:FACEPALM:
![]() Location: San Diego
Completed a major front and rear suspension overhaul this weekend on a fellow members gorgeous 99 E36 M3 Estoril/Dove.
Jon came down from LA and stayed the weekend, while we cranked everything out. Short list of what we did Drop entire rear suspension weld in RTAB pocket reinforcements (found the passenger side was ripped. 106k, bone stock, one auto-x, no track events) powdercoated/reinforced rear subframe new OEM subframe bushings 75D AKG front diff bushing new ball joints new wheel bearings new dust shields new OEM RTABs w/limiters Turner adjustable lower camber arms new upper/inner bushings in spring arms new Lemforder ball joints in control arms new Lemforder tie rod assemblies powdercoated/reinforced front subframe new OEM motor mounts new BW solid FCABS new BW solid tranny mounts oil pan gasket Turner oil pan baffle kit z3 2.8 pickup tube oil pump nut (safety wire/loctite) DIY power steering hose fix new steering giubo Vorshlag Camber plates JRZ RS1 coilovers drained diff, clean it out, new gasket, refill Can't think of much else, I'll let the pictures do the talking |
Play Drums, Drive Ugly Colored Cars.
![]() Location: Town
Pictures......about thatttt
NICE!!!
#4 |
:FACEPALM:
![]() present Jon brought me ![]() unloading the parts ![]() get it on jackstands ![]() game time ![]() time to start removing stuff ![]() its out ![]() BREMBOS ![]() thats not good ![]() ![]() AKG plates ![]() since we are leaving gas tank in, gotta cut the inner tip off ![]() Jon getting the pockets cleaned up ![]() While Jon works on cleaning, I start disassembly ![]() ![]() You think the RTABs needed to be replaced? ![]() |
#5 |
Nice dude, bet it drives like a dream now.
#6 |
:FACEPALM:
yeah.. they are shot
![]() ![]() disassembling the e-brake ![]() time to get the welder out ![]() Go Pro for time lapse video set up ![]() time to get welding ![]() ![]() ![]() ![]() ![]() parts laid out ![]() more welding ![]() ![]() ![]() ![]() ![]() ![]() playing with some methods of welding, some better than others ![]() ![]() ![]() old M3 FCABS ![]() new solid rubber FCABs ![]() these are trash ![]() time for this crap to go ![]() |
#7 |
![]() Location: Connecticut
Wow. And not a damn bit of rust on that pocket either. Scary. RTABs were shot.
-Nick |
#8 |
Gone Squatchin'
![]() Location: West Chester, PA
Willl there be any structural difference by cutting the tip off on the reinforcement plate? I doubt I will find the determination to pull my gas tank when I do this...
#9 |
:FACEPALM:
out with the old
![]() press work time ![]() I love custom arbors ![]() cuz you can never have enough pictures ![]() PURDY ![]() special visitor from the forums stopped by to say hi and see what we were up to ![]() awesome Matco snap ring pliers ![]() ![]() the press setup ![]() get after it ![]() ![]() ![]() ![]() new subframe/upper/lower arms back in the car ![]() new dust shields back on ![]() the dust shields ARE directional. Make sure to line up the holes with the holes on the trailing arm ![]() putting the flanges back in ![]() time to work on the diff ![]() how did that get in there? ![]() |
#10 |
:FACEPALM:
all back together
![]() this has to go ![]() oh hai E46 csl rotors/Brembo package ![]() e46 ebrake shoes for the e46 rotors to get the e-brake to work again. Needs some modification ![]() ![]() little trim, and good to go ![]() ![]() time for half shafts ![]() ![]() goop them suckers up with anti-seize so it's easier in the future ![]() limiters with the bracket ![]() ![]() slight difference ![]() I like ![]() ![]() damn thats sexy ![]() setting outer trailing arm at ride height so I can preload the upper/lower inner bushings, and mark the RTABs, all to get torqued ![]() ![]() ![]() ![]() I want BADLY ![]() diff back in ![]() ![]() |
