Old Thu, May-21-2015, 08:22:32 AM   #1
LSB FTW
Fear is exciting for me
LSB FTW's Avatar
Reputation: 0 LSB FTW is on a distinguished road
Default E46 M3 Journal: "LSBFTW" Daily Driver.
Hello Everyone,
I've been here for a while now and thought I'd start a journal to show where my car stands currently and how it's going to transform as I plan to continue making a few modifications here and there.
Options:
-2003 LSB/Black M3 coupe SMG - 88,000 Miles and going up everyday.
-Premium Package
-Bi Xenons
-Parking distance control
-HK audio
-Alu trim
-OEM alarm
Interior:
-Recaro Pole Position N.G
-OEM Yellow Seat Belts
-Storm-Motorwerks SMG Paddles
-Coby Alcantara 1M thickness w/Yellow center stripe
-V1 Radar
Exterior:
-SGT Scorza CSL Trunk
-Karbonius 1x1 CSL diffuser
-Vorsteiner V2 CF CSL Front Bumper w/Karbonius 1x1 CSL Spliters.
-ECS Gloss Black Front Grill
-Gloss Black side gills
-35% tint
-Vanity plate “LSB FTW”
-Black BMW “M3” license plate frame
-Xpel Ultimate
Suspension:
-TC Kline D/A front, S/A rear hypercoil coilovers with 450 lb front and 500 lb rear springs
-TC Kline Camber plates
-Hotchkis adjustable front tubular sway bar
-Rouge Engineering RTABs
-turner motorsport adjustable rear lower control arms (bushing ends)
-e9X M3 engine mounts
Brakes:
-Brembo GT 4 piston with 380mm Racing Technology Type III rotors.
-Brembo 4 piston rear calipers with 328mm Rear CSL/ZCP Cross-Drilled & Floating Rotor.
-TS20 brake pads.
Wheels/tires:
-RAC RG4s V2. 19”x9” Front, offset is +37. 22.5 lbs front - 19”x10” Rear , offset is +25. 23.0 lbs rear - 245/35/19 front 275/30/19 rear Michelin Pilot Super Sports.
Lighting:
-e9X LED license plate lights
-outer brake light ring enabled
-WeissLicht 78-LEDs Per Ring White Illumination Clear Halo Rings
Breathing (Intake/Exhaust):
-Evolve CSL airbox
-Dinan High Flow Throttle Bodies
-OEM CSL header with Jet Hot Ceramic Coated Painted 2066 Opalescent Blue
-Euro Cats/Section1
-SuperSprint Xpipe Section 2 Non-Resonated.
-Dinan Muffler
ECU:
-CSL DME TTFS Custom Tuned
-TTFS MAP sensor
-Shift lights always on
-Sport mode memory enabled
-Top speed limiter removed
-Dyno limiter removed
-CSL warmup light values
-CSL oil level display enabled
SMG:
-OEM CSL SMG Drive Logic Program.
Navigation:
-Avant 2
-Backup / Reverse Camera
Programmed options:
Light Control Module:
-triple blink turn signals
-Halogen highs on with xenon highs
-fog lights stay on with high beams
-brake force display enabled
-Euro 4-way flash sequence
-side markers disabled (as stock in Europe)
DSC Module:
-M track mode enabled w/cluster M track light
Rear view mirror module:
-save custom reverse mirror aiming location
General Module:
-One touch close rear windows
-remote windows up by holding lock
-trunk open button disabled when car is locked
-car automatically relocks after 2 min if untouched in that time
-windows keep closing when door is opened (including when car is off)
Strengthening:
-updated BMW diff mount bolts
Miscellaneous:
-brake duct cover removal
-Fire Extinguisher (under passenger seat)
-rear window switches modified to be two stage
-clutch fan removed
-engine shrouds removed (unnecessary without clutched fan)
July 2012.
First day with the M3 60,000 miles, My brother and I daily drive E46 M3s.
I have always liked the OEM ZCP/CSL Wheels so i bought a set. This was its first photoshoot.
February 2014.
Then I decided to upgrade to the RAC RG4s V2s. I really like how these wheels look, best part about them is that they are forged and light!.
I also added the SGT Scorza CSL Trunk, it was painted by Metro Auto Rebuild in Seattle. They did an excellent job matching the paint.
May 2014.
OEM CSL/Euro Headers Jet Hot Ceramic Coated Painted 2066 Opalescent Blue.
I love that perfect OEM Fitment!
September 2014.
The Evolve CSL Airbox! The best mod for the S54 in my opinion.
----------------------------------------------------to be continued
Jump to top LSB FTW is offline   Reply With Quote
Old Thu, May-21-2015, 08:33:18 AM   #2
RunwayM
Reputation: 0 RunwayM is on a distinguished road
Default Re: E46 M3 Journal: "LSBFTW" Daily Driver.
Cool build!
Jump to top RunwayM is offline   Reply With Quote
Old Thu, May-21-2015, 08:43:07 AM   #3
eson
eson's Avatar
Reputation: 0 eson is on a distinguished road
Always loved your car. Stoked to see more
Jump to top eson is offline   Reply With Quote
Old Thu, May-21-2015, 08:54:38 AM   #4
juliokoen
juliokoen's Avatar
Reputation: 0 juliokoen is on a distinguished road
Spain
Nice!!!
Jump to top juliokoen is offline   Reply With Quote
Old Thu, May-21-2015, 11:34:29 AM   #5
tonecho
Reputation: 0 tonecho is on a distinguished road
Spain
Muy mola
Jump to top tonecho is offline   Reply With Quote
Old Thu, May-21-2015, 04:57:08 PM   #6
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Reputation: 0 flipm3 is on a distinguished road
WOOHOO!!! About time you started a build journal.
Great progress with the build and can't wait to see what else you do.
2004 E46 M3 6MT | Silver Grey . Cloth | My E46 M3 Build Thread
2009 E90 M3 DCT | Melbourne Red . Speed Cloth | My E90 M3 Build Thread
2002 E46 M3 6MT | Jet Black . Black Nappa | My E46 M3 Build Thread
2016 981 Cayman 6MT | White . Black | Coming Soon
POST YOUR DYNO GRAPH HERE: The Official Dyno Thread
Jump to top flipm3 is offline   Reply With Quote
Old Thu, May-21-2015, 05:40:07 PM   #7
WyattH
About time!! One of the cleanest cars on the board, I'm happy to see this and excited to see where it goes.
Old Thu, May-21-2015, 06:20:29 PM   #8
Beautiful!
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R alpha N Evolve CSL CF Airbox eVenturi Scoop Euro Headers|sect 1 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, May-21-2015, 07:08:56 PM   #9
TheGenius46M
TheGenius46M's Avatar
Love your car man. By far one of my favorite M3's of all time. Keep it up!
2003 E46 M3 TiAg/Cinnamon 6MT
MCS | Recaro | OMP | Hyperco | Besian | AKG | UUC | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Status Gruppe |
Old Thu, May-21-2015, 07:35:07 PM   #10
johnnydeeeee
johnnydeeeee's Avatar
Reputation: 0 johnnydeeeee is on a distinguished road
Beautiful. I love what you've done so far.
E36 M3 Arctic Silver/Black MT SOLD
E46 M3 LSB/Dove MT My Journal
Jump to top johnnydeeeee is offline   Reply With Quote
Discussing E46 M3 Journal: "LSBFTW" Daily Driver. in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
