Old Tue, Nov-20-2012, 02:48:31 AM   #1
02blueru
Reputation: 0 02blueru is on a distinguished road
Default Lower Radiator Hose Replacement
My coolant light came on today and it appears to be coming from the lower radiator hose area. Not sure yet if its the hose or the temp sensor. I want to replace everything in that area, so is there a list of parts (part #'s would be awesome) and tools I'll need for this job?
Also, I've looked at all of the DIYs but they all seem to involve doing something else as well such as replacing the pump. Is there something specific to this job? It looks like I'll have to remove the fan shroud, undertray, and the intake for room... Any thing else or know of any tricks that will make this easier?
Thanks guys
Jump to top 02blueru is offline   Reply With Quote
Old Tue, Nov-20-2012, 03:40:20 AM   #2
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
Default Re: Lower Radiator Hose Replacement
How many miles are on your car? Depending on the mileage, you should just do a complete coolant system overhaul.
Here is DIY link.
http://www.m3forum.net/m3forum/showthread.php?t=354281
Jump to top deadlysyns is offline   Reply With Quote
Old Tue, Nov-20-2012, 04:03:37 AM   #3
02blueru
Here is DIY link.
I just hit 60k, so i dont think thats necessary yet. I tend to subscribe to if it isn't broke don't fix it, but I also don't want to be fixing something in this area again because I didn't replace it the first time around.
Old Tue, Nov-20-2012, 04:58:19 AM   #4
deadlysyns
deadlysyns's Avatar
check and see if coolant levels are correct...if it is change out your temp sensor.
Old Tue, Nov-20-2012, 05:40:11 AM   #5
02blueru
I guess I should have mentioned that I can visually see that it's leaking. A small puddle has dropped on my garage floor through the undertray
Old Tue, Nov-20-2012, 05:52:12 AM   #6
deadlysyns
deadlysyns's Avatar
Originally Posted by 02blueru View Post
I guess I should have mentioned that I can visually see that it's leaking. A small puddle has dropped on my garage floor though the undertray
just replace lower hose, follow DIY. fairly simple.
you might need oring for your temp sensor.
Old Tue, Nov-20-2012, 07:05:38 AM   #7
see.m3.go
see.m3.go's Avatar
Reputation: 0 see.m3.go is on a distinguished road
It is a pretty simple DIY to replace the lower hose. Plus, it only costs like 20 bucks.
2003 TiAg/Imola SMG to 6MT: AST 4100, Vorshlag Camber Plates, Status Gruppe Headers, Status Gruppe Muffler, Recaro SPG, VAC Floor Mounts, TiAg Kirk Roll bar, G-force 6pt Harnesses, Evolve Tune, TMS Power Pullies, AKG DTM Shifter, Macht Schnell Stage 1 Intake, Hardwired V1, MH Stud Conversion, APEX ARC-8, AKG 75D Subframe Bushings, 95A Diff Bushings, BMW Motorsport 4.10 diff
My Journal
Jump to top see.m3.go is offline   Reply With Quote
Old Tue, Nov-20-2012, 06:40:00 PM   #8
e46<3
e46<3's Avatar
Reputation: 0 e46<3 is on a distinguished road
Pressure test the system before buying anything!
Follow the link for good tunes!
Have a listen to my SoundCloud
https://soundcloud.com/bryanisaac
Jump to top e46<3 is offline   Reply With Quote
Old Tue, Nov-20-2012, 06:48:26 PM   #9
02blueru
I decided to do the upper hose as well while i'm at it. I bought both hoses, temp sensor (including o-ring), and the coolant from pelican parts for a decent price including free 2-day shipping. I'll also be replacing my windshield washer pump and the grommet which has been dry for a while now due to a leak haha. Thanks for the replies everyone.
Old Tue, Nov-20-2012, 06:55:55 PM   #10
Dan4hockey99
stancebro4lyfe
Dan4hockey99's Avatar
Reputation: 0 Dan4hockey99 is on a distinguished road
Ukraine
DIY is a little messy but not difficult. I would just get a new temp sensor they go for around $25.
1998 BMW M3 LS1 Swap
| Felony Form | 5.7L LS1 | Enkei RPF1 | Renown | Brembo | BC Racing Coilovers |
Jump to top Dan4hockey99 is offline   Reply With Quote
Discussing Lower Radiator Hose Replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
