Closed Thread
Old Tue, Oct-09-2012, 01:12:55 PM   #1
rbenjami
Grumpy Old Man
rbenjami's Avatar
Reputation: 0 rbenjami is on a distinguished road
Default NEW DISCOVERY: Bluetooth Audio on E46 M3
Awhile ago I posted a query with no answers. How can I get music from my new iPhone 5 to come through my car OEM sound system? I have bluetooth telephone (TCU swap), but no bluetooth audio sound.
I am now able to get bluetooth audio through my car speakers. And it is cheap and easy.
First, I had to add the DICE ipod kit. http://www.bavariansoundwerks.com/pr...tegration-Kit/This kit hooks up to the existing CD changer harness in your trunk and ends in a 30 pin apple connector. The kit can be set up two ways. First, you could set it up so that the ipod is controlled through the head unit - through a complex system of disc and track buttons. It is complex and requires you to remember what the different discs and tracks are. Second, you can set it up so that the iPod is the controller and the sound connector just gives a link for the audio signal and power.
I set mine up the second way, so that the ipod had all of the control. BUT my iPhone 5 doesnt have a 30 pin connector. So, I started to look at bluetooth audio solutions. All were very expensive. Until I found this:
EDIT: The link at the top doesn't seem to work, but if you click on the link under the picture, it works.
For $25 I found a little doggle that plugs into your 30 pin DICE connector and gives you a powered bluetooth receiver. Now, I use the head unit to select the CD changer and it automatically powers up the doggle (which I have hidden away). Once powered, it takes a couple of seconds to automatically link to the bluetooth on my iPhone. Once linked, I can stream music, pandora, or anything else through my car speakers with excellent sound quality. Best of all, the bluetooth phone still works through the steering wheel controls.
2004 M3 CB/Cinn Convertible: OEM summer 19s w/ 17 snows; Bluetooth via TCU; euro center bin; v32/2007-2 nav; Beltronics RX75 Plus; Recaro Young Sport Seat
  • If you are wondering about whether or not to buy snow tires, please review the dozens of threads where people caused thousands of dollars of damage in a light snowfall at 10 mph.
  • If you are thinking about buying an M3 because they can now be found pre-owned fairly inexpensively, please review the threads explaining how expensive the maintenance is. Plan on spending $2,000 or more per year on routine maintenance.
Jump to top rbenjami is offline
Old Tue, Oct-09-2012, 01:26:54 PM   #2
Oldboy
Oldboy's Avatar
Reputation: 0 Oldboy is on a distinguished road
Default Re: NEW DISCOVERY: Bluetooth Audio on E46 M3
Nice! How the h*ll did you figure that out?!?!? Great job and thanks for sharing!
Jump to top Oldboy is offline
Old Tue, Oct-09-2012, 01:40:29 PM   #3
loayoweis
Reputation: 0 loayoweis is on a distinguished road
Awesome! The amazon link did not work. I was looking for this solution. I have an 01 with the older unit so this is what I am interested in.
Regards,
Loay
Jump to top loayoweis is offline
Old Tue, Oct-09-2012, 02:35:12 PM   #4
m3freak86
JERSEY STRONG
m3freak86's Avatar
Reputation: 0 m3freak86 is on a distinguished road
Wow, nice find! Might have to pick this up.
2013 SWP Subaru WRX Hatch (gone)
WRX Journal
2004 Carbon Black///M3 (gone)
Mods and Specs
My Exhaust Obsession
My Journal
Jump to top m3freak86 is offline
Old Tue, Oct-09-2012, 03:06:17 PM   #5
rbenjami
Grumpy Old Man
rbenjami's Avatar
Here is another merchant that has the same thing for fifteen bucks.
http://shop.brando.com/I-WAVE-Blueto...c0299d057.html
And here too:
http://www.chinaecarts.com/iwave-blu...ad-p-2998.html
My Amazon order came in an envelope from china with the same packaging shown in the second link. Amazon, though, has the world's best return policy - in case it doesn't work for you as well as it did for me. Of course, for fifteen bucks, it might be worth the risk (since I see the Amazon sellers are now north of thirty bucks!)
Old Tue, Oct-09-2012, 03:12:46 PM   #6
kokgo20
kokgo20's Avatar
Noob question, and don't mean to hijack the thread, how can i tell if my car has BT or not?
Build thread
05/2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - BMW MS 4.10 - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom A/F & boost gauge - Active Prima plus + FS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast -
Jump to top kokgo20 is offline
Old Tue, Oct-09-2012, 03:19:30 PM   #7
rbenjami
Grumpy Old Man
rbenjami's Avatar
When you first start up your car, have your phone search for devices. If you are 2003 or earlier, you dont have it (unless added by a prior owner). If you are 2005 or later, you probably do. If you are 2004, it is a crapshoot.
Old Tue, Oct-09-2012, 03:46:27 PM   #8
M3Moogle
Kupo
M3Moogle's Avatar
Reputation: 0 M3Moogle is on a distinguished road
Russian Federation
Unless you have Nav, then you have it regardless of the year... i think :P
Jump to top M3Moogle is offline
Old Tue, Oct-09-2012, 03:53:20 PM   #9
niart906
Reputation: 0 niart906 is on a distinguished road
Op you are a god!!! I've been looking for an inexpensive Bluetooth solution forever. Thanks!!!
Current Cars:
2013 F30 335i Estoril Blau II/Black
2000 E46 328i
Previous:
2006 E60 M5 Silver-Gray/Indy Red
2003 E46 M3 Jet Black/Cinnamon
Jump to top niart906 is offline
Old Tue, Oct-09-2012, 03:54:34 PM   #10
rbenjami
Grumpy Old Man
rbenjami's Avatar
Not true. I have Nav on my 04 and it did not have bt. There are many threads on this, lets not hijack this one. OK?
Closed Thread
Discussing NEW DISCOVERY: Bluetooth Audio on E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
