Old Tue, Nov-12-2013, 06:56:28 PM   #1
disapr
Drop a gear and...
Reputation: 0 disapr is on a distinguished road
Default DISAPR 2004 E46 M3 Track Car For Sale (SOLD)
My E46 M3 track car is up for sale.
Some of you may have already seen the build thread(s) for this car - If not, see the links below.
m3forum
http://www.m3forum.net/m3forum/showthread.php?t=434202
Bimmerforums
http://forums.bimmerforums.com/forum...6m-track-build
m3post
http://www.m3post.com/forums/showthread.php?t=800559
Parts/Modifications Section (Detail)
Body
  • Roll cage was fabricated by Lucas Racing - All tubing is 1.750 x .090 Steel, TIG or MIG welded depending on access.
  • Interior paint & body was done by Richey Collision - Metal was etch primed and painted with single stage DuPont Alpine White.
  • BMW CSL Carbon Fiber Roof - This is one of the last OEM BMW CSL Roofs and includes black CSL rails. The roof was bonded using SEM 39747.
  • BMW OE Windshield - New
  • Five Star Bodies Polycarbonate Rear & Quarter Glass - All windows are attached with screws that are tapped/threaded into the body.
  • Five Star Bodies Rear Window Brace w/Custom Mounts
  • Bimmerworld Carbon Fiber Diffuser
  • Bimmerworld Carbon Fiber Headlight Blanks
Engine/Performance
  • Zionsville E46M Competition Cooling Radiator w/SPAL Fan
  • BMW Motorsport Thermostat
  • VAC Billet Racing Oil Filter Housing
  • C&R Racing Remote Filter Housing w/Custom CNC 6061-T6 Aluminum Mount
  • SETRAB Oil Cooler
  • SETRAB Power Steering Cooler
  • GoodRidge PTFE Oil Lines & AN Fittings
  • Turner Solid Aluminum Engine & Gearbox Mounts
  • Bimmerworld Race Exhaust with straight pipe
  • Remote WIX Racing Filter
  • EPIC Race Tune
  • AFE Stage II Intake w/dry filter/new MAF
Suspension
  • MCS 2way Dampers w/Coil-Over Rear
  • Hyperco Coils 650 Front | 375 Rear
  • Hotchkis Sport Sway Bar Set
  • Ground Control Adjustable End Links
  • Turner Solid Aluminum Bushings & Spherical Bearings
  • Ground Control Spherical Rod Ended Control Arms
  • Turner Subframe Reinforcements Front & Rear - The rear subframe is also tied to the cage.
  • Mason Engineering STB
Interior
  • Custom Carbon Fiber Switch Panel
  • Push Button Start w/GTR Start Button
  • STACK Gauges - Oil Pressure, Oil Temp, Water Temp
  • AiM SOLO DL w/CANBUS Connection
  • Custom Carbon Fiber AiM SOLO DL Mount
  • RaceTech 4009WHR Driver Seat & RaceTech 4009W Passenger Seat
  • SCHROTH Profi II-6 HANS Driver & Profi II-6 Passenger
  • CAE Ultra Shifter
  • VAC Seat Mounts
  • WorksBell Quick Release w/Machined/Pinned Steering Shaft
  • Sparco Steering Wheel
  • Mason Engineering Clutch Pedal
  • Turner Pedals
  • BSCI SFI 45.1 Padding
  • 4 Pole Battery Disconnect Switch
  • SPA 4L Mechanical Fire System
General
  • Apex Arc8 Wheels
  • StopTech ST40 Brakes w/Stainless Lines - PFC11 Front pads & PFC01 Rear pads
  • Hoosier R6 Tires
  • Braille Carbon Fiber Battery
  • Braille Battery Mount
  • PAINLESS Stranded Copper Battery Cable w/Monster Terminals
  • Techflex Braided Sleeving
  • Heater Core Delete
  • CDV Delete
  • A/C Delete
  • Parking Brake Delete
  • Emissions Delete
  • Turner Nylon Tow Hooks
  • Turner 90mm Studs
  • Turner Spacers 5mm F 10mm Rear
  • Machined Rear Hubs to Clear Spacer
  • All new control arms, bolts, axles, seals, hoses etc
  • AMB (MyLaps) Transponder - Hardwired
All items listed and the associated accessories are included.
Description
Weight: 2807lbs with a nearly empty fuel tank and no driver.
RWHP: 296 on a DynoJet
This car has been completely disassembled, inspected, cleaned and reassembled with great attention to detail. All bolts, seals, axles, control arms and bearings have been replaced with new OEM BMW components. All suspension bushings have been replaced with Turner solid aluminum bushings or spherical bearings. All systems/components are in perfect working order with zero issues.
During the build, all fluids were changed including: Engine (Castrol TWS 10w60), Transmission (Pentosin MTF2), Brake System (Castrol SRF) and Differential (BMW Motorsport 75W-140). Since the initial build, all usage has been logged and fluids have been regularly changed.
All engine maintenance items have been addressed – The VANOS system has been inspected and no issues were found. The VANOS filter has been changed, timing chain tensioner has been replaced and engine valves have been adjusted. The engine has new spark plugs, accessory belt, coolant/power steering hoses and new throttle position sensors and MAF sensor among other items.
The engine and drive train have 74k miles. All other wear related items have been replaced and have approximately 2k miles.
Since completing the build, the car has done 8 track days and one NASA TT3 race, placing second both days against a very capable advasary. The Hoosier R6 tires and brake pads only have 8 short TT sessions on them from the race in September.
Everything was throroughly tested and fine tuned over the summer, performing flawlessly at NASA. The car is dialed in and very forgiving to drive - for those of you that are familiar with Texas World Speedway, my best lap from the NASA TT race was 1.52 CCW on R6's with no aero.
This car meets all rules for NASA GTS and TT3, and was specifically built to race GTS3/4. I have most receipts for large items and can provide full documentation on the usage and maintenance.
Obligatory “Why are you selling it?” - Focusing on new goals and opportunities.
SOLD, thanks!
Pictures
Larger photos can be found on my Flickr site
Thanks for looking
Jump to top disapr is offline   Reply With Quote
Old Tue, Nov-12-2013, 07:50:54 PM   #2
M3roar
Got Jesus?
Reputation: 0 M3roar is on a distinguished road
Default Re: DISAPR E46M Track Car For Sale
One of the saddest days ever! Such a work of art! OCD work at its best!
Good luck with the sale! Wish I could snatch it!
GOT JESUS?
Jump to top M3roar is offline   Reply With Quote
Old Tue, Nov-12-2013, 07:53:16 PM   #3
Vox Populi
Vox Populi's Avatar
Reputation: 0 Vox Populi is on a distinguished road
UGHHHHHH so much want!!!
Seriously, amazing car. Wish you the best of luck with the sale.
Build Thread
Jump to top Vox Populi is offline   Reply With Quote
Old Tue, Nov-12-2013, 07:56:05 PM   #4
AP3X_FTW
Visor Down For Business
AP3X_FTW's Avatar
Reputation: 0 AP3X_FTW is on a distinguished road
I don't believe my eyes. Ive really enjoyed reading through your build thread, thanks for the inspiration. The next owner is a very lucky man.
My all time favorite e46 M3.
E92 M3
E70 X5 M Sport
i3 RE
Jump to top AP3X_FTW is offline   Reply With Quote
Old Tue, Nov-12-2013, 08:09:55 PM   #5
M3ANMACHINE
@coleslawjay
M3ANMACHINE's Avatar
Default DISAPR E46M Track Car For Sale
Wow! Can't believe it!
2011 E90///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
APEX | BIMMERWORLD | COBY WHEEL | CORSA | H&R | MACHT SCHNELL | PEDALHAUS | RECARO
2014 F15 X5 | Space Grey | M-Sport
Old Tue, Nov-12-2013, 08:28:37 PM   #6
dmw16
Reputation: 0 dmw16 is on a distinguished road
I know it's been said, but I just can't believe it. This is my all time favorite M3. Best of luck!
Jump to top dmw16 is offline   Reply With Quote
Old Tue, Nov-12-2013, 11:41:54 PM   #7
ThunderMoose
This car is absolutely incredible. I have had the opportunity to view the car up close in the track paddock and from behind after pointing it by on the track.
I have never seen a car so well cared for down to the tiniest level. The OP has not taken any shortcuts in building this car. Everything is top of the line and well put together.
The car, as mentioned, finished 2nd in TT3 on both days in its first TT outing. The first place that winner happened to be the TT3 Nationals 3rd place finisher, who not only has more horsepower but has extensive aero mods and owns national motorsports shop.
Long story short, the car is quick and ready to go. The craftsmanship behind the build is second to none.
Old Tue, Nov-12-2013, 11:46:33 PM   #8
dubledee
Petrolhead
dubledee's Avatar
Reputation: 0 dubledee is on a distinguished road
Viet Nam
Good luck with your sale. Such an amazing build, your journal was a pleasure to read.
04 SG M3 6MT slicktop | 96 Guards Red 911
AKG | APEX | BMW Motorsports | Bimmerworld | Brembo |Eibach | Eisenmann |GC | Karbonius | Kirk | Macht Schnell | Moton | Pagid | Powerflex | PFC | Recaro | RE | Schroth | SS |TC Design | TMS
Jump to top dubledee is offline   Reply With Quote
Old Wed, Nov-13-2013, 12:39:15 AM   #9
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
Amazing m3 build, sir. Truly something to aspire. Best of luck with the sale
Sent from MI6
2005 Carbon Black Metallic ///M3 SOLD
My Journal
2012 Porsche Cayman R
Jump to top ///M_Achilles is offline   Reply With Quote
Old Wed, Nov-13-2013, 03:07:09 AM   #10
brakelate
2004 Imola M3, 2017 Alpine White M2 Performance Edition
brakelate's Avatar
Reputation: 0 brakelate is on a distinguished road
Very impressive build. Hope the new owner will be local so we can see it at the local tracks.
Getting close to the holidays so you might have better luck posting up in the spring.
GL with you future endeavors!
04 Imola/black 6spd/No sunroof
Supersprint/CSL airbox/ Schricks/TTFS/Bimmerworld Race/Moton CS/Blanton LSD/Stoptech/Performance Friction ZR/Recaros
Need more seat time!
Jump to top brakelate is offline   Reply With Quote
Discussing DISAPR E46M Track Car For Sale in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
