Old Thu, Jan-16-2014, 12:22:24 AM   #1
p0lar
Naturally Agitated
p0lar's Avatar
Default Secondary Air Pump (SAP) Delete Howto
This howto will explain the relatively simple procedure of disabling the secondary air pump and its associated DTCs.
The first thing to understand is where to find the configuration values for these variables within your DME. To do this, you MUST know what version your DME is. Please see this thread about how to make that determination.
The next step is to set both K_SLS_UB_MIN and K_SLS_UB_MAX to the same voltage values, sufficiently high enough that they're never reached in any normal circumstance. These values are sequential, thus the offset given is the start of K_SLS_UB_MIN. Another bit that can be set is the K_SLS_OBD. Typically, it is set to 1, which reports the condition via OBD. Setting this to 0 will instruct it to remain quiet.
VersionDME TypeK_SLS_OBD OffsetK_SLS_UB_MIN OffsetOEM Voltage MinOEM Voltage Max
211321000502MSS520x74B40x74B8 9.0 V16.0 V
211321000901MSS520x74B40x74B810.0 V15.0 V
211321001301MSS520x74C40x74C810.0 V15.0 V
211321001401MSS520x74C40x74C810.0 V15.0 V
211321001501MSS520x74C40x74C810.0 V15.0 V
211321001601MSS520x74C40x74C810.0 V15.0 V
211321001701MSS520x74C40x74C810.0 V15.0 V
211322000701MSS540x75060x750A 9.0 V16.0 V
211322000901MSS540x75C60x75CA 9.5 V17.0 V
211322001101MSS540x75E60x75EA 7.0 V17.0 V
211322001301MSS540x75C40x75C8 7.0 V17.0 V
211322001501MSS540x75D40x75D8 9.5 V17.0 V
211322001701MSS540x75D40x75D8 9.5 V17.0 V
211322002101MSS540x75D40x75D8 9.5 V17.0 V
211322002401MSS540x75D40x75D8 9.5 V17.0 V
211322002601MSS540x75D40x75D8 9.5 V17.0 V
211322002801MSS540x75D40x75D8 9.5 V17.0 V
211323001601MSS54HP0xC1000xC104 9.5 V17.0 V
211323001801MSS54HP0xC1000xC104 9.5 V17.0 V
211323001901MSS54HP0xC1000xC104 9.5 V17.0 V
211323002001MSS54HP0xC1000xC104 9.5 V17.0 V
211323002301MSS54HP0xC1000xC104 9.5 V17.0 V
211323002501MSS54HP0xC1000xC104 9.5 V17.0 V
211323002701MSS54HP0xC1000xC104 9.5 V17.0 V
211325000301MSS54HP {csl}0xC1000xC104 9.5 V17.0 V
211325000401MSS54HP {csl}0xC1000xC104 9.5 V17.0 V
Typically, the following code will be seen (E46 M3), the byte in BLUE represents the K_SLS_OBD switch, and the bytes in RED represent the K_SLS_UB_MIN and K_SLS_UB_MAX values respectively:
Code:
01 FF 04 B0 5F AA
Typically, the following code will be seen (E39 M5) with the same colour designations:
Code:
01 FF 04 B0 64 96
To get the voltage value, convert the hexadecimal value to decimal, then divide it by ten, thus, for all commonly found values:
Code:
0x5A =  90 / 10 =  9.0 V
0x5F =  95 / 10 =  9.5 V
0x64 = 100 / 10 = 10.0 V
0x96 = 150 / 10 = 15.0 V
0xA0 = 160 / 10 = 16.0 V
0xAA = 170 / 10 = 17.0 V
To prevent the SAP from starting, simply set these values to a sufficiently-high number. 18.5 V is a popular suggestion from SliM3 and has been confirmed, thus:
Code:
18.5 * 10 = 185 = 0xB9
So, rewrite the string with the following two bytes changed:
Code:
01 FF 04 B0 B9 B9
If you plan to fully disconnect your Secondary Air Pump, you'll also need to delete DTC 0xAA. Please see this thread for information regarding DTC suppression.
In addition to the modification of the K_SLS_UB_MIN and K_SLS_UB_MAX values, the K_SLS_OBD value can also be easily disabled. This is performed by further modifying the string as follows by changing the '01' to '00':
Code:
00 FF 04 B0 B9 B9
For reference, the block-off plate part number is 11121438086, its accompanying gasket is 11727514860.
Old Sat, Jan-18-2014, 03:36:20 PM   #2
aznniche
aznniche's Avatar
Default Re: Secondary Air Pump (SAP) Delete Howto
Will deleting the SAP leave the status in Ready mode for emissions testing?
Jump to top aznniche is online now   Reply With Quote
Old Tue, Feb-18-2014, 08:17:01 PM   #3
ac_2007
ac_2007's Avatar
Reputation: 0 ac_2007 is on a distinguished road
I'm also curious about this.
Jump to top ac_2007 is offline   Reply With Quote
Old Tue, Feb-18-2014, 08:18:42 PM   #4
I think it gets set to "Not Applicable" which should be fine for passing emissions test.
Old Tue, Mar-04-2014, 02:58:03 PM   #5
cossie1
Reputation: 0 cossie1 is on a distinguished road
United Kingdom
Do you (we) have full control over the Secondary Air Pump system ?
The reason for asking is that people seem to like the pops and bangs that you can get during the warmup phase, but are happy to trade this for smoother running when the engine is cold.
However we used to mess with the SAS system on the Evo's and use them to inject air into the manifold on the over run (with very light throttle) and this would give pops and bangs then on the over run pretty much at will.
So was just thinking if you (we) have full control over the SAS, then we could disable during cold start, to get the smoother running and then enable it on the over run if wanted.
Jump to top cossie1 is offline   Reply With Quote
Old Wed, Mar-19-2014, 01:39:41 AM   #6
M3CARBON1
Reputation: 0 M3CARBON1 is on a distinguished road
United Kingdom
Would like to know too..
Jump to top M3CARBON1 is offline   Reply With Quote
Old Fri, Apr-04-2014, 06:49:57 PM   #7
VERTigo
Reputation: 0 VERTigo is on a distinguished road
p0lar, it is as if you read my mind. I am looking to do just this as the Saad Racing catch can installs right where the Secondary Air pump "was".
Saad Racing Stage 3 Turbo + ProEFI & NX Nitrous on E85
Jump to top VERTigo is offline   Reply With Quote
Old Fri, Apr-04-2014, 06:56:09 PM   #8
p0lar
Naturally Agitated
p0lar's Avatar
Nice - this is an ultra-easy modification to perform. Just order the block off plate and gasket, then replace a single string and a single DTC just for good measure and it's done.
Old Sat, Apr-05-2014, 04:10:04 AM   #9
tap
Reputation: 0 tap is on a distinguished road
nice writeup!!!! thanks p0lar!
Jump to top tap is offline   Reply With Quote
Old Sat, Apr-05-2014, 05:54:18 AM   #10
p0lar
Naturally Agitated
p0lar's Avatar
Wish I could take credit for it, but I simply picked info from various threads and amalgamated it into an easy-to-find thread with offsets for about every version.
Nonetheless, I've personally deleted my own SAP with the full block-off plate and it absolutely does NOT throw any codes or interfere with engine operation in any fashion whatsoever.
Discussing Secondary Air Pump (SAP) Delete Howto in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
