Old Tue, Sep-29-2015, 10:27:06 PM   #1
BTB
BTB's Avatar
Cool BTB's 2003 Imola Red M3 Slicktop - Ongoing Build
Hey guys,
I've been posting/lurking around M3Forum since May 2013 when I first got the car, but never got around to creating a build thread. Until now that is.
The car is a 2003 (11/2002 build date) Imola Red/Black Napa 6MT M3 slicktop.
Factory options include:
-Harmon Kardon premium sound
-Heated front seats
-Rainsensor
-smoker's package
-front armrest (now deleted)
-xenon headlights
Anyway, its a fairly low-option M3 having no nav, manual seats, and no sunroof. Personally I think the outside looks a little cleaner without headlight washers and parking sensors as well.
As far as plans for the car go, I'm fresh out of college (May 2018), so just keeping it clean, well maintained and running right are big enough challenges. I plan on keeping the car as my daily driver until I can hopefully afford more than one car, at which point I plan on building a streetable track/drift car out of it.
In it's current state:
Around 77k on the engine here, 168k on the chassis
Modification list
As of 10/15/18
Engine/Exhaust:
-motor is from an '06 IB ZCP (not that it matters) and is approaching 80k miles
-full Beisan suite
-BW/C&R radiator
-BW/C&R oil cooler
-mishimoto fan kit
-mishimoto silicone radiator hoses
-Status gruppe catless headers
-Status gruppe 200 cell catted section 1
-RE X-pipe section 2 w/ EVC
-gold foil wrap
-machined oil filter cap
Drivetrain:
-JB Racing aluminum single mass flywheel *swapped to new stock dmf in Oct 2018*
-Clutchmasters kevlar clutch (that blew up, now running oe luk)
-TMS braided clutch line
-E60 shift lever
-UUC DSSR
-Rogue delrin brake and clutch pedal bushings
-Rogue delrin shifter carrier bushings
-cdv delete
Suspension/Brakes:
-Brembo GT 4 pots (front)
-RaceTech TS20
-Koni yellow shocks/struts
-Eibach pro-kit springs
-Rogue rsms
-TMS plates welded into racp, bmw foam
-Apex EC-7 18x9.5 et35 all around (12mm rear spacer)
-Potenza RE760 sport 245/40
-Stoptech slotted rotors, ss lines, and "street performance" pads (rear)
-Brembo 600
Exterior:
-SGT SCZA trunkid
-euro bumper
-black kidneys and side grills
-csl replica diffuser
Interior:
-Coby wheel alcantara shift and ebrake boots
-business radio button bracket fix
-Schroth quick fit harness
-BW little nicky knob
-custom fan switch/gauge panel
-Ultimate pedals (shiny smooth) with heel toe extension; wrapped in griptape
-armrest deleted, euro tray
-OMP Corsica 350mm, roundel horn button
-LeatherZ VDO gauges (oil pressure, water temp, volts)
Future Plans/Dreams:
CAE shifter
hydraulic handbrake with dual rear calipers
aluminum subframe bushings
oe rtab w/ limiter, or monoball
Recaro spg xl
Livery Dromo wheels
CF airbox
cams
TTFS
SCZA/SS street muffler
coilovers
adjustable sway bars
camber plates
clutch type built diff
DSS rebuilt axles
etc.
After doing an NA build/bolt-ons I'd consider doing a lower compression FI built engine w/ lang racing and going the turbo route, if I can reasonably afford to do so (inspired a bit by Mike Essa's car). Maybe stay NA and do a stroker, though... we'll see
Thanks for looking
My Journal
Old Sun, Apr-10-2016, 05:19:01 PM   #2
BTB
BTB's Avatar
Default Re: BTB's 2003 Imola Red M3 Coupe - Ongoing Build
Figured I can use this post for some old pictures of the car.
Back when the car was bought, May 2013
I know, she was rough
Track Days:
Gingerman Raceway - 4/25/14
First track day I had with the e46
Autobahn Country Club w/ MVP - 8/4/14
(after passing my dad in the e92 )
My Journal
Old Sun, Apr-10-2016, 05:29:25 PM   #3
BTB
BTB's Avatar
Just this past weekend I installed my new updated oil cooler
Vs. old
As well as the switch panel I made for the mishimoto fan, I think I'll make a new one with 2 spaces for vdo voltmeter and oil pressure gauges as well, but I'm glad this one turned out okay
And some footage 'testing' the new oil cooler
My Journal
Old Sun, Apr-10-2016, 11:28:26 PM   #4
Tom_schleg
Reputation: 0 Tom_schleg is on a distinguished road
Slick top
Jump to top Tom_schleg is offline   Reply With Quote
Old Tue, Apr-12-2016, 11:26:18 PM   #5
BTB
BTB's Avatar
Originally Posted by Tom_schleg View Post
Slick top
My Journal
Old Thu, May-19-2016, 09:57:48 PM   #6
BTB
BTB's Avatar
Default BTB's 2003 Imola Red M3 Coupe - Ongoing Build
Got car coded with ncs expert: enabled drls, one touch 'lambo' vents, key fob windows up/down, halogens on with xenon highs, etc. Very convenient.
Also received my pair of potenza re760 sports to match my fronts in preparation of next track day, blackhawk farms with PCA.
Edit: and a pic after a recent wash
My Journal
Old Thu, Jun-02-2016, 03:48:13 AM   #7
BTB
BTB's Avatar
Installed my new 350mm omp Corsica and matching potenza re760 tires on the rear. Will have to get more pics once I get the BMW roundel horn button (and more of the car in general )
Resistors added to turn off airbag light
Can't believe how much a steering wheel alone can change the feel of a car!
My Journal
Old Sun, Jun-12-2016, 09:44:35 PM   #8
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
Car looks great! Have you done an oil analysis on your engine yet??? Just curious because we have very similar mileage
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Sun, Jun-12-2016, 11:39:13 PM   #9
FK
Originally Posted by BTB View Post
Why are you using your blinker?
Old Sun, Jun-12-2016, 11:51:15 PM   #10
BTB
BTB's Avatar
Thanks man, I've done four of them actually, but the original engine was replaced with a used one shortly after I got the car (138k miles), I believe the original had a blown head gasket, and there was a fair amount of buildup in the motor, yada yada yada it got replaced. I've currently got ~77k on my engine. So they may be of no help to you
Regardless, the oil analyses can be found on the blackstone thread or in my photobucket album.
Iron was high on the first one, I believe there was some minor cylinder scuffing (tws and -20 degree F weather) as I remember during one particular cold start (leaving school) the engine made a scraping/scuffing noise for the first few seconds. Not good. They have gotten better and better since then so I don't think it was detrimental to the engine, and I believe each sample had at least one track day on it (except the one with pennzoil ultra euro 5w-40, winter oil).
Unlike the stereotype I actually like to inform people of my whereabouts on the road
My Journal
Discussing BTB's 2003 Imola Red M3 Slicktop - Ongoing Build in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
