Old Wed, Aug-01-2012, 02:30:12 PM   #1
M3novo
Reputation: 0 M3novo is on a distinguished road
Default Reinstall used OEM clutch with SAC
I am planning to reinstall my used clutch that has just 35k. According TIS the clearance between the friction material and rivet should be at least 1mm, I have 1.5mm. Still a lot of material to use.
My question is as it has the SAC and TIS requires a special tool to basically keep the adjustment in place during installation. Is that really needed? Somebody already reinstall an used clutch with SAC? Did you follow some special procedure?
tks
Jump to top M3novo is offline   Reply With Quote
Old Fri, Aug-03-2012, 12:48:37 AM   #2
M3novo
Default Re: Reinstall used OEM clutch with SAC
Please help....
Old Fri, Aug-03-2012, 03:30:36 PM   #3
FrumpyBF
Reputation: 0 FrumpyBF is on a distinguished road
http://forum.e46fanatics.com/showthread.php?t=629140
Is that helpful?
Jump to top FrumpyBF is offline   Reply With Quote
Old Sun, Aug-05-2012, 04:13:01 AM   #4
M3novo
so looks like if I am just reinstalling the same old plate and clutch I don't need to reset the plate.
tks
Discussing Reinstall used OEM clutch with SAC in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
