3forum/showthread.php?t=316864
I also sold my extra E46 M3 shell to the guy who bought my race car couple of month later.
Old Sat, Mar-05-2016, 02:32:15 AM   #3
Gtfour
Gtfour's Avatar
Default 2007 BMW E70 X5 4.8i
My daily driver back then was a 2007 BMW E70 X5 4.8i Jet Black on Cinnamon
-Sport package
-Navigation
-Heads-Up display
-OEM style 214 & 215 wheels
-Self leveling rear suspension
-OEM hitch
-Tekonsha Prodigy II brake controller
-35% tinted front windows
-black kidney grills
-K&N drop in air filter
Old Sat, Mar-05-2016, 02:32:37 AM   #4
Gtfour
Gtfour's Avatar
Default 2007 BMW Z4M Coupe
Two months later (February 2012) after I sold the E46 M3, I was looking to buy a street legal car that I can track. I was tempted to get another E46 M3 but I ended up buying a 2007 BMW Z4M COUPE with ESS VT445 supercharger kit. Saw the car on AutoTrader and fall in love instantly.
I picked up the car in Halifax, Nova Scotia. I did the trip with my E70 X5 and bring back the car with my friend's Trailex aluminum open trailer. It's a 2600km trip back and forth, during winter and hit a snow storm on my way back.
BMW Z4M Coupe
Build Date: 12/2006
#1013 of 1815
Silvergray
Imola red Nappa Leather
Navigation
Some pics when I got the car
I fabricated a custom hitch for the M Coupe and bought an Harbor Freight trailer. I fabricated a tire rack with locks, space for 3 fuel jugs and installed a pick up truck box on it. Perfect setup to go to the track!
Some winter fun ride with the M Coupe
At some point I wanted a race seat so I trade my imola red leather for black leather + cash and got a Recaro Pole Position leather /alcantara seat
The navigation system in the M Coupe sucks honestly. I got tired of it and was able to sell my navigation system and trade the dash board to get rid of the hole for the flip screen. So I removed some weight and made some cash for other mods. Also installed a lightweight battery at the same time
I installed CSL headers and modified the section 1 like an euro and add o2 sensors and EGT bungs in it. Did the job myself. The bungs are from Vibrant and the EGT bung is custom, drilled the center of a M14X1.25 bolts on a lathe and cut the head. I also gutted my OEM mufflers and weld bigger tips. The mufflers are a bit restrictive from factory so I make a straight design while keeping the perforated pipe and keep the same packing
I installed an APR GTC 300 and made custom brackets to hold it in place
I had KW Clubsport with Hyperco 650/750 spings and Performance Friction Z45/Z29 BBK!
Installed Strong Strut 3 pieces brace kit and a 42Draft Design oil catch can
Old Sat, Mar-05-2016, 02:32:57 AM   #5
Gtfour
Gtfour's Avatar
Default 2007 Z4M Coupe
Modification list
Recaro Pole Position black leather/alcantara
Jaffster shift knob
Navigation delete
AutoSolution short shift kit
BMW Motorsport 4.10 diff
ESS VT1-445 supercharger kit
BMW E46 M3 CSL OEM headers
OEM section 1 cats with EGT/O2 sensors bungs weld in it
Gutted OEM mufflers
42 Draft Design oil catch can
Strong Strut 3 pieces kit strut braces
KW Clubsport coilovers
650/750 Hyperco springs
Adjustable front/rear swaybars
Performance Friction Z45/Z29 BBK with PF01 pads
APR front splitter and APR GTC300 rear wing
Custom hitch
Braille 21Lbs battery
CCW Classics race version 18x9.5et32 18x10et25
Pirelli DH slicks 245/265
Apex ARC-8 18x9.5et22 18x10et25
Pirelli Trofeo 245/265
I owned the car for 2.5 years and did about 10-15 track days with it. It was a nice car, relatively fast on the track, rare... But it was kind of too nice and still worth too much money to completely gutted it and make a dedicated track car out of it. I was also having problem with the ESS software during cold track days. The car would get into limp mode because it was running too poor/there was not enough fuel delivered and would not go higher than 1000 rpm unless you shut the engine off and restart... Kind of dangerous on the track... And ESS would not give any support since the Z4M crowd is so small...especially those with ESS SC kit who track their car and can push hard enough to get this limp mode... I think we were like 5 on the planet who had this specific problem...So I sold the Z4M Coupe back in June 2014.
Old Sat, Mar-05-2016, 02:33:21 AM   #6
Gtfour
Gtfour's Avatar
Default Re: Street legal.Pretty much. E46 M3 ZCP Track car build
The M Coupe at VAG Motorsport next to a nicely prepared Z3M Coupe
The Z4M Coupe on CCW Classic and ACS Type 2
Old Sat, Mar-05-2016, 02:33:41 AM   #7
Gtfour
Gtfour's Avatar
Default 2005 bmw e46 325xit
During the time I had my Z4MC, I got rear end with my BMW E70 X5 and decided to sell it after. I didn't need to tow anymore and bought a 2005 BMW E46 325 XIT 5-speed with sport package as a daily driver to replace the X5.
Vehicule specifications
Sapphire black on black
130000km
5-speed manual
Slicktop, no sunroof
Roof rack bar delete
Mtech II front bumper with Clubsport splitters
Black kidney grills
Clear corners and side lights
E46 M3 rear view mirrors
Kurt hitch
BMW 330 front brakes upgrade
S52 engine beauty cover
Clutch stop
E46 M3 dead pedal
E46 M3 steering wheel
BMW Performance shift and e-brake alcantara boots
ZHP shift knob
Tinted windows 35%
KW V1 coilovers
BMW OEM strut brace
CCW LM20 18x8et44 18x9et38
Michelin PSS 215/245
Old Sat, Mar-05-2016, 02:34:02 AM   #8
Gtfour
Gtfour's Avatar
Default 2008 bmw e90 m3
When I sold the Z4M Coupe in June 2014, my E46 Touring was my only street legal car, no more summer toy. It lasted 2 months before I switched to something else. The touring was a nice daily driver and winter beater but the M54B25 miss something call POWER, especially when AWD!!! So I was able to get a really decent price for it when I trade it for my 2008 E90 M3 Silverstone II with black interior.
6-speed manual
Executive package
Technology package
Carbon leather trims
Tint windows 35%
aFe filter
Dinan mufflers
Black grills
Painted reflectors
Arkym CF front lip
BMW Performance CF rear spoiler
BMW Performance shift knob
BMW Performance pedals
APEX ARC8 18x9.5et35 18x10et25
Michelin PSS 245/265
Installed OEM CF Mirror caps, Arkym front lip, black grills and tinted windows
Installed Dinan mufflers
Installed my ACS Type 2
With the ARC8 and oem CF spoiler
I had to change the throttle valve actuators $$$$
I need to admit that the E90 M3 is a really nice daily driver. It's comfortable on the road not like the E46 OEM suspension, seat/driving position is perfect and seats are way more comfortable than E46. I had all the nice feature in mine like comfort access, NAV, EDC, ... The S65 is an awesome engine but needs to rev to be fun and the way I do my daily commute I rarely use the engine to it's full potential. I did only one track day with the E90 M3 where you can really use the engine but the car feels front heavy and a bit less precise than E46 M3. Anyway, I bought it to use only as a daily driver anyway.
In december 2015, a friend of mine told me he wanted to sell his Porsche 997 Turbo and his 2002 BMW 325xit to get only one car instead, an E90 M3. He was looking for an alpine white on Fox red. I told him that I can sell mine if he want it. At first, he wasn't interested in my car because Silverstone II... So I offered him to trade my E90 M3 for his 325xit. Once the 997T sold, my offer was more interesting because that way he didn't had to sell his Touring. He looked on the web and found a Fox red interior and finally accepted my offer. So we trade cars in January 2016 and I installed a couple parts on the E90 M3:
-Mars LED Taillights
-BMW Performance steering wheel
-Angel eyes
-Fox Red interior
I also help him out with a new set of Work VSXX. He wanted to get the centers in Silverstone II like the car!
While installing the Fox red interior, I had some fun with guys on a local forum. I took some pics with roll bar I have for E46 M3 and told them I was building a race car with the E90 M3!
Old Sat, Mar-05-2016, 02:34:23 AM   #9
Gtfour
Gtfour's Avatar
Default 2002 E46 325XIT Japanrot
So here is my actual daily driver. Reasons for trading my E90 M3 were :
-free up some money for the E46 M3 mods and track season
-I am doing only 10000km / 6250 miles a year of daily commute
-road sucks big time here in Montreal, Canada
-winter is hard for a car & screw up a paint job
-I will eventually want a SUV with a tow capacity around 5-6000lbs as a DD
-Never like the look of the E9x M3 generation that much
2002 E46 325xit
Sport Package
5 speed manual
130500km = 82000 miles
Japanrot / Electric red exterior
Black interior
KW V1 coilovers
Avant Garde M220 19x8.5 et35
M3 steering wheel
M3 mirrors
M3 rear view mirror inside
ZHP shift knob
BMW Performance shift boot
BMW Performance e-brake boot
Clear corner and side lights
Euro clear taillights
Painted mouldings
tinted windows 35%
Weathertech rubber carpets
Westfalia custom hitch
Wrapped window trims A to D pillars
Old Sat, Mar-05-2016, 02:34:43 AM   #10
Gtfour
Gtfour's Avatar
Default 1999 BMW Z3M Coupe
In March 2014, I bought a 1999 BMW Z3M Coupe track car. It was a salvage title car that was poorly fixed. I bought it for cheap (8000$) and sold some extra or unwanted parts and in the end with all the parts sold and the new parts bought the car cost me 0$ . It was just a project car for me because I never really wanted to track this car.
Modification list
Moton Motorsport 2-way coilovers with 600/750 springs
Turner Motorsport adjustable swaybars
Strong Strut front brace
Recaro Profi race seat
Schrotch Clubmann harness
OMP 1010 pedals
OMP Superleggera steering wheel
Jaffster shift knob
APR front splitter (Z4MC)
Aerocatch hood pins
DBA 4000 rotors
Calipers guide pins brass bushings
Bimmerworld aluminum radiator
3.73 LSD diff
Bimmerworld silicone elbow
aFe filter
Magnaflow mufflers
E46 M3 OEM 18x9et26 square setup painted black
The car had a kind of roll cage that was not well made, weld were not 360 degrees and design was weird so I start removing all the 1-1/2'' bar and also the weird one. I also removed all the extra weight in the interior like door cards, center console, sunroof and mechanism, AC components, sound deadening, some sheet metal, gutted the doors interior and trunk, ... I installed an APR front splitter (the one from my Z4MC) & rear wing with custom riser, paint the dash in black to cover the tan original interior, made some vents into rear bumper, remove glass windows in doors, rear quarter and back glass. Made a vent into the front bumper to give more air to the radiator. There was hood pins installed previously and the installation must went wrong because there was some extra holes drilled and hood was a bit bent. I was able to correct that job while installing Aerocatch hood pins.
Discussing Street legal.Pretty much. E46 M3 ZCP Track car build in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
