Old Mon, Jan-07-2013, 08:19:43 PM   #11
kuksul08
Default Re: Help with cavity on engine block between cylinders (blown headgasket)
I don't see why a cement wouldn't work. It's under a lot of compression by the cylinder head and will just provide something for the gasket to press against to maintain full strength. Can you measure how deep the cavity is? It doesn't look like much.
Here are some super high temp cements (1800-2200F) http://www.omega.com/Temperature/pdf...ND_AIR_SET.pdf or http://www.cotronics.com/vo/cotr/ea_ultratemp.htm
Alternatively get it machined down to the depth of the cavity and use a taller head gasket. Anyone know if those are available?
Old Wed, Jan-09-2013, 12:25:04 AM   #12
e46s54guy
Reputation: 0 e46s54guy is on a distinguished road
I don't have the depth of the cavity. Decking or machining the block will be very costly since the entire bottom end has to be rebuilt and clearance may be too minimal especially since the head was already machined.
Do you have any thoughts on these products to fill the cavity?
http://www.permatex.com/products/pro...sealant-detail
http://permatex.carshopinc.com/produ...id/42287/80697
Jump to top e46s54guy is offline   Reply With Quote
Old Wed, Jan-09-2013, 12:28:05 AM   #13
kuksul08
The second link looks promising:
Suggested Applications:
Cylinder head gaskets, ...
Old Wed, Jan-09-2013, 12:46:15 AM   #14
///NNM
///NNM's Avatar
Reputation: 0 ///NNM is on a distinguished road
Russian Federation
not sure about cement, but welding and fileing to flat sounds better apternative to me. however the perfect solution is to have it machined flat just like the head. this will make a completely perfect seal.
YouTube DIY Videos Race Car: '03 M3 Coupe
Jump to top ///NNM is offline   Reply With Quote
Old Wed, Jan-09-2013, 01:00:08 AM   #15
kuksul08
What about the heat affected zone after welding?
Old Wed, Jan-09-2013, 01:01:47 AM   #16
brichter
Unregistered Abuser
brichter's Avatar
Reputation: 0 brichter is on a distinguished road
None of the products being posted have a max service temperature anywhere near what it needs to be to last more than a couple weeks/a month at best.
OP, you have 2 choices:
1) Weld and surface the block
2) Deck the block
How much had to be taken off the head to true it up? if more than .005 or so, weld the block. If less than that, you might be able to get away with decking the block depending on how deep the void is. Also see if you can get a thicker head gasket to offset the material removal.
You can't do either with the block in the car. Looks like the most cost-effective route is a used engine.
Note to people: This is what happens when you continue to drive with a head gasket blown between the cylinders. The higher compression the engine is, the faster you flame-cut the head and/or block.
2002 AW M3
Jump to top brichter is offline   Reply With Quote
Old Wed, Jan-09-2013, 02:55:06 PM   #17
nowanker
"He's no wanker!"
Just throwing this out.... not saying it's a good idea. Maybe braze that divot instead of filling with epoxy? Lower temp to apply than welding, but the brass will take the heat/pressure alot better than plastic would. It would also be easier to dress flat than a weld, assuming the goal is to not pull the block out of the car for a machine shop repair.
Old Wed, Jan-09-2013, 05:35:11 PM   #18
nrubenstein
If you really want to take a short cut, you might talk to an engine builder about whether or not you could get away with o-ringing the block. That's about the only thing that I can think of that you could do without pulling the rest of the engine. If the o-rings can withstand the existing block damage (a big question) then you'd actually have a much more powerfully sealed combustion chamber.
Old Tue, Feb-12-2013, 08:22:33 PM   #19
e46s54guy
We put the head back on with some gasket sealant and the car drives perfectly. Passed leakdown tests and pressure tests. No issues at all so far! Thanks for the comments
Old Wed, Feb-13-2013, 12:44:57 AM   #20
///NNM
///NNM's Avatar
Russian Federation
Be prepared to redo all of this in few heat cycles. Not sure how someone can trust a gasket maker in such a place. But I am glad it works for now. I sincerely wish you it holds up.
Sent from my DROID3 using Tapatalk 2
Discussing Help with cavity on engine block between cylinders (blown headgasket) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
