Old Fri, Oct-30-2015, 07:47:11 PM   #1
TheCoder
TheCoder's Avatar
Reputation: 0 TheCoder is on a distinguished road
Default The Coder's 03 Estoril M3 Journal
As some of you might know, I've recently joined the M club after 7 years of owning and caring my own E46 325Ci. I posted my purchase story earlier in a 'How to Import a Vehicle from Canada' thread.
Now it's time to maintain and do some tweaks on this all stock vehicle. @97.5 k I already refreshed the fluids, replaced the drive belt, and have some plans for this vehicle as follow
1. Reinforce the subframe
2. Swap the SMG with Manual while it's functional
I'll keep you all posted
Log
06/10/2011
@72969
Brake pads & rotors
RTAB
Wiper blade
11/01/2011
@76244.1094
Inspection I
Diff fluid
Replace radiator tank, refill coolant
Left tie rod
11/01/2011
@76270.207
New Valve Cover Gasket
02/14/2012
@77050
BMW Exide OE Battery
09/08/2012
@79209 mi
VANOS unit replaced
06/21/2013
@86306
New Rear View Mirror
10/10/2014
@94207
Constant Pressure Valve
Power Steering Flush
Power Steering Pump
Power Steering hose
========PURCHASED===========
@97.5K mi
- Replace Oil fluid
- Bleed brakes
- Top off Power Steering
- New Rear Tires
- New Bosch Alternator
- New air filter
@99.5K mi
- Replace Oil fluid
- Bleed brakes
- SMG to 6MT swap
- Refresh 6MT fluid
- Replace all transmission input and output seals
- New Luk Clutch and flywheel
- New OE Input shaft pilot bearing
- Copper Clutch fork Ball pin
- New OEM Clutch fork
- New OEM Clutch Release bearing
- New OEM Clutch Slave Cylinder
- New OEM Clutch Master Cylinder
- New OEM Central Support Bearing
- All input and output seals replaced on rear diff
- Reedish RCAP reinforcement kit (welded).
- Vincebar RCAP reinforcement bar (Welded).
- AKG subframe bushings
- ECS Tuning front Diff bushing
- Replaced Diff two rear bushings
- Upgraded ESC Tuning BBK CSL slotted and drilled Rotors, and CSL brake adapter.
- Replaced all brake lines with steel braded brake lines from ECS Tuning
- HAWK front and rear brake pads
- Upgraded DME assembly to latest assembly (7.842.973)
- Replaced Fuel filter and pressure regulator
- Upgraded all interior light to Ziza LED.
- WINCOS 70 Premium Series IR Clear tint applied to all windows except windshield.
@100k
- Genuine BMW LED tail lights
- OEM Eldor ignition coils
- OEM NGK laser platinum spark plugs
@100.5K
- New from Windshield with water sensor
- New WINCOS 70 Premium Series IR Clear tint applied to windshield
- New Genuine face-lift reverse light
@100.7K
- New Left wheel hub bearing
- New Set of ZCP Wheels and Michelin PS2 tires.
@105.3 K
- Liqui Moly 10w60
- New Mahl oil filter and rings
- Chain tensioner crush ring
- New oil level sensor
@105.7K
- New Drive shaft CV Joint.
- New Drive shaft Center bushing
- New Flex Disc
Note: All replacement parts are OE or OEM unless stated otherwise.
2002 Titanium Silver BMW 325Ci SOLD
2003 Estoril Blue BMW M3
2003 Estoril Blue BMW M3 Journal
How to Import a car from Canada
Jump to top TheCoder is online now   Reply With Quote
Old Fri, Oct-30-2015, 08:28:31 PM   #2
e46lsb
e46lsb's Avatar
Reputation: 0 e46lsb is on a distinguished road
Default Re: The Coder's 03 Estoril M3 Journal
Love that color!
Individual- inside and out.
Jump to top e46lsb is offline   Reply With Quote
Old Fri, Oct-30-2015, 08:28:52 PM   #3
e46lsb
e46lsb's Avatar
Although I'm biased
Old Fri, Oct-30-2015, 08:38:43 PM   #4
TheCoder
TheCoder's Avatar
Originally Posted by e46lsb View Post
Although the I'm biased
No, you are not. You just got good taste.
Sent from my D6633 using Tapatalk
Old Fri, Oct-30-2015, 08:50:06 PM   #5
ARM3D
Reputation: 0 ARM3D is on a distinguished road
Ukraine
Congrats, great color!
2005 Interlagos Blue ///M3 ZCP || Photos ||
2018 Silverstone II ///M3 ZCP || Photos ||
Jump to top ARM3D is offline   Reply With Quote
Old Fri, Oct-30-2015, 09:58:17 PM   #6
Distinct70
Distinct70's Avatar
Reputation: 0 Distinct70 is on a distinguished road
Love the colour. Hate you for taking a great Canadian car away from us.
Jump to top Distinct70 is offline   Reply With Quote
Old Fri, Oct-30-2015, 10:13:13 PM   #7
TheCoder
TheCoder's Avatar
Sorry man. But if it makes you feel better, the previous owner bought it in the US anyway, so I technically brought it back home
Old Fri, Oct-30-2015, 11:44:04 PM   #8
Distinct70
Distinct70's Avatar
Hahaha! Then you have returned the Crown Jewels to the rightful kingdom. Awesome car!
Old Tue, Nov-03-2015, 09:38:44 PM   #9
TheCoder
TheCoder's Avatar
@97500 mi
I lifted the car and did an inspection : Noticed that the drive belts need to be changed. So I got some Continental drive belts and replaced both belts.
Also replace the Motor oil with my favorite Luqui Moly 10W-60 and a Mahle Oil Filter.
Measured the Alternator's output using the embedded dashboard voltmeter, and it seems a little shaky. at run time it's throwing 11-13 volts. So I though I'd replace and sell it while I'm there as well. I had good experience with the BOSCH alternator's on my 3 series so I got new BOSCH alternator instead of the current Valeo. ended up costing me a fraction of the price had it actually went out.
I also noticed some wear on the rear right spring, so I'll be replacing that along with the left side spring. Got me some new OE springs online.
Already found me a used 6MT manual transmission! at $850, that was a steal. I just need to prepare my computer with proper INPA, NCSExpert and
WinFKP so that i can code the vehicle's ECU properly
Last, I got my new plates ! Thanks to forum member M57 for their suggestion which surprisingly turned out to be available.
Old Tue, Nov-03-2015, 09:57:58 PM   #10
Alex
Troll
Alex's Avatar
Reputation: 0 Alex is on a distinguished road
No problem
Car is looking good
2003 BMW M3 Alpine White/Black - (SOLD but not forgotten )
2017 Mustang Crowd Killer GT- My first and last American car (SOLD and forgotten)
2011 BMW 335is DCT (for sale)
WTB: e46 m3
My M3 Journal
Jump to top Alex is offline   Reply With Quote
Discussing The Coder's 03 Estoril M3 Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
