Old Wed, Jan-15-2014, 04:57:03 AM   #1
p0lar
Naturally Agitated
p0lar's Avatar
Default 6MT Shift Lights Howto
The E46 M3 is equipped with a sequence of 7 multi-function amber lights that tail the tachometer in a radial pattern from 4500 RPM to 7500 RPM. While the car is warming up, these lights are ordinarily used to indicate engine oil temperature; however, once the oil has reached the monitoring threshold, they become dormant, except on the SMG-equipped cars, where they become shift indicator lights.
The 'shift lights' feature on the E46 M3 was not enabled for manual-transmission cars from the factory, but was enabled for SMG-equipped cars by default. Though it's been explained elsewhere in great detail, this thread is simply the placeholder for the elements required to make the changes for 6MT-equipped cars, as well as a comprehensive list of the shift light location in all MSS54/MSS54HP DME variants.
As usual, the first step is to identify the program version of DME. Once the DME's version has been identified, reference the following table and examine the byte at the proper offset.
VersionDME VariantOffset
211322000701MSS54unavailable
211322000901MSS540x1A01
211322001101MSS540x19FB
211322001301MSS540x1A67
211322001501MSS540x1A7D
211322001701MSS540x1AB3
211322002101MSS540x1AB3
211322002401MSS540x1AB3
211322002601MSS540x1AB3
211322002801MSS540x1AB3
211323001601MSS54HP0x28C9
211323001801MSS54HP0x29CB
211323001901MSS54HP0x29CB
211323002001MSS54HP0x29CB
211323002501MSS54HP0x29CB
211323002701MSS54HP0x29CB
211325000301MSS54HP {csl}0x28CB
211325000401MSS54HP {csl}0x28CB
You should see a string that looks as follows:
Code:
C8 1E 06 00 DA FE
Alternately, you can also search the partial binary for 'C8 1E 06 00'.
----- BEHAVIOUR MODIFICATION -----
If you would like the shift light pattern to illuminate regardless of the sport mode setting, set the byte at the proper offset to '01' as follows:
Code:
C8 1E 06 01 DA FE
If you would only like the shift light pattern to illuminate while in sport mode, set the byte to '02':
Code:
C8 1E 06 02 DA FE
----- ERRATA -----
The shift light display will exhibit erratic behaviour when lowering the rev limits in neutral (either for "flat-foot shifting" or for 6MT "launch control" and may trigger on a shift regardless of in-gear RPM. There is no known workaround to date.
Old Wed, Jan-15-2014, 08:46:57 PM   #2
chriskuta
chriskuta's Avatar
Reputation: 0 chriskuta has disabled reputation
Default Re: 6MT Shift Lights Howto
Must have been under a rock - there is a 6MT launch control? WTF? Off to search
2001 e46, Euro Spec, Manual, OEM CSL Airbox, HP ECU CSL Tune, OEM CSL Wheels
Jump to top chriskuta is offline   Reply With Quote
Old Wed, Jan-15-2014, 09:00:32 PM   #3
p0lar
Naturally Agitated
p0lar's Avatar
It's right there above, just lower the limits on the neutral gear.
I personally find both to be worthless in all situations other than a drag race, which the M3 is notoriously a horrible car to be repurposed for, but to each his own!
Old Thu, Jan-16-2014, 12:06:33 AM   #4
certify
Reputation: 0 certify is on a distinguished road
Malaysia
p0lar, is there a way to modify the binary to make the shift lights to lit up 1000rpm earlier on 3rd, 4th, 5th and 6th gears?
Jump to top certify is offline   Reply With Quote
Old Thu, Jan-16-2014, 12:25:21 AM   #5
p0lar
Naturally Agitated
p0lar's Avatar
Good question, that's probably controlled within the program space, but I bet it's a calculation therein as when I raise my rev limits, the shift lights seem to follow that raise.
Old Thu, Jan-16-2014, 12:52:27 AM   #6
certify
Malaysia
I notice that too about the raising the rev limits. The higher the rev limits the later the rev lights lid up too. But the 1st and 2nd gears the rev lights seems to lid up earlier as compared to 3rd gears onwards and the higher the gears the later the rev lights lid up.
Old Thu, Jan-16-2014, 12:55:05 AM   #7
p0lar
Naturally Agitated
p0lar's Avatar
There's definitely a hysteresis function that governs that, but I'm not aware that it exists in the parameter space. I'll look through it again, but the bits for the lights are pretty confined.
Old Thu, Jan-16-2014, 04:50:33 AM   #8
Bennymic
Reputation: 0 Bennymic is on a distinguished road
Probably based on a predicted time to reach the rev limit. I.e. it lights up at 6500 rpm when in 2nd vice 7250 rpm when in 5h. This is because the rpm's are rising more rapidly in 2nd than they would be in 4th so you need to shift earlier in order not to hit the limiter(assuming shifting takes a constant amount of time). (all those numbers are completely made up)
Jump to top Bennymic is offline   Reply With Quote
Old Thu, Jan-16-2014, 09:29:50 AM   #9
certify
Malaysia
If this can be discovered, it would another new discovery by itself. By then it could be closer to e92 M3 DCT shift lights!
Old Wed, Mar-19-2014, 11:51:43 PM   #10
LakerE46
Reputation: 0 LakerE46 is on a distinguished road
Can you program the shift lights to only come on when sport mode is equipped for a 6 mt car? Leaving them off when sport isn't on
Current:
03.5 Silver Grey on Black E46 M3
Suspension & Braking
GC Race/Track Coilovers + Camber Plates + Rogue RSM
Turner Monoball FCAB / SDW Monoball RTAB
Brembo 355mm GT kit
Apex ARC8 18x9.5 ET 35 square + Michelin PSS 265/35
Engine & Driveline
SGT Headers - Custom rasp pipe - Modified OEM section 3
AutoSolutions 30% SSK - ZHP Knob - CDV Delete - Clutch Stop
ACT LWFW/Organic clutch
Past:
95 Nissan 240SX (S14)
14 Lexus CT200h
06 Range Rover Supercharged
91 Mercedes Benz 420SEL
05 BMW M3 SG/Black 6MT (RIP)
02 Saab 9-5 Aero
01 BMW 325I (RIP)
Jump to top LakerE46 is offline   Reply With Quote
Discussing 6MT Shift Lights Howto in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
