Old Thu, Oct-25-2012, 05:04:48 PM   #1
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
Default Illuminated ZHP knob....
The new M5 6spd comes with a illuminated ZHP knob.
Here is p/n: 25112284205
It cost $124.52 through Tischer, have at it guys.
edit 11/16/12
Ok, here are pics, the boot is attached to the knob. There is an extra piece extending pass the silver ring. It is also a new knob. It is taller than the normal ZHP knob. Uses the same connector. They staple the boot to the base ring now instead of melting/gluing the boot the base frame.
New knob illumination compared to the one in my signature which I mod my self.
I assume separating the knob from the boot would be similar to the 135i/335i perforated knobs seen here: http://www.1addicts.com/forums/showthread.php?t=209774
I think it would probably look fine if you were to cut those clips off and smooth it down - not like the bottom of that aluminum ring is visible when installed. But if it really bothers you -- perhaps it'd be possible to remove the existing aluminum ring from a ZHP knob and transplant it to the new one.
Yes, it will be the same as the 135i/335i knobs if you separate the knob from the boot.
Here are the measurements between the e46 frame and new boot/knob.
From corner to corner where the two seams are.
E46: 5 1/8 inch
M5: 6 1/2 inch
The circumference of the base frames.
E46: 20 1/2 inch
M5: 21 inch
The M5 shift boot will fit on the E46 base frame but may need to be trimmed some because it is 1/2 inch longer. The seams probably will not line up at the corners on the E46 frame.
The new M5 knob weighs 1oz more than the zhp knob with shift boot.
7.6 oz
8.6 oz
Jump to top deadlysyns is online now   Reply With Quote
Old Thu, Oct-25-2012, 05:07:16 PM   #2
jickel180
Fair Enough
jickel180's Avatar
Reputation: 0 jickel180 is on a distinguished road
Default Re: Illuminated ZHP knob....
Awesome, thanks for the heads up!
Jump to top jickel180 is offline   Reply With Quote
Old Thu, Oct-25-2012, 05:12:43 PM   #3
lilsaM3
lilsaM3's Avatar
Reputation: 0 lilsaM3 is on a distinguished road
are you still offering your services to wrap these in Alcantara? If so how much?
Jump to top lilsaM3 is offline   Reply With Quote
Old Thu, Oct-25-2012, 05:20:53 PM   #4
deadlysyns
deadlysyns's Avatar
yes, shoot me a PM..
Old Thu, Oct-25-2012, 05:26:47 PM   #5
rhumbline
rhumbline's Avatar
Reputation: 0 rhumbline is on a distinguished road
How (well) would that work on the E46 M3?
Knob would just screw on I presume?
What about the leather boot as the M6 hole is differently shaped the the E46's? Trimming necessary? Use/adapt another E46 boot?
My shift knob is looking a bit worn (leather, separation of plastic on shift pattern) and the light has stopped working for some reason, so I might well be interested in this.
Jump to top rhumbline is offline   Reply With Quote
Old Thu, Oct-25-2012, 05:28:05 PM   #6
drunk hal
Reputation: 0 drunk hal will become famous soon enough
The knobs are a press fit, just pull up and it pops off. Yes, you will have to cut the E46 boot since it's one piece.
Jump to top drunk hal is offline   Reply With Quote
Old Thu, Oct-25-2012, 06:54:55 PM   #7
RickeyM
RickeyM's Avatar
Reputation: 0 RickeyM is on a distinguished road
Nice find! I am going to order one!
2001 LSB 6MT ///M3
Jump to top RickeyM is offline   Reply With Quote
Old Thu, Oct-25-2012, 07:48:24 PM   #8
parts
Rocky Dennis FTW
parts's Avatar
Reputation: 0 parts is on a distinguished road
Thank you, sir. The perfect knob.
04SG6MT | performance keyholes | lightweight dipstick | tires | carbon fiber key chain | see-through windows | rubber powerband
Jump to top parts is offline   Reply With Quote
Old Thu, Oct-25-2012, 07:51:20 PM   #9
vongeiss
JerseyShoreM3
vongeiss's Avatar
Reputation: 0 vongeiss is on a distinguished road
The knob has clips inside of it, you basically just pull it straight off and try not to punch your self in the face. The new one just presses right on, but you will need to buy a new boot that's for an e46.
2002 ///M3 Carbon Black - current
Tein S-tech springs with Koni adjustable's, VMR VB3's silver, Magnaflow cat back,
Orion V2 LED angel eyes, HID Projector fog lights 6000k, Port & Polished head and Euro headers no cats
2002 ///M3 Steel grey / Imola Red - RIP
2001 325i Steel Grey - sold and missed
Instagram: @VONGEISS
Jump to top vongeiss is offline   Reply With Quote
Old Thu, Oct-25-2012, 07:53:17 PM   #10
DiXiS 18
DiXiS 18's Avatar
Reputation: 0 DiXiS 18 has disabled reputation
Iran
Does this one light up brighter then the one I bought from LeatherZ?
2005 ///M3 Titanium Silver/Black 6SPD
And if you no longer go for a gap that exists, you are no longer a racing driver because we are competing, competing to win.
-Ayrton Senna
Jump to top DiXiS 18 is offline   Reply With Quote
Discussing Illuminated ZHP knob.... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
