Old Sat, Sep-13-2014, 05:02:24 PM   #1
skillzo1
skillzo1's Avatar
Reputation: 0 skillzo1 is on a distinguished road
Default Skillzo's Boosted Interlagos Build Thread
DO TO PHOTOBUCKET ISSUES IT IS RECOMMENDED TO VIEW THIS JOURNAL USING TAPATALK
Purchased 6/5/14
2005 M3
Interlagos Blue/Black
6spd manual
76000
Power Seats
Sunroof
NOTES: Previous owner purchased car from Enthusiasts Automotive at around 70000 miles ( have paperwork )
Link to Exhaust dump open video
Car came with
TC Kline Coilovers
SS Brake Lines
SSK Kit
Rogue Engineering stainless cutback
El Diablo Exhuast and down pipe bypass
RavenMotorsports Roll Cage
Race Pedals
AFE Stage 2 Intake
6/15/14
Full Interior and Exterior LED lights installed. Purchased from Led Automive.com
7/7/14
Avin Avant-2 Unit installed with reverse camera ( All wires ran under interior carpet )
8/21/14
Matte Black grill and side gills installed along with smoked corners and IB painted bumper reflectors and IB painted fog light housings
8/23/14
Sundown 8" sub installed in custom box built by bill at AVPRIORITY.com along with Alpine amp.
8/24/14
9/13/04 78080 miles
Full Beisan Unit installed, Inspection 2 completed, Oil change with new gaskets and filter also done. Also Upgraded Cam Bolts installed, with new Upper Chain Guide. ( All Tabs and Cam Bolts in good condition ) Car also coded for Euro Hazards, one touch rear window roll up, Windows close with key fab, both doors unlock with one press of key fab, and Power and automatic windows when doors are open without key.
9/28/14
Received Alcantara Headliner. Purchased from forum member Spookm3
http://www.m3forum.net/m3forum/showthread.php?t=477198
9/30/14 78170 miles
Umnitza V4 Angel Eyes installed
10/2/14 78180 miles
ABS Sensors cleaned ( all 4 )
Changed Diff fluid using OEM SAF-XJ + FM BOOSTER SAE 75W-140 about 2.5 liters
12/15/14
Dropped of car to Maximum Psi for Subframe Reinforcement ( from the bottom and through trunk ) and to also replace whatever bushings is needed.
New Volk Gram Lights Arrived. Thanks Krystian from Race Consulting Agency
Volk Gram Lights 57XTREME SEMI GLOSS BLACK
FRONT - 19X9.5 +25 5-120
REAR - 19x10.5 +25 5-120
1/1/15
Purchased Porsche BBK kit
List of what is included:
Front 996 calipers (already machined 5.5mm) and rear 996 calipers
Front Rally Road Caliper Brackets
Rear "P0lar" Caliper Brackets (proper brackets which do not cause rotor rust ring)
Front and rear Textar pads (rear pads are proper D737 pads which sweep the entire rear rotor - no rust ring)
Rally Road front and rear SS brake lines
Front ZCP Rotors (27.56mm and 27.44mm left, new is 28mm, min is 26.4mm)
Rear ZCP Rotors (19.85mm and 19.89mm left, new is 20mm, min is 18.4mm)
All pins, clips, and anti squeal/noise back pads are included
1/5/14 78200 miles
Car picked up from Maximum Psi. Subframe reinforced from botton and from top of trunk. Replaced guibo, poly subframe bushings, and poly diff bushings. Did not need anything else. Alignment as also done.
*NOTES*
NO Subframe cracks were found on subframe.
Diff was replaced with a used diff with fewer miles. Diff currently has 60000 miles. Car currently has 78200 miles. 18200 miles difference. Added new seals, bushings, and oem diff fluid.
1/17/15
Picked up some more goodies.
Vorsteiner Double Sided Carbon Fiber GTR Hood, Vorsteiner CSL trunk, Vorsteiner CSL diffuser. And some kinda splitters.
3/8/15
Purchased Recaro Sporster Cs Seats, with Bride hardware, and Takata Harness.
4/8/2015
Schroth Quick Snap Harnesses and Pads arrived from Race Consulting Agency ( Krystian ) Driver and Passenger Side.
4/23/15
Planted seats mounts arrived. Driver and Passenger side. Thanks Krystian from Race Consulting Agency
5/9/15
And it has started. All body parts being painted and while im at it basically doing the entire car even though it doesnt need it.
5/11/15
New Avin Avant 2 unit Arrived. Screen issues with previous unit.
6/6/15
Picked up a new shift knob.
6/8/15
Just in from graphxwerkz
6/19/15
Some extended bolts and some Project Kics lug nuts. Thanks Krystian from Race Consulting Agency
6/20/15
Ordered my custom wheel last thursday. It showed up today and i am amazed at how good it came out. I ordered it from Ledermanz on eBay and emailed them for custom work that i wanted done. I was a little hesitant as it was on eBay and overseas but after doing some research, i found feedback everywhere on how good their work it. Not 1 single negative fb on eBay as well. I sent plenty of emails with questions and demands and they replied to everyone of them within a timely manner. It also only took a week to get from overseas to here in NJ. Took 2-3 days to make the make the wheel itself .
I HAVE TO SAY THAT The craftsmanship is OUTSTANDING. ITS PERFECT. The stitching is great all around. It exceeded my expectations in every way. Took a lot of pics to show everyone how good it came out. NO core was needed and it came with the upper and lower trim.
I wanted a flat bottom wheel. Something a little different. I also had them do flat black leather on the left and right side, with perforated black alcantara at the top and bottom. Had that done like that to match my Sportster CS seats, as they are suade and flat black leather. I personally like the feel of the perforated alcantara better then the flat. It Has a 12oclock blue alcantara stripe to match my car. I also had them add extra padding for that nice full feel in your hands. I will be driving with some gloves on, i love the wheel that much.
Here they are. Enjoy, i know i will. I'm right now.
7/17/15
Chasen just sent me a quick pick of the custom rear seat delete he is doing for me. Looks great. Needs to be wrapped now.
Made for a Raven Rollbar, and German Specialties sub box.
UPDATES CONTINUED IN FUTURE JOURNAL POSTS AS I HAVE REACHED THE LIMIT TO THIS POST
CURRENT MOD LIST AS OF 5-13-17
Exterior
•Vorsteiner Double Sided CF Hood
•Vorsteiner CF CSL Trunk
•Euro bumper
•Downforce USA Rear Diffuser
•GTR Vented Rear Bumper
•Autofold Sideview Mirrors
•Lamin-x Tinted OEM LED Tail Lights
•Lamin-x Tinted Headlight Lenses
•Depo Smoked Corner Lights
•Depo Smoked Side Markers
•Umnitza Orion V4 Angel Eyes
•Lightwerkz G5-EX Projectors with Brackets
•///M3 Laser Etched Projector Lenses
•Matte Kidney Gills
•Matte Kidney Grill
•Led in side markers, corner lights, & licensce plate,
•Reverse Camera
•HID Foglights
•Fresh Respray
Interior
•Full Alcantara Headliner
•Custom Alcantara ///M3 Logo Shift Boot by Exact Art
•Custom Alcantara ///M3 Logo Ebrake Boot by Exact Art
•Custom Alcantara ///M3 Logo EBrake Handle by Exact Art
•Ledermanz Steering Wheel
•Piano Black Trim
•M Sport CF Shift Knob
•Recaro Sporster CS Seats
•Dinnman 2x2 CF Sportster Shells
•Bride Floor Mounts W\Sliders
•Schroth Blue Racing Harnesses
•Raven Harness Bar
•Full LED Interior
•Graphix Work Illuninated M3 Door Sills
•Chasen Custom Rear Seat Delete
•RTD Anodized Black Solid Shifter with Custom Ring
•Micky Mouse Guage Pod
•Aem Wideband
•PLX E85 Guage
Sounds
•Avin Avant 2
•Bav Sounds Stage 1
•Custom M3 Sub Enclosure
•Alpine Amp
•Subdown 10” Sub
•Modified ZCP Wheel for Radio Controls*
Engine
•Maximum PSI Stage 2 Turbo Kit W/E85
•Maximum PSI Custom 3.5” Exhuast W/Quad Double Wall Tips & EVC. Tips PCed Black
•Karbonius Custom Vented Carbon Fiber Valve Cover
•Karbonius Carbon Fiber Cabin Filter Cover
•Vibra Tech Motor Mounts
•Vibra Tech Tranny Mounts
•Radium Catch Can
•MP Racing Machined Oil Filter Cap
•ECS Tuning Polished Oil Dip Stick
•Active Autowerkz Fan Clutch
•Turner Pulley Kit
•Turner Fluidyne Radiator
•Samco Hoses
•Stetrab Oil Cooler
•Full Beisan Vanos Upgrade
•Polished Vanos
•WPC Treated OEM Bearings
•RTD DSSR
Differential
•Upgraded to 3.15 Gears 210mm with REM coating
Suspension & Brakes
•TC Kline Coilovers
•TC Kline Camber Plates
•Powerflex Diff Bushings
•Fall Line Motorsports RTAB
•Powerflex CAB
•FCP Adjustable Rear Camber Arms
•BMW Performance Carbon Fiber Strut Bar
•Maximum PSI Subframe Reinforcement Top & Bottom
•DSS Upgraded Axles
•Rotora BBK 6F – 4R PCed Lambo Yellow
Wheels
•Advan GT Rims with Pilot Sport
•Apex Arc-8 Satin Black with Toyo R888
•ZCP with RS3
NOTES-1
•Coolant flush at 80k
•Trans flush at 80k
•New belts at 80k
•New OEM Fan Blade added at 80k
•New OEM Water Pump at 80k
•New OEM Thermostat at 80k
•New brake fluid at 80k
•New MECHANICAL Tensioner added at 80k
NOTES-2
7/25/17 80843 miles
Brand new Competition Twin Disc Clutch installed ( Defective original Comp clutch installed and replaced by max psi under warrenty.
RTD DSSR installed
New OEM Trans Fluid
New Slave Cylinder
New shifter joint and clips for dssr
New Steering Coupler
New Detent Springs (3)
Recharged AC*
Also had allignment and height adjustment done
Apex Arc 8
Front 18x9.5 22 Toyo R888r 255/35/18
Rear 18x10 25 Toyo R888r 275/35/18
Height 13.0 front and back
Camber
Front -2.5
Rear -2.1
Notes -3
40k mile diff swapped in with 3.15 gears at 82395 miles. FM Booster bmw fluid used. Checked all wheel hubs for play all seemed good.
Current 05 IB//BL 6SPD 714RWHP 590TQ
SOLD 05 AW//IR 6SPD
Skillzo's Build...http://www.m3forum.net/m3forum/showthread.php?t=487768
Jump to top skillzo1 is offline   Reply With Quote
Old Sat, Sep-13-2014, 05:31:30 PM   #2
TEASE///M3
TEASE///M3's Avatar
Reputation: 0 TEASE///M3 is on a distinguished road
Default Re: Skillzo's Interlagos Build Thread
Wow that is a clean example, that interlagos
I vote OE grills, and clear corners on IB.
Untitled by . McFarlin, on Flickr
2006 M3 ZCP Interlagos Blue Manual Cinnamon 6MT Slicktop
RIP 2002 M3 Tiag Dove Grey 6MT
Jump to top TEASE///M3 is offline   Reply With Quote
Old Sat, Sep-13-2014, 06:03:14 PM   #3
skillzo1
skillzo1's Avatar
Thanks man I'm trying.
Future mods include
Subframe reinforcment
Replace all bushings
M alcantara Interior
Max Psi stage 2 Turbo Kit
BBK kit
CSL Front Bumper
CSL Trunk
Vented Hood
Paint Respray
SOLD 05 AW//IR 6SPD
Old Thu, Oct-02-2014, 10:05:59 PM   #4
skillzo1
skillzo1's Avatar
Umnitza v4 angel eyes installed.
SOLD 05 AW//IR 6SPD
Old Wed, Oct-22-2014, 10:52:01 PM   #5
skillzo1
skillzo1's Avatar
SOLD 05 AW//IR 6SPD
Old Thu, Oct-23-2014, 02:21:43 AM   #6
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
Very nice bro!
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is online now   Reply With Quote
Old Sat, Oct-25-2014, 03:19:28 PM   #7
ftc3
Reputation: 0 ftc3 is on a distinguished road
Nice job! I'm getting ready to tackle the Besian upgrades myself.
My journal
Dinan Intake | Dinan TBs | Schrick 280/272 | SSV1| SS Res Sec 2 | Dinan Exhaust | Koni Yellow | Dinan Springs | TTFS Tune | 356WHP
Jump to top ftc3 is offline   Reply With Quote
Old Sun, Oct-26-2014, 12:52:23 PM   #8
skillzo1
skillzo1's Avatar
Originally Posted by OneFastSicilian View Post
Very nice bro!
Thanks dude
Its worth it.
SOLD 05 AW//IR 6SPD
Old Sun, Oct-26-2014, 01:59:15 PM   #9
giOsaurus rEx
(╯°_°)╯︵ ┻━┻
giOsaurus rEx's Avatar
Reputation: 0 giOsaurus rEx is on a distinguished road
I like where this is going!
I'm in the IB Cool Kids Club.
Jump to top giOsaurus rEx is offline   Reply With Quote
Old Sun, Nov-02-2014, 06:11:13 PM   #10
skillzo1
skillzo1's Avatar
SOLD 05 AW//IR 6SPD
Discussing Skillzo's Boosted Interlagos Build Thread in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
