Old Tue, Feb-26-2013, 02:46:28 AM   #1
BearDeXPS
BearDeXPS's Avatar
Talking BearDeXPS 2005 JB/Blk M3 Journal
2005 BMW E46 M3
Production Date 07/2005
Final Assembly Point: Regensburg, Germany
Jet Black / Black Nappa Leather / 6-spd MT
Premium Package (moonroof, power seats w/ driver memory)
Heated Seats/ Parking Distance Control / Bi-Xenon Headlights / H&K Sound / Aluminum Trim / CD Player / LED Tail Lights
Most recent pic's 9/19 (finally got some proper ones ):
ME!
List of Modifications & Maintenance ****UPDATED 9/29/2014
Engine & Exhaust:
Lang Racing Stage 2 Performance Cylinder Head
- Supertech Valve Spring Kit w/ Ti Retainers
- Complete Disassembly & Cleaning
- High performance Five Angle Valve Job
- New OE Valve Seals
- Trueness Checked & Resurfaced Mating Surface
- Smoothed out CNC cuts on intake side of cylinder head
Lang Racing EGR Plate
evolve-R ECU Tune/Re-Tune Stage 2:
- Idle RPM Raised – 1,000 RPM
- Cold Start Delete
- Variable Rev Limit Raised per gear (8300 in first, 8200 in second, 8000 in 3-6)
- Top Speed Limit Delete
- SMG Shift Light
- Sport Mode Memory
- Dyno Mode
- Secondary Air Pump Delete
- Add the much desired "fire shooting/burbling/cracking on over rev"
- Post Cat 02 "Ready State" w/ CEL removal
Dinan Intake and Aluminum Air Mass Meter Housing D763-1600A
Dinan High Flow Throttle Bodies D760-3400
Macht Schnell Intake Charge Pipe (ICP)
aFe Dynamic Air Scoop
EVOsport Power Pulleys & *Contitech 6PK1538 Belt
Status Gruppe Tuning Stainless Steel "Cat-less" headers + Heat Wrap
Status Gruppe Tuning Section 1 "Rasp Pipe"
Rogue Engineering Section 2 “X-pipe” w/ EVC dump valve
Eurosport Design exhaust tips on OE muffler (I like the stock exhaust note)
OE new exhaust hardware, gaskets, & hangers
ARP 2000 Head Studs w/ OE new Head gasket
ARP 2000 Rod Bolts, WPC Treated Rod Bearings w/ OE new Oil Pan gasket
IAT relocate
Reflect-A-Gold Protective Film on Dinan intake, MAF housing, and intake manifold
Radium Engineering Catch Can w/ Petcock Drain Kit
OE new Timing Chain, Oil Pump Chain, and all new Chain Guides, Rails, Hardware, & Gaskets
Dimple Oil magnetic drain plug
**280/272 Schrick Cams w/ WPC treated Followers (undecided... pending if I go F/I or not)
Fuel:
Radium Engineering Fuel Pump sleeve w/ Aeromotive 340R Fuel Pump & OE new Gaskets
OE new Jet Pump
OE new Fuel Filter & FPR
OE new Vacuum Supply Hoses
Radium Engineering Fuel Rail w/ Pressure Gauge
Fuel Injector Cleaning (RC Engineering) w/ OE new o-rings & Air Rail o-rings & ITB gaskets
VANOS:
Beisan modified Pump Disk
Dr VANOS Cryo Treated Exhaust Hub
Beisan System Rattle Kit & Tool
Beisan System Piston Seals
Beisan System Plate Seals
Beisan System beta Upper Left Chain Guide
Turbo Toy modified ARP camshaft bolts w/ Loctite
OE new Chain Tensioner
Bimmerworld VANOS Actuator Supply Line
OE new VANOS Filter Kit
OE new S62 Diaphragm Springs
OE new Solenoid Pack
Suspension:
H&R Springs w/ Rear Adjustable Perch
Koni Yellow shocks (R-3/4 & F-1/4 turn from FULL soft)
Rogue Engineering Rear shock Mount
Turner Motorsport Spring Perch Reinforcement
OE new CSL Front Upper Strut Mount Bearing and Perch
OE new spring seat pads
OE new Front Control Arm Bushing
AKG 85A poly Rear Trail Arm Bushings
Clutch, Tranny, & Driveshaft:
Rogue Engineering Stage 1 Clutch w/ JB Racing Stainless Steel Lightweight Flywheel
OE new Throw-out Bearing & Guide Tube
Rogue Engineering Stainless Steel Pivot Pin
OE new Fork & Spring Clip
Rogue Engineering Stainless Steel Clutch Line
OE new Clutch Slave Cylinder
OE new Clutch Master Cylinder
Rogue Engineering CNC OCTANE Short Shifter Kit (34% reduction)
- Rogue Engineering CNC'd carrier arm, Weighted Selector Rod (WSR), & delrin oval Carrier Bushing
OE new shifter linkage Shifter Ball Bushing, Bearing, Shims, & Clips
CDV delete
OE new Compression Springs, Pins, & Balls
OE new CSB, Guibo ("Flex Disk"), CV Gasket, CV re-packed, & Hardware
OE new “updated” Diff Bolts
OE new Harmonic Balancer & Timing Case Gasket
Castrol SAF-XJ diff fluid w/ Ford FM Booster
Pentosin 75w80 / API GL4 MTF
Dimple Tranny & Diff magnetic drain plugs
VibraTech Motor Mounts
Rogue Engineering Tranny Mounts
Brakes:
Porsche 996 Brembo BBK upgrade (rebuild)
StopTech high temp seals & dust boots
OE new Porsche 996 Brembo caliper cross-over lines, Bleeder Screws, brake pad Retaining Hardware & Dampener plates
Rally Road front carrier bracket
p0lar rear carrier bracket
Custom powder coat
Brembo Brake Temp Stickers
Racing Brake 2-piece fully floating rotor’s
Textar Brake Pads
StopTech Stainless Steel brake lines w/ banjo fitting
Motul RBF 600 brake fluid
Wheels:
OE new ZCP BBS wheels w/ Michelin PSS F245/35-19 R275/30-19
OE original 18's w/ Michelin PSS F225/40-18 R255/35-18 (sitting in the garage for future track use)
Macht Schnell Competition Wheel Spacer Kit - 20mm (front)
Macht Schnell Competition Wheel Spacer Kit - 12mm (rear)
RAD Wheel Lock Bolt Set
Lighting:
Umnitza Orion V4 6000K Angel Eyes (w/ Remote Option & Night Controller)
OE new Headlight Lens
Osram Xenarc CBI D2S 5500k HID headlight bulbs
ZKW-R HID clear lense
DEPO Smoked Corner lights
DEPO Smoked Side Markers lights
Lamin-X fog light film (yellow)
DTM Tuning 3000k HID Fog Light retrofit
CREE LED reverse bulbs
Racing Dash Led License Plate lights
Audio:
BSW Stage 1 audio upgrade
BSW d110.e46c subwoofer system
HushMat front doors, rear boot lid, rear seat, & “spare tire” well
OE new Aux Input
*Avin AVANT-2 head unit (CD/DVD/Nav)
- Backup/Reverse Camera
- Torque Compatible Bluetooth OBD2 w/ ON OFF Button
- USB AUX 3RCA
- Bluetooth Hands Free Microphone
- 32GB external micro SD
- OE Nav retrofit kit/bracket
Interior:
3M Infinity OP Window Tint 15%
3M Crystalline 90 Window Film Front Windshield
Sybesma upgraded rearview mirror
WeatherTech floor Mats
OE new Floor Mats
OE new Rear Speaker Covers
OE new “short” center council
OE new “euro” tray & cup holder tray (interchangeable)
Coby Wheel black Alcantara w/ 'M tri-stitch' steering wheel w/ 12 o'clock yellow stripe
Coby Wheel black Alcantara w/ 'M tri-stitch' shifter boot
F10 M5 Illuminated Shift Knob
Rogue Engineering clutch stop
Rogue Engineering delrin Clutch pedal bushing
AKG delrin Brake pedal bushing
"M" Seat Gap Fillers
Mason Engineering Short Throw Clutch Pedal
Turner Motorsport Aluminum Pedals
*Power Module
Exterior:
Matte Black Gills & Grills
Status Gruppe Tuning CSL one piece 2x2 weave front lip
Painted Reflectors
OE new rear window trim/seals
OE new Hood Grill
TeKarbon CSL 2x2 weave rear diffuser
AGT 2x2 weave side skirt extensions
Euro 'convex' Mirrors
Rear fenders rolled/pulled
JL Motoring ACS rep 2x2 weave trunk lip
**Status Gruppe Tuning FRP CSL rep trunk
Subframe & Diff:
**Redish Motorsport Subframe Reinforcement Plates (already purchased; sitting in garage for install)
**Powdercoat Rear Subframe
**OE Structural Foam Injection
**OE new diff cover & bushings
**AKG 90A w/ Aluminum Sleeve Subframe bushings
**Mason Engineering X-Brace w/ Rear Suspension Subframe Support
**4.10 or 3.91 Motorsport Diff (undecided... pending if I go F/I or not)
Programming:
Instrument Cluster - Acoustic Warnings for Belts DISABLED
Rearview Mirror Module - Reverse Tilt Mirror
General Module - Open and Close Windows/Sunroof with Remote, Disable the Boot Open Button Key Fob when Car is Locked
EWS Module - Clutch Switch DISABLED
*DSC - Enable M-track Mode & Indicator
*OBD - Oil Level Display, Cluster Speed Offset
*LCM - Fogs Stay on with Highs Beams, Triple Blink Turn Signals, Alternate 4 Way Flasher Flash Patterns
*General Module - Alarm Enabled, One Touch Close for Coupe Rear Windows, One Click Unlock for Both Doors
Paint Correction/Detail/Coating:
DrColorChip paint correction
Wet Sand
3 stage polish w/ Shine Supply Classic Cut & Flat Top
Modesta BC-05 glass coating
Black Perl tire coating
Re-painted Font Bumper
Painted front Grill
Glipstone Leather cleaner/conditioner fanboy!!
Misc. Maintenance/Preventative Maintenance:
OE new Clock Spring
OE new ECU blower (no more cricket noise!)
OE new TPS (upper and lower)
OE new tensioner pulleys
OE new Valve Timing Chain Bolt (typ oil leak)
OE new Coolant System replacement
- Water Pump, Thermostat, Expansion Tank Kit, Fan Blade, Fan Shroud, Aux Fan Switch, Temp Sensor, all new bolts, o-rings, gaskets, seals, etc.
Bimmerworld/C&R Aluminum Radiator (30% capacity increase)
Rogue Engineering Silicone Radiator Hoses
Mishimoto Electric Fan Conversion (custom weather proof quick disconnect, control module relocate, Mallory Pro Sheild)
Redline Water Wetter & distilled water
OE new Crankcase Pressure Regulator Valve - "oil separator"
OE new CPV
Viton CPV o-ring
OE new front HID level sensor/bracket
OE new Power Steering Pump
OE new Power Steering lines, Hardware, & Reservoir/Filter
ATF Motul Power Steering Fluid
OE new Front Wheel Hub/Bearing Assembly w/ Dust Cap, Collar, & Collar Nut
OE new Steering Guibo
OEM new Bosch Starter Motor
OEM new Bosch Alternator
OE new Oil Pump
OE new sunshade clips & lubed tracks w/ Motul 300 lithium grease
OE new door card Clips w/ foam (anti-rattle)
Tennis Ball Mod (anti-rattle)
Rear upper deck Felt Pads applied (anti-rattle)
OEM new Bosch Coils
NGK Iridium IX Spark Plugs
OEM new Bosch Pre-Cat O2 Sensors
OE new Camshaft Position Sensors
Cleaned Throttle Bodies
Cleaned ICV
Cleaned Speedo Sensors
Inspections I & II as scheduled
Castrol TWS BMW branded 10W-60 as scheduled (every 5,000k miles)
SAFETY FEATURES:
HJC SI-12R helmet in Rubberstone Black + an R.S.T. Black Chrome Shield
Schroth Racing - Quick Fit Pro harnesses in black + Harness Grips + Harness Shoulder Pads
**mod phase 2 planned for 2017/18
Hope you enjoy; thanks for stopping by!
Last edited by BearDeXPS; Fri, Jun-19-2015 at 04:21:21 PM. Reason: updated "current pics" & "mod list"
Old Tue, Feb-26-2013, 02:48:16 AM   #2
BearDeXPS
BearDeXPS's Avatar
Default Re: BearDeXPS 2005 JB/Blk M3 Journal
Most guys on this forum start their Journal by telling the viewer's a little bit about themselves... I guess I'll follow suit.
I spent most of my life in Cincinnati, OH. My High School/FastAndTheFurious years were spent where most cats that age who are interested in cars spend their youth... in the Honda scene. My first car was a '95 Honda Del Sol 6MT and I must say I loved LOVED that car. For a High School kid it was great, fun, etc. but it was a kid's car. I graduated college and was stepping into the "professional" arena and didn't want to be seen in it for fear of losing the respect as my elders. I was very close to pulling the trigger on an e36 m3 4-door post college graduation but decided to take my father’s advice and purchase his old '95 Toyota Avalon for like $2k, and save for something I really wanted to purchase. Well, I ended up driving it for almost 3years saving my money while working and traveling with work all around the USA before I could responsibly purchase my dream car, e46 M3 - JetBlack/Black.
Here’s a picture of the enabler; I called it "The Green Monster”:
There isn’t a huge used market for M3’s in Texas. My parents house where I grew-up is luckily right down the street from Enthusiast Auto Group. I told my father my budget, what I wanted, and told him I would trust his review (I've got much respect for my father, he's a good man and knows his BMW's). After he took about 5 of them for a spin over the course of 2months I finally decided to pull the trigger. So my purchase date was 5/2011.
I purchase it for $28,000 w/ 60k miles (incredible shape - recently serviced Stage II inspection and a new CPV). Eric/Evan were great guys to deal with and I would definitely recommend them to someone who's in the market! EAG is also a Dinan dealer so I decided to purchase a few extra goodies - CAI, Stage3 Software & a Rogue Engineering CNC OCTANE Short Shifter Kit (34% reduction); before my father and mother drove it down to S. Texas.
Here's some pic's from the dealer:
Texas is hot as Hell so the very first thing I had to get done was a tint - so I took it to a local tint shop and got the darkest legal tint available - 3M Infinity OP Window Tint 15% as well as the 3M Crystalline 90 Window Film for the front windshield.
Other than that, I pretty much enjoyed it in its stock forum for a while, smart and responsible owner in mind with regular maintenance as required!
A local Indy I had some work performed at had an M1 inside so I took the chance to get a close look… hope you guys like the pic’s:
Old Tue, Feb-26-2013, 02:48:48 AM   #3
BearDeXPS
BearDeXPS's Avatar
Audio upgrades – 6/2012 (start of the mod bug)
It's pretty bizarre our car's don't come with an Aux input. The search to find a solution is what brought me to this forum. I didn't find my answer here on m3form.net, but I did find a link to a great DIY - http://www.my330i.com/mod26.php
OEM Aux input:
After some research regarding what speaker system to go with I decided on Bavarian Soundwerks:
- BSW Stage 1 audio upgrade
- BSW d110.e46c subwoofer system
- HushMat front doors and rear boot lid
I also replaced the rattling OEM Rear Speaker Cover(s):
Old Tue, Feb-26-2013, 02:49:15 AM   #4
BearDeXPS
BearDeXPS's Avatar
After about 2years of ownership it was due for a large maintenance! Plus I had recently purchased all sorts of goodies that I wanted a shop to install for me while I headed back home for a long Christmas vacation. Not being from Texas it was a bit of a quest to find an Indy that was reputable and I felt comfortable leaving her with for such a long period of time. Here's a thread that was created to help find a shop in San Antonio; the end result was - there is no good shops in San Antonio http://m3forum.net/m3forum/showthread.php?t=420707
Inspection II - valve adjustment, fuel filter, brake flush, transmission flush, diff flush, oil change
During the Inspection II valve adjustment the Indy I selected did a visual inspection of my VANOS. It appears there was a start to the demise of my exhaust hub, plus the m3forum paranoia was starting to get to me; so I decided it was time to replace my VANOS system so I can finally get some sleep. Here's a picture of my old VANOS exhaust hub where you can start to see some of the finish deteriorating:
I decided to go the Dr VANOS upgrade route – cryo treated exhaust hub, modified pump, updated intake bolts. He's local to me so I figured if I had any problems in the future he would be a quick commute to Austin from San Antonio away.
A complete new suspension was installed. I decided to go the H&R springs w/ Koni shocks for several reasons; overall I'm very happy with my decision.
- H&R Springs w/ Rear Adjustable Perch
- Koni Yellow shocks (3/4 turn from FULL soft)
- Turner Rear Shock Mount Reinforcement
- Rogue Engineering Rear Shock Mount
- Rogue Engineering Spring Perch Reinforcement
- OEM CSL Front Upper Strut Mount Bearing and Perch
The rear view mirror was cracked - I decided to go the Sybesma route and I'm very happy I did. They did a great job and were very easy to deal with!
New OEM Headlight Lens
Smoked Corner
Painted Reflectors
Status Gruppe CSL one piece 2x2 weave front lip
Old Tue, Feb-26-2013, 02:49:38 AM   #5
BearDeXPS
BearDeXPS's Avatar
Finally meeting some local enthusiasts in SA/Austin area! Looking forward to more Cars & Coffee, G2G’s, & Hill Country cruises!!
Cars & Coffee - Austin, Tx (2/17)
Hill Country, Tx (2/17)
Hill Country, Tx / Canyon Lake (2/17)
Cars & Coffee - San Antonio, Tx (2/23)
Old Wed, Feb-27-2013, 02:41:42 AM   #6
tr4ck_m3
Buildjournal
tr4ck_m3's Avatar
Reputation: 0 tr4ck_m3 is on a distinguished road
more pics!
IG: @tr4ckM3
B-Spec Tune
2002 BMW E46 M3 6MT | B-Spec Tune + E85 Flex Fuel | JRZ RS PRO | Titan 7 TS-5
2013 BMW F30 335i 8AT - MLSD | XHP Stg3 + MHD E30 Stg2 | KW V1 | Volk TE37
Jump to top tr4ck_m3 is offline   Reply With Quote
Old Wed, Feb-27-2013, 06:38:13 PM   #7
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Yes more pics of the upgrades and maintenence.
Build///Journal
IG: @Khan_Art_
Old Wed, Feb-27-2013, 07:17:12 PM   #8
Dizzeep
Blue Dreamin 24/7
Dizzeep's Avatar
Reputation: 0 Dizzeep is on a distinguished road
Good start to your journal. Glad to see another Texas M3 journal!
Clean car hope to see it in person at some meets and get togethers.
WTD
By joining Fapper Club
///M CSL SMG Software,Evolve,Dinan,SGT,Dynavin
Jump to top Dizzeep is offline   Reply With Quote
Old Thu, Feb-28-2013, 03:42:40 PM   #9
BearDeXPS
BearDeXPS's Avatar
Originally Posted by omhl View Post
more pics!
I know, I know! Will get on it this weekend
Old Thu, Feb-28-2013, 03:44:28 PM   #10
BearDeXPS
BearDeXPS's Avatar
Thanks Deep! Let me know when you get back in town for Spring/Summer break
I've met a handful of the Austin folks... hopefully I'll be meeting some more over the weekend at COTA
Discussing BearDeXPS 2005 JB/Blk M3 Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
