Old Fri, Oct-11-2013, 01:22:01 PM   #1
p0lar
Naturally Agitated
p0lar's Avatar
Default DTC (OBD Error Code) Deletion/Removal Strategy
There are two main methods by which DTCs (Diagnostic Trouble Codes) are commonly suppressed within the MSS50/MSS52/MSS54/MSS54HP, and several alternative methods.
Let's start by learning how to identify a DTC string within the DME. A firm understanding of the DTC errors and their respective codes themselves will be of great assistance. NikolaiD has posted an excellent reference/list that can be located here.
Once you have an idea of which DTC you'd like to suppress, it's also important to understand the actual binary string within the DME that represents the particular DTC in question. These strings are not located in the same position in all binaries, so a table has been provided below with each version, DTC and respective offset.
The string is 14 bytes long, and generally starts with the hexadecimal DTC code itself, and finishes with a 'FF' terminator. For example, if we look at NikolaiD's chart, we can find that code 170 (0xAA), 'Minimum flow of secondary air', which is most commonly associated with the secondary air pump delete, has a hex code of 'AA'. Thus, within a sample 211323002501JD79 MSS54HP DME binary, we find a 14-byte string at offset 0xE3BE representing that particular DTC:
Code:
AA 01 01 01 01 01 01 00 01 02 03 28 27 FF
METHOD 1:
The first method to suppress a DTC, and coincidentally also the easiest, requires only a simple modification of the DTC string by replacing the 13th byte with '00':
Code:
AA 01 01 01 01 01 01 00 01 02 03 28 00 FF
METHOD 2:
The second method is to actually zero out the entire 14-byte string:
Code:
00 00 00 00 00 00 00 00 00 00 00 00 00 00
METHOD 3 (untested):
The third method is to perform a hybridization of the previous two by zeroing out the first and 13th bytes of the 14-byte string:
Code:
00 01 01 01 01 01 01 00 01 02 03 28 00 FF
METHOD 4 :
The fourth method is to substitute the following string for the entirety of the original string, exactly as has been done within other OEM binaries for OEM suppressed codes:
Code:
00 28 28 03 02 03 02 00 01 02 03 28 00 FF
Regardless of which method you employ, the DME's errors must be cleared after reflashing the DME with the updated binary.
Note that the important byte (suffix) immediately preceding the 'FF' cap has been observed to be only one of the following 13 codes, possibly dealing with the grouping of function:
suffixfunction group
0x00disabled
0x01enabled/general
0x02enabled/?
0x03enabled/?
0x05enabled/?
0x09enabled/CAN External to DME
0x23enabled/CAN?
0x25enabled/sensor
0x27enabled/general
0x2Denabled/DME Internal
0x2Fenabled/EGAS
0x34enabled/EWS, immobilizer
0xA5enabled/misfire
There are generally two 128-byte groupings of DTCs in each section of the 32kb or 64kb binary parameter space, at the locations defined below, and always preceded by the following binary string:
Code:
00 01 01 01 14 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
Except in the case of 0701, which uses the following code to demarcate the DTC code positions:
Code:
00 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
In the case of both strings, the following four characteristics are defined:
  • K_ED_CONTROL = bytes 0,1 (00 00 = disabled, 00 01 = enabled)
  • K_FSP_CONCEPT = byte 2 (0 = set environment condition, 1 = set special condition?, other = 'illegally masqed')
  • K_FSP_TIMER = byte 3 (0 = by duration of engine operation, 1 = by mileage, other = 'illegally masqed')
  • K_DS2_VMAX = byte 4 (RPM)
However, in the string located in the master segment, the remainder are purposed:
  • K_MIL_CONTROL = byte 8 (enabled/disabled)
  • K_MIL_PERIODE = byte 9 (x100 in ms)
  • K_DCY_N_MIN = bytes 10,11 (RPM)
  • K_DCY_DELAY = byte 12 (seconds)
  • K_TMOT_OBD_WARM = byte 13 (temperature in C)
The locations by version of all DTC strings, which account for ~5.4% of the total volume of MSS54HP data and ~10.8% of the total volume of MSS54/MSS52 data:
VersionDME VariantSlave OffsetMaster Offset
211321000502MSS520x38B20x7812
211321000901MSS520x38B20x7812
211321001301MSS520x38B40x7814
211321001401MSS520x38B40x7814
211321001501MSS520x38B40x7814
211321001601MSS520x38B40x7814
211321001701MSS520x38B40x7814
211322000701MSS540x38B20x7812
211322000901MSS540x38B40x7814
211322001101MSS540x38B40x7814
211322001301MSS540x38B40x7814
211322001501MSS540x38B40x7814
211322001701MSS540x38B40x7814
211322002101MSS540x38B40x7814
211322002401MSS540x38B40x7814
211322002601MSS540x38B40x7814
211322002801MSS540x38B40x7814
211323001601MSS54HP0x60140xE014
211323001801MSS54HP0x61140xE014
211323001901MSS54HP0x61140xE014
211323002001MSS54HP0x61140xE014
211323002501MSS54HP0x61140xE014
211323002701MSS54HP0x61140xE014
211325000301MSS54HP {csl}0x60140xF014
211325000401MSS54HP {csl}0x60140xF014
All DTC Info from (almost) every unmodified version I own.
Comprehensive MSS54/MSS54HP DTC Offset Information
dtc (dec)0301/040107010901/1101/1301/1501/1701/2101/2401/2601/280116011801/1901/2001/2501/2701
0x00 (0)0x66880x3F260x3F280x66880x6788
0x00 (0)0x66960x3F340x3F360x66960x6796
0x00 (0)0x66A40x3F420x3F440x66A40x67A4
0x00 (0)0x66B20x3F500x3F520x66B20x67B2
0x00 (0)0x66C00x3F5E0x3F600x66C00x67C0
0x00 (0)0xF5EE0x7DEC0x7DEE0xE5EE0xE5EE
0x00 (0)0xF5FC0x7DFA0x7DFC0xE5FC0xE5FC
0x00 (0)0xF60A0x7E080x7E0A0xE60A0xE60A
0x00 (0)0xF6180x7E160x7E180xE6180xE618
0x00 (0)0xF6340x7E320x7E340xE6340xE634
0x00 (0)0xF6420x7E400x7E420xE6420xE642
0x00 (0)0xF6500x7E4E0x7E500xE6500xE650
0x01 (1)0x60760x39140x39160x60760x6176
0x02 (2)0xF0920x78900x78920xE0920xE092
0x03 (3)0x61D40x3A720x3A740x61D40x62D4
0x04 (4)0x61F00x3A8E0x3A900x61F00x62F0
0x05 (5)0x61E20x3A800x3A820x61E20x62E2
0x06 (6)0x61B80x3A560x3A580x61B80x62B8
0x07 (7)0x61100x39AE0x39B00x61100x6210
0x08 (8)0xF2980x7A960x7A980xE2980xE298
0x09 (9)0xF0D80x78D60x78D80xE0D80xE0D8
0x0A (10)0x611E0x39BC0x39BE0x611E0x621E
0x0B (11)0xF2A60x7AA40x7AA60xE2A60xE2A6
0x0C (12)0x60BC0x395A0x395C0x60BC0x61BC
0x0D (13)0x60AE0x394C0x394E0x60AE0x61AE
0x0E (14)0xF11E0x791C0x791E0xE11E0xE11E
0x0F (15)0x65FC0x3E9A0x3E9C0x65FC0x66FC
0x10 (16)0x60300x38CE0x38D00x60300x6130
0x11 (17)0x660A0x3EA80x3EAA0x660A0x670A
0x12 (18)0x62EC0x3B8A0x3B8C0x62EC0x63EC
0x13 (19)0xF3A20x7BA00x7BA20xE3A20xE3A2
0x14 (20)0xF1F00x79EE0x79F00xE1F00xE1F0
0x15 (21)0x61560x39F40x39F60x61560x6256
0x16 (22)0x61480x39E60x39E80x61480x6248
0x17 (23)0x64120x3CB00x3CB20x64120x6512
0x18 (24)0x64200x3CBE0x3CC00x64200x6520
0x19 (25)0x64040x3CA20x3CA40x64040x6504
0x1A (26)0x64660x3D040x3D060x64660x6566
0x1B (27)0x62600x3AFE0x3B000x62600x6360
0x1C (28)0x62DE0x3B7C0x3B7E0x62DE0x63DE
0x1D (29)0xF0A00x789E0x78A00xE0A00xE0A0
0x1E (30)0x60680x39060x39080x60680x6168
0x1F (31)0x620C0x3AAA0x3AAC0x620C0x630C
0x20 (32)0x621A0x3AB80x3ABA0x621A0x631A
0x21 (33)0x61FE0x3A9C0x3A9E0x61FE0x62FE
0x22 (34)0x62280x3AC60x3AC80x62280x6328
0x23 (35)0x62360x3AD40x3AD60x62360x6336
0x24 (36)0x60CA0x39680x396A0x60CA0x61CA
0x25 (37)0x63160x3BB40x3BB60x63160x6416
0x26 (38)0x63240x3BC20x3BC40x63240x6424
0x27 (39)0x63320x3BD00x3BD20x63320x6432
0x28 (40)0x63400x3BDE0x3BE00x63400x6440
0x29 (41)0xF2600x7A5E0x7A600xE2600xE260
0x2A (42)0xF1100x790E0x79100xE1100xE110
0x2B (43)0x605A0x38F80x38FA0x605A0x615A
0x2C (44)0xF52A0x7D280x7D2A0xE52A0xE52A
0x2D (45)0xF51C0x7D1A0x7D1C0xE51C0xE51C
0x2E (46)0x619C0x3A3A0x3A3C0x619C0x629C
0x2F (47)0x61AA0x3A480x3A4A0x61AA0x62AA
0x30 (48)0xF2520x7A500x7A520xE2520xE252
0x31 (49)0xF5380x7D360x7D380xE5380xE538
0x32 (50)0x642E0x3CCC0x3CCE0x642E0x652E
0x33 (51)0x644A0x3CE80x3CEA0x644A0x654A
0x34 (52)0x643C0x3CDA0x3CDC0x643C0x653C
0x35 (53)0x60140x38B20x38B40x60140x6114
0x36 (54)0x60920x39300x39320x60920x6192
0x37 (55)0x64580x3CF60x3CF80x64580x6558
0x38 (56)0xF5460x7D440x7D460xE5460xE546
0x39 (57)0xF26E0x7A6C0x7A6E0xE26E0xE26E
0x3A (58)0xF2360x7A340x7A360xE2360xE236
0x3B (59)0xF2440x7A420x7A440xE2440xE244
0x3C (60)0xF4F20x7CF00x7CF20xE4F20xE4F2
0x3D (61)0xF5000x7CFE0x7D000xE5000xE500
0x3E (62)0xF5540x7D520x7D540xE5540xE554
0x3F (63)0xF3B00x7BAE0x7BB00xE3B00xE3B0
0x40 (64)0xF5620x7D600x7D620xE5620xE562
0x41 (65)0x60D80x39760x39780x60D80x61D8
0x42 (66)0x61C60x3A640x3A660x61C60x62C6
0x43 (67)0x612C0x39CA0x39CC0x612C0x622C
0x44 (68)0x66180x3EB60x3EB80x66180x6718
0x45 (69)0xF0F40x78F20x78F40xE0F40xE0F4
0x46 (70)0xF0E60x78E40x78E60xE0E60xE0E6
0x47 (71)0xF1020x79000x79020xE1020xE102
0x48 (72)0x613A0x39D80x39DA0x613A0x623A
0x49 (73)0xF21A0x7A180x7A1A0xE21A0xE21A
0x4A (74)0xF2B40x7AB20x7AB40xE2B40xE2B4
0x4B (75)0xF2C20x7AC00x7AC20xE2C20xE2C2
0x4C (76)0xF1D40x79D20x79D40xE1D40xE1D4
0x4D (77)0xF1FE0x79FC0x79FE0xE1FE0xE1FE
0x4E (78)0xF20C0x7A0A0x7A0C0xE20C0xE20C
0x4F (79)0xF1560x79540x79560xE1560xE156
0x50 (80)0x62440x3AE20x3AE40x62440x6344
0x51 (81)0xF2FA0x7AF80x7AFA0xE2FA0xE2FA
0x52 (82)0xF3DA0x7BD80x7BDA0xE3DA0xE3DA
0x53 (83)0xF2D00x7ACE0x7AD00xE2D00xE2D0
0x54 (84)0xF2DE0x7ADC0x7ADE0xE2DE0xE2DE
0x55 (85)0xF50E0x7D0C0x7D0E0xE50E0xE50E
0x56 (86)0xF13A0x79380x793A0xE13A0xE13A
0x57 (87)0x62FA0x3B980x3B9A0x62FA0x63FA
0x58 (88)0x63080x3BA60x3BA80x63080x6408
0x59 (89)0x66260x3EC40x3EC60x66260x6726
0x5A (90)0x635C0x3BFA0x3BFC0x635C0x645C
0x5B (91)0x636A0x3C080x3C0A0x636A0x646A
0x5C (92)0x63780x3C160x3C180x63780x6478
0x5D (93)0x63860x3C240x3C260x63860x6486
0x5E (94)0x66340x3ED20x3ED40x66340x6734
0x5F (95)0x66420x3EE00x3EE20x66420x6742
0x60 (96)0x66500x3EEE0x3EF00x66500x6750
0x61 (97)0x665E0x3EFC0x3EFE0x665E0x675E
0x62 (98)0x666C0x3F0A0x3F0C0x666C0x676C
0x63 (99)0xF6260x7E240x7E260xE6260xE626
0x64 (100)0x63B00x3C4E0x3C500x63B00x64B0
0x65 (101)0x63BE0x3C5C0x3C5E0x63BE0x64BE
0x66 (102)0x63CC0x3C6A0x3C6C0x63CC0x64CC
0x67 (103)0x63DA0x3C780x3C7A0x63DA0x64DA
0x68 (104)0xF4BA0x7CB80x7CBA0xE4BA0xE4BA
0x69 (105)0xF0840x78820x78840xE0840xE084
0x6A (106)0xF0CA0x78C80x78CA0xE0CA0xE0CA
0x6B (107)0xF2280x7A260x7A280xE2280xE228
0x6C (108)0xF27C0x7A7A0x7A7C0xE27C0xE27C
0x6D (109)0xF28A0x7A880x7A8A0xE28A0xE28A
0x6E (110)0x61800x3A1E0x3A200x61800x6280
0x6F (111)0xF3080x7B060x7B080xE3080xE308
0x70 (112)0xF3160x7B140x7B160xE3160xE316
0x71 (113)0xF3240x7B220x7B240xE3240xE324
0x72 (114)0xF3320x7B300x7B320xE3320xE332
0x73 (115)0xF3400x7B3E0x7B400xE3400xE340
0x74 (116)0xF34E0x7B4C0x7B4E0xE34E0xE34E
0x75 (117)0xF35C0x7B5A0x7B5C0xE35C0xE35C
0x76 (118)0xF36A0x7B680x7B6A0xE36A0xE36A
0x77 (119)0xF3780x7B760x7B780xE3780xE378
0x78 (120)0xF3860x7B840x7B860xE3860xE386
0x79 (121)0xF3940x7B920x7B940xE3940xE394
0x7A (122)0x60840x39220x39240x60840x6184
0x7B (123)0x61020x39A00x39A20x61020x6202
0x7C (124)0x61640x3A020x3A040x61640x6264
0x7D (125)0x61720x3A100x3A120x61720x6272
0x7E (126)0x60A00x393E0x39400x60A00x61A0
0x7F (127)0x618E0x3A2C0x3A2E0x618E0x628E
0x80 (128)0xF3F60x7BF40x7BF60xE3F60xE3F6
0x81 (129)0xF4040x7C020x7C040xE4040xE404
0x82 (130)0x60220x38C00x38C20x60220x6122
0x83 (131)0xF0140x78120x78140xE0140xE014
0x84 (132)0xF0220x78200x78220xE0220xE022
0x85 (133)0xF0300x782E0x78300xE0300xE030
0x86 (134)0xF03E0x783C0x783E0xE03E0xE03E
0x87 (135)0xF04C0x784A0x784C0xE04C0xE04C
0x88 (136)0xF1480x79460x79480xE1480xE148
0x89 (137)0xF1640x79620x79640xE1640xE164
0x8A (138)0xF1720x79700x79720xE1720xE172
0x8B (139)0xF1800x797E0x79800xE1800xE180
0x8C (140)0xF18E0x798C0x798E0xE18E0xE18E
0x8D (141)0xF05A0x78580x785A0xE05A0xE05A
0x8E (142)0xF0680x78660x78680xE0680xE068
0x8F (143)0xF0760x78740x78760xE0760xE076
0x90 (144)0x60E60x39840x39860x60E60x61E6
0x91 (145)0x60F40x39920x39940x60F40x61F4
0x92 (146)0xF5C40x7DC20x7DC40xE5C40xE5C4
0x93 (147)0xF5D20x7DD00x7DD20xE5D20xE5D2
0x94 (148)0xF5E00x7DDE0x7DE00xE5E00xE5E0
0x95 (149)0x65EE0x3E8C0x3E8E0x65EE0x66EE
0x96 (150)0xF0BC0x78BA0x78BC0xE0BC0xE0BC
0x97 (151)0x634E0x3BEC0x3BEE0x634E0x644E
0x98 (152)0xF12C0x792A0x792C0xE12C0xE12C
0x99 (153)0xF4C80x7CC60x7CC80xE4C80xE4C8
0x9A (154)0xF4D60x7CD40x7CD60xE4D60xE4D6
0x9B (155)0xF0AE0x78AC0x78AE0xE0AE0xE0AE
0x9C (156)0x603E0x38DC0x38DE0x603E0x613E
0x9D (157)0x604C0x38EA0x38EC0x604C0x614C
0x9E (158)0x62520x3AF00x3AF20x62520x6352
0x9F (159)0xF19C0x799A0x799C0xE19C0xE19C
0xA0 (160)0xF1AA0x79A80x79AA0xE1AA0xE1AA
0xA1 (161)0xF1B80x79B60x79B80xE1B80xE1B8
0xA2 (162)0xF1C60x79C40x79C60xE1C60xE1C6
0xA3 (163)0xF1E20x79E00x79E20xE1E20xE1E2
0xA4 (164)0xF5700x7D6E0x7D700xE5700xE570
0xA5 (165)0xF57E0x7D7C0x7D7E0xE57E0xE57E
0xA6 (166)0xF58C0x7D8A0x7D8C0xE58C0xE58C
0xA7 (167)0xF59A0x7D980x7D9A0xE59A0xE59A
0xA8 (168)0xF5A80x7DA60x7DA80xE5A80xE5A8
0xA9 (169)0xF5B60x7DB40x7DB60xE5B60xE5B6
0xAA (170)0xF3BE0x7BBC0x7BBE0xE3BE0xE3BE
0xAB (171)0xF3CC0x7BCA0x7BCC0xE3CC0xE3CC
0xAC (172)0xF2EC0x7AEA0x7AEC0xE2EC0xE2EC
0xAD (173)0xF3E80x7BE60x7BE80xE3E80xE3E8
0xAE (174)0x626E0x3B0C0x3B0E0x626E0x636E
0xAF (175)0x627C0x3B1A0x3B1C0x627C0x637C
0xB0 (176)0x628A0x3B280x3B2A0x628A0x638A
0xB1 (177)0x62980x3B360x3B380x62980x6398
0xB2 (178)0x62A60x3B440x3B460x62A60x63A6
0xB3 (179)0x62B40x3B520x3B540x62B40x63B4
0xB4 (180)0x62C20x3B600x3B620x62C20x63C2
0xB5 (181)0x62D00x3B6E0x3B700x62D00x63D0
0xB6 (182)0x63940x3C320x3C340x63940x6494
0xB7 (183)0x63A20x3C400x3C420x63A20x64A2
0xB8 (184)0x63E80x3C860x3C880x63E80x64E8
0xB9 (185)0x63F60x3C940x3C960x63F60x64F6
0xBA (186)0xF6960x7E940x7E960xE6960xE696
0xBB (187)0xF6A40x7EA20x7EA40xE6A40xE6A4
0xBC (188)0xF6B20x7EB00x7EB20xE6B20xE6B2
0xBD (189)0xF6C00x7EBE0x7EC00xE6C00xE6C0
0xBE (190)0xF6CE0x7ECC0x7ECE0xE6CE0xE6CE
0xBF (191)0xF6DC0x7EDA0x7EDC0xE6DC0xE6DC
0xC0 (192)0xF6EA0x7EE80x7EEA0xE6EA0xE6EA
0xC1 (193)0xF6F80x7EF60x7EF80xE6F80xE6F8
0xC2 (194)0x64740x3D120x3D140x64740x6574
0xC3 (195)0xF49E0x7C9C0x7C9E0xE49E0xE49E
0xC4 (196)0x64900x3D2E0x3D300x64900x6590
0xC5 (197)0x649E0x3D3C0x3D3E0x649E0x659E
0xC6 (198)0x64AC0x3D4A0x3D4C0x64AC0x65AC
0xC7 (199)0x64BA0x3D580x3D5A0x64BA0x65BA
0xC8 (200)0x64C80x3D660x3D680x64C80x65C8
0xC9 (201)0x64D60x3D740x3D760x64D60x65D6
0xCA (202)0x64E40x3D820x3D840x64E40x65E4
0xCB (203)0x64F20x3D900x3D920x64F20x65F2
0xCC (204)0x65000x3D9E0x3DA00x65000x6600
0xCD (205)0x650E0x3DAC0x3DAE0x650E0x660E
0xCE (206)0x651C0x3DBA0x3DBC0x651C0x661C
0xCF (207)0x652A0x3DC80x3DCA0x652A0x662A
0xD0 (208)0x65380x3DD60x3DD80x65380x6638
0xD1 (209)0x65460x3DE40x3DE60x65460x6646
0xD2 (210)0x65540x3DF20x3DF40x65540x6654
0xD3 (211)0x65620x3E000x3E020x65620x6662
0xD4 (212)0x65700x3E0E0x3E100x65700x6670
0xD5 (213)0x657E0x3E1C0x3E1E0x657E0x667E
0xD6 (214)0x658C0x3E2A0x3E2C0x658C0x668C
0xD7 (215)0x659A0x3E380x3E3A0x659A0x669A
0xD8 (216)0x65A80x3E460x3E480x65A80x66A8
0xD9 (217)0x65B60x3E540x3E560x65B60x66B6
0xDA (218)0x65C40x3E620x3E640x65C40x66C4
0xDB (219)0x65D20x3E700x3E720x65D20x66D2
0xDC (220)0x65E00x3E7E0x3E800x65E00x66E0
0xDD (221)0xF4E40x7CE20x7CE40xE4E40xE4E4
0xDE (222)0xF4120x7C100x7C120xE4120xE412
0xDF (223)0xF4200x7C1E0x7C200xE4200xE420
0xE0 (224)0xF42E0x7C2C0x7C2E0xE42E0xE42E
0xE1 (225)0xF43C0x7C3A0x7C3C0xE43C0xE43C
0xE2 (226)0xF44A0x7C480x7C4A0xE44A0xE44A
0xE3 (227)0xF4580x7C560x7C580xE4580xE458
0xE4 (228)0xF4660x7C640x7C660xE4660xE466
0xE5 (229)0xF4740x7C720x7C740xE4740xE474
0xE6 (230)0xF4820x7C800x7C820xE4820xE482
0xE7 (231)0xF4900x7C8E0x7C900xE4900xE490
0xE8 (232)0x64820x3D200x3D220x64820x6582
0xE9 (233)0xF4AC0x7CAA0x7CAC0xE4AC0xE4AC
0xF7 (247)0x667A0x3F180x3F1A0x667A0x677A
0xF8 (248)0x66CE0x3F6C0x3F6E0x66CE0x67CE
0xF9 (249)0x66DC0x3F7A0x3F7C0x66DC0x67DC
0xFA (250)0x66EA0x3F880x3F8A0x66EA0x67EA
0xFB (251)0x66F80x3F960x3F980x66F80x67F8
0xFC (252)0xF65E0x7E5C0x7E5E0xE65E0xE65E
0xFD (253)0xF66C0x7E6A0x7E6C0xE66C0xE66C
0xFE (254)0xF67A0x7E780x7E7A0xE67A0xE67A
0xFF (255)0xF6880x7E860x7E880xE6880xE688
Old Fri, Oct-11-2013, 01:22:24 PM   #2
p0lar
Naturally Agitated
p0lar's Avatar
Default Re: DTC (OBD Error Code) Deletion/Removal Strategy
Unique DTCs across all MSS54/MSS54HP Versions:
DTC (hex)DTC (dec)DTC Suffix (hex)DTC Suffix (dec)DTC String
0x0000x00000282803020302000102032800FF
0x0110x03301282806060606000102032803FF
0x0220x273902C8C805020205000102032827FF
0x0330x273903282804010104000102032827FF
0x0440x273904282804010104000102032827FF
0x0550x273905282804010104000102032827FF
0x0660x00006010A0101010A000102032800FF
0x0660x00006282803020302000102032800FF
0x0660x01106010A0101010A000102032801FF
0x0660x01106282803020302000102032801FF
0x0660x233506010A0101010A000102032823FF
0x0770x273907282803020302001102032827FF
0x0880x00008282803020302001102032800FF
0x0990x01109102002010102000102032801FF
0x0A100x27390A282803020302001102032827FF
0x0B110x0000B282803020302001102032800FF
0x0B110x0110B282803020302001102032801FF
0x0C120x25370C28FA0301011400011D032825FF
0x0D130x25370D28FA0301011400011C032825FF
0x0E140x0000E2828030202030A0402032800FF
0x0E140x0330E2828030202030A0402032803FF
0x0F150x25370FC8C804010104000108092825FF
0x10160x273910282804010104000102032827FF
0x10160x273910282808010108000102032827FF
0x11170x00011141403020302000102033200FF
0x11170x01111141403020302000102033201FF
0x11170x0111114140302030200011A1B2801FF
0x12180x00012282802010102000102032800FF
0x12180x01112282801010101030A0B142801FF
0x13190x273913285002010102000102032827FF
0x14200x00014282802010102000102032800FF
0x15210x2739152828030A030A001102032827FF
0x16220x2739162828030A030A001102032827FF
0x17230x01117281404020204000111032801FF
0x18240x01118281404020204000111032801FF
0x19250x01119281404020204000111032801FF
0x1A260x0001A281404020204000111032800FF
0x1B270x0001B060601010101000A05032800FF
0x1B270x27391B060601010101000A05032827FF
0x1C280x0001C282802010102000C02032800FF
0x1C280x0331C0A280101010113140A0B2803FF
0x1D290x27391DC8C805020205000102032827FF
0x1E300x2D451E01010101010100010203282DFF
0x1F310x27391F282804010104000102032827FF
0x20320x273920282804010104000102032827FF
0x21330x273921282804010104000102032827FF
0x22340x00022282804010104000102032800FF
0x23350x00023282804010104000102032800FF
0x24360x273924282803020203000119352827FF
0x25370x273925502802020203000120032827FF
0x25370x273925502803020203000120032827FF
0x26380x273926502802020203000121032827FF
0x26380x273926502803020203000121032827FF
0x27390x03327502803020203000122032803FF
0x27390x273927502803020203000122032827FF
0x28400x03328502803020203000123032803FF
0x28400x273928502803020203000123032827FF
0x29410x253729A0A004010104000112032825FF
0x2A420x0112AC82801010201000104032801FF
0x2B430x0002B282802010102001802032800FF
0x2B430x0112B282802010102001802032801FF
0x2B430x25372B282802010102001802032825FF
0x2C440x0112C3C3C04010104000102122801FF
0x2D450x0992D282802010102000102032809FF
0x2D450x2D452D28280201010200010203282DFF
0x2E460x0002E282803020302000102032800FF
0x2F470x0002F282803020302000102032800FF
0x30480x03330285002010102000102032803FF
0x31490x00031282803020302000102032800FF
0x32500x01132281404020204000111032801FF
0x33510x01133281404020204000111032801FF
0x34520x01134281404020204000111032801FF
0x35530x03335FA010101FA01000A0B032803FF
0x36540x011362850020101020001020D2801FF
0x37550x00037281404020204000111032800FF
0x38560x00038282803020302000102032800FF
0x39570x00039A0A004010104000112032800FF
0x3A580x0113A28320501010A00010D032801FF
0x3B590x0113B28320501010A00010E032801FF
0x3C600x0113C4B4B0501010500010D032801FF
0x3C600x25373C4B4B0501010500010D032825FF
0x3D610x0113D4B4B0501010500010E032801FF
0x3D610x25373D4B4B0501010500010E032825FF
0x3E620x0003E282803020302000102032800FF
0x3F630x0003F285002010102000102032800FF
0x40640x00040282803020302000102032800FF
0x41650x00041142802010102000117032800FF
0x42660x01142010101010101000102032801FF
0x43670x2739432828030A030A001102032827FF
0x44680x00044141403020302000102033200FF
0x44680x01144141403020302000102033201FF
0x44680x011441414030203020001051B2801FF
0x45690x01145102002010102000102032801FF
0x46700x01146102002010102000102032801FF
0x46700x01146102002010202000102032801FF
0x47710x00047102002010102000102032800FF
0x47710x01147102002010102000102032801FF
0x48720x2739482828030A030A001102032827FF
0x49730x25374964C802010102000102032825FF
0x49730x253749C8C802010102000102032825FF
0x4A740x0004A2828030A030A001102032800FF
0x4B750x0004B2828030A030A001102032800FF
0x4C760x0114C142802010102000102032801FF
0x4C760x0114CC8C804010104000102032801FF
0x4D770x25374D14280201010200010A032825FF
0x4E780x25374E14280201010200010B032825FF
0x4F790x0114F282802010102000102032801FF
0x50800x011500A0101010A01000105032801FF
0x51810x0005128280302030210040A032800FF
0x51810x0115128280302030210040A032801FF
0x52820x00052285002010102000102032800FF
0x53830x000532828030A030A001102032800FF
0x54840x000542828030A030A001102032800FF
0x55850x022550A0A01010101000117032802FF
0x56860x09956010A0101010A000102032809FF
0x57870x0115728FA0301011400011E032801FF
0x57870x25375728FA0301011400011E032825FF
0x58880x0115828FA0301011400011F032801FF
0x58880x25375828FA0301011400011F032825FF
0x59890x01159282814141414000102032801FF
0x5A900x0005A01010101010100013B262800FF
0x5B910x0005B01010101010100013B272800FF
0x5C920x0115C0101010101013B011E3A2801FF
0x5C920x25375C0101010101013B011E3A2825FF
0x5D930x0115D0101010101013B011F3A2801FF
0x5D930x25375D0101010101013B011F3A2825FF
0x5E940x0005E040101010401001102032800FF
0x5E940x0115E040101010401001102032801FF
0x5F950x0005F040101010401001102032800FF
0x5F950x0115F040101010401001102032801FF
0x60960x00060282802010102000102032800FF
0x60960x00060282802010102000A020C2800FF
0x60960x00060282803020302000102032800FF
0x60960x253760282802010102000A020C2825FF
0x61970x00061282803020302000102032800FF
0x62980x00062282803020302000102032800FF
0x63990x01163282814141414000102032801FF
0x641000x00064282803020302000102052800FF
0x651010x00065282803020302000102052800FF
0x661020x00066282803020302000102052800FF
0x671030x00067282803020302000102052800FF
0x681040x00068282803020302000102032800FF
0x691050x253769010101010101000102032825FF
0x6A1060x0116A010101010101000102032801FF
0x6A1060x0996A010101010101000102032809FF
0x6B1070x0336B010101010101000102032803FF
0x6B1070x2F476B01010101010100010203282FFF
0x6C1080x0006C320A05010105000102032800FF
0x6D1090x0006D320A05010105000102032800FF
0x6E1100x0006E285002010102000102032800FF
0x6E1100x0336E285002010102000102032803FF
0x6F1110x0116F96960501010A000102032801FF
0x6F1110x25376F96960501010A000102032825FF
0x701120x0117096960501010A000102032801FF
0x701120x25377096960501010A000102032825FF
0x711130x00071282828012801001102032800FF
0x721140x00072282828012801001102032800FF
0x731150x01173142802010102000102032801FF
0x741160x000740A0101010201000402032800FF
0x751170x000750A0101010101000402032800FF
0x761180x01176323205010105000102032801FF
0x761180x253776323205010105000102032825FF
0x771190x01177323205010105000102032801FF
0x771190x253777323205010105000102032825FF
0x781200x01178FAFA05010105000102032801FF
0x781200x253778C8C805010105000102032825FF
0x791210x01179010101010101000102032801FF
0x791210x253779010101010101000102032825FF
0x7A1220x2D457A01010101010100010203282DFF
0x7B1230x0007B010A0101010A000102032800FF
0x7B1230x0007B282803020302000102032800FF
0x7B1230x0117B010A0101010A000102032801FF
0x7B1230x0117B282803020302000102032801FF
0x7B1230x23357B010A0101010A000102032823FF
0x7C1240x0007C282803020302000102032800FF
0x7C1240x0337CFA0A0101010113140A0B2803FF
0x7D1250x0007D010101010101000102032800FF
0x7D1250x0007D141402020101000102032800FF
0x7D1250x0337D010101010101000102032803FF
0x7D1250x0337D141402020101000102032803FF
0x7E1260x0997E010101010101000102032809FF
0x7F1270x0007F010101010101374647392800FF
0x7F1270x27397F010101010101374647392827FF
0x801280x253780FAFA01050105000102032825FF
0x811290x0118101010101010100014A4B2801FF
0x821300x01182010101010101000102032801FF
0x831310x09983191901010101000102032809FF
0x841320x09984010A0101010A000102032809FF
0x851330x09985010A0101010A000102032809FF
0x861340x09986010A0101010A000102032809FF
0x871350x253787282803020302000102032825FF
0x881360x03388141405020205000107062803FF
0x881360x253788141405020205000107062825FF
0x881360x273988141405020205000107062827FF
0x891370x03389010101010101000102032803FF
0x891370x03389285002010102000102032803FF
0x8A1380x0008A282803020302000102032800FF
0x8B1390x0998B01010101010100010A032809FF
0x8C1400x0118C010101010101000102032801FF
0x8C1400x0118C102002010102000102032801FF
0x8D1410x0008D010101010101394E0A042800FF
0x8D1410x0118D010101010101394E0A042801FF
0x8D1410x0558D010101010101394E0A042805FF
0x8E1420x0118E010101010101000102032801FF
0x8E1420x0118E142802010102000102032801FF
0x8F1430x0338F285002010102000102032803FF
0x901440x25379028C80301011400012B2D2825FF
0x911450x25379128C80301011400012C2E2825FF
0x921460x00092010101010101000102032800FF
0x931470x00093010101010101000102032800FF
0x941480x3452943C3C02040103000102032834FF
0x951490x01195282803020302000102392801FF
0x951490x253795282803020302000102392825FF
0x961500x2D459601010101010100010203282DFF
0x971510x00097282803020203000102032800FF
0x971510x01197282803020203000102032801FF
0x981520x0009828280A28280A000102032800FF
0x991530x00099282803020302000102032800FF
0x9A1540x0009A282803020302000102032800FF
0x9A1540x0009A285002010102000102032800FF
0x9A1540x25379A285002010102000102032825FF
0x9B1550x2D459B01010101010100010203282DFF
0x9C1560x2D459C01010101010100010203282DFF
0x9D1570x2D459D01010101010100010203282DFF
0x9E1580x2D459E28280A28280A00010203282DFF
0x9F1590x0119F102002010102000102032801FF
0xA01600x011A0102002010102000102032801FF
0xA11610x011A1102002010102000102032801FF
0xA21620x000A2C8C804010104000108092800FF
0xA31630x2D45A301010101010100010203282DFF
0xA41640x000A4282803020302000102032800FF
0xA51650x000A5282803020302000102032800FF
0xA61660x000A6010101010101000102032800FF
0xA71670x000A7010101010101000102032800FF
0xA81680x000A8010101010101000102032800FF
0xA91690x000A9010101010101000102032800FF
0xAA1700x2739AA010101010101000102032827FF
0xAB1710x000AB010101010101000102032800FF
0xAC1720x000AC282803020302000102032800FF
0xAD1730x011AD280102010101000102032801FF
0xAE1740xA5165AE010101010101480B024C50A5FF
0xAE1740xA5165AE282828020228480B024C50A5FF
0xAF1750xA5165AF010101010101490B024D50A5FF
0xAF1750xA5165AF282828020228490B024D50A5FF
0xB01760x000B00101010101010A3738462800FF
0xB01760x2335B00101010101010A3738462823FF
0xB01760x2537B00101010101010A3738462825FF
0xB11770x000B10A0A03020302000102032800FF
0xB11770x000B1282803020302000102032800FF
0xB11770x011B10A0A03020302000102032801FF
0xB21780x2537B201010101010100012F332825FF
0xB31790x2537B3010101010101000130342825FF
0xB41800x000B4010101010101393738462800FF
0xB41800x2739B4010101010101393738462827FF
0xB51810x000B5010101010101393738462800FF
0xB51810x011B5010101010101393738462801FF
0xB61820x011B6FAC802010102000102032801FF
0xB71830x011B7FAC802010102000102032801FF
0xB81840x2739B8282828012801001102032827FF
0xB91850x2739B9282828012801001102032827FF
0xBA1860x022BA282803020302000102032802FF
0xBB1870x022BB282803020302000102032802FF
0xBC1880x022BC282803020302000102032802FF
0xBD1890x022BD282803020302000102032802FF
0xBE1900x022BE282803020302000102032802FF
0xBF1910x022BF282803020302000102032802FF
0xC01920x000C0282803020302000102032800FF
0xC01920x022C0282803020302000102032802FF
0xC11930x000C1282803020302000102032800FF
0xC11930x022C1282803020302000102032802FF
0xC21940x099C2010101010101000102032809FF
0xC31950x099C364640A01010A000102282809FF
0xC41960xA5165C40101010101010001020350A5FF
0xC51970xA5165C50101010101010001020350A5FF
0xC61980xA5165C60101010101010001020350A5FF
0xC71990xA5165C70101010101010001020350A5FF
0xC82000xA5165C80101010101010001020350A5FF
0xC92010xA5165C90101010101010001020350A5FF
0xCA2020x000CA010101010101000102035000FF
0xCB2030x000CB010101010101000102035000FF
0xCC2040xA5165CC0101010101010001020350A5FF
0xCD2050xA5165CD0101010101010001020350A5FF
0xCE2060xA5165CE0101010101010001020350A5FF
0xCF2070xA5165CF0101010101010001020350A5FF
0xD02080xA5165D00101010101010001020350A5FF
0xD12090xA5165D10101010101010001020350A5FF
0xD22100xA5165D20101010101010001020350A5FF
0xD32110x000D3010101010101000102035000FF
0xD42120x000D4010101010101000102035000FF
0xD52130xA5165D50101010101010001020350A5FF
0xD62140x2537D601010101010100012B242825FF
0xD72150x2537D701010101010100012C252825FF
0xD82160x2537D8010101010101000142442825FF
0xD92170x2537D9010101010101000143452825FF
0xDA2180x2537DAFA960302020300013E402825FF
0xDA2180x2537DAFA960502020300013E402825FF
0xDB2190x2537DBFA960302020300013F412825FF
0xDB2190x2537DBFA960502020300013F412825FF
0xDC2200x3452DC282802040103000102032834FF
0xDD2210x000DD010101010101000102032800FF
0xDD2210x000DD010101010101000102062800FF
0xDD2210x000DD282803020302000102032800FF
0xDD2210x2537DD010101010101000102062825FF
0xDE2220x000DE282803020302000102032800FF
0xDE2220x011DE282803020302000102032801FF
0xDF2230x000DF282803020302000102032800FF
0xDF2230x000DFA0A004010104000102032800FF
0xDF2230x000DFA0A004010104000136172800FF
0xDF2230x033DFA0A004010104000136172803FF
0xE02240x000E0010101010101000102032800FF
0xE02240x000E0010101010101000136172800FF
0xE02240x000E0282803020302000102032800FF
0xE12250x000E1010101010101000102032800FF
0xE12250x000E1010101010101020A0B0C0A00FF
0xE12250x000E1282803020302000102032800FF
0xE12250x011E1010101010101020A0B0C0A01FF
0xE12250x2537E1010101010101020A0B0C0A25FF
0xE22260x000E2010101010101000102032800FF
0xE22260x000E2010101010101020A0B0C0A00FF
0xE22260x000E2282803020302000102032800FF
0xE22260x2537E2010101010101020A0B0C0A25FF
0xE32270x000E3010101010101000102032800FF
0xE32270x000E3282803020302000102032800FF
0xE42280x033E4010101010101000102032803FF
0xE52290x000E5010101010101000102032800FF
0xE62300x033E60101010101010F1002032803FF
0xE62300x2739E60101010101010F1002032827FF
0xE72310x2D45E701010101010100010203282DFF
0xE82320x000E8010101010101120A3C3D2800FF
0xE82320x2739E8010101010101120A3C3D2827FF
0xE92330x000E9282803020302000102032800FF
0xF72470x000F7282803020302000102032800FF
0xF82480x022F8282803020302000102032802FF
0xF92490x022F9282803020302000102032802FF
0xFA2500x022FA282803020302000102032802FF
0xFB2510x022FB282803020302000102032802FF
0xFC2520x000FC282803020302000102032800FF
0xFC2520x022FC282803020302000102032802FF
0xFD2530x000FD282803020302000102032800FF
0xFD2530x022FD282803020302000102032802FF
0xFE2540x000FE282803020302000102032800FF
0xFE2540x022FE282803020302000102032802FF
0xFF2550x000FF282803020302000102032800FF
0xFF2550x022FF282803020302000102032802FF
Old Fri, Oct-11-2013, 09:06:25 PM   #3
m3vertsmg2
Formerly new//m3fan
Reputation: 0 m3vertsmg2 is on a distinguished road
Question,
Will this only suppress the CEL? Will it also set the secondary air pump emissions monitor to ready?
EDIT:
There is a no EOBD variant for the E46 M3. But since we have much finer control of the DME nowadays, I don't really recommend flashing it (since it would disable OBD altogether). You're best off turning off the error codes you want to turn off. It has been reported that 0'ing out the entire string for the cat efficiency codes sets the monitors to ready.
Has been answered. Thanks!
*F-BOMBS IN SIGS*
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things
Jump to top m3vertsmg2 is offline   Reply With Quote
Old Sat, Dec-14-2013, 02:23:20 AM   #4
wertyu78
Reputation: 0 wertyu78 is on a distinguished road
Hi,
I am having issues locating the DTC in the hex editor itself. Can somebody explain this process further?
Thanks!
Jump to top wertyu78 is offline   Reply With Quote
Old Sat, Dec-14-2013, 07:08:40 AM   #5
p0lar
Naturally Agitated
p0lar's Avatar
First, determine what version MSS54/MSS54HP you have.
The version string will look like 21132200xxxxyyyy or 21132300xxxxyyyy or 21132500xxxxyyyy.
Find your xxxx in the table headings above, and you'll have EVERY location for EVERY DTC. Follow the removal strategy in the first post to suppress what you like!
Old Sat, Dec-14-2013, 06:09:28 PM   #6
wertyu78
Where do I find the location of the version string? I've loaded the .bin from the DME to the hex editor but cannot find the DTC string!
Old Sat, Dec-14-2013, 06:17:22 PM   #7
p0lar
Naturally Agitated
p0lar's Avatar
Ok, this is going to be WAY over the top, from an information-perspective, but here is a fully-searchable PDF file with all DTC strings from almost every unmodified MSS54/MSS54HP file I own.
It's raw data, so beware the ~375 pages of information. This is in a CSV format, so it should easily import into a database, spreadsheet or some other format useful for data analysis.
"enjoy"
Old Sat, Dec-14-2013, 06:20:08 PM   #8
p0lar
Naturally Agitated
p0lar's Avatar
Lightbulb Re: DTC (OBD Error Code) Deletion/Removal Strategy
Read the PDF HowTo in my signature, specifically page 9!
Old Sat, Dec-14-2013, 06:27:51 PM   #9
wertyu78
I'm having trouble locating the two bytes at 0x2. Perhaps it's my lack of knowledge on using a hex editor.
Old Sat, Dec-14-2013, 06:34:23 PM   #10
p0lar
Naturally Agitated
p0lar's Avatar
Let's go back to the basics. Don't worry about the offset 0x2 for now.
1) What is the year/make/model of your car?
2) What is the size of the file that you pulled? (BMWFlash? Galletto? Other?)
3) What is the 16 byte string located at either 0x7FB8 or 0xBFB8?
"Who would cross the Bridge of Death must answer me these questions three, ere the other side he see."
Discussing DTC (OBD Error Code) Deletion/Removal Strategy in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
