Old Fri, Jul-20-2012, 04:40:16 PM   #1
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Cool DIY: Oil pan removal + engine mounts
Ok so here we go.
This DIY is useful when you've dropped something inside your engine (for example a wonderful vanos tab) and now have to fish it out. It also covers engine mounts as I changed them while I was down there.
In part it's a continuation of the previous DIY: Vanos and bolts, as you will have to do this one if in the Vanos one you dropped something into the engine. This is why I recommend you block every nook and cranny with rags... trust me.
This was a very frustrating job, but mainly because I was an idiot and tried to take shortcuts. I didn't want to drop the subframe brace and tried to work around it. DO NOT DO THIS. Do it the right way which is explained here, it's much quicker and you won't go
I used a car lift at home for this. It isn't necessary, but it does make things easier.
We will not touch the timing at any point, so there's no need to pop the valve cover off.
Disclaimer: These instructions are what I did. In no way does this guarantee you similar results. Opening your engine and fooling around with the timing can damage the car, the engine and you.
If you plan on following these steps, read the DIY several times to become familiar with it before starting.
Note 1: This won't be as thorough as the Vanos DIY, simply because I had the M dismounted for almost a month while I worked on it in my 'spare time' (during exams, not so much!) and by the time I finished I reaaaally wanted to turn it on
Note 2: I don't mention any part numbers in this DIY. I get all my parts through Mike Kent at thebmwpartstore and never have to look up PNs, so I don't know what they are.
Note 3: I don't post the torque values because I didn't use a torque wrench and don't have access to the TIS or the Bentley manual. Even if I did, I don't trust an uncalibrated torque wrench with my engine parts, I would prefer using blue loctite if a bolt is keeping me up at night.
As a general guideline, bolts marked 8.8 are weaklings and will break or strip with any hint of 'tight', so be careful with them. They're usually threaded into aluminum or iron and that will not take much pressure before stripping.
Note 4: the bolts that hold the oil pan are garbage, 8.8 rated. I bought an entire new set and as some of the other big bolts I opened up were corroded I also got new ones. This isn't necessary but makes me happy, so I do it.
Note 5: there are a few different lengths of bolts that are involved in this. I suggest you take a pic every time you remove a bolt so you know what goes where.
Failure do to so will result in multiple attempts at putting bolts of different lengths into holes where they thread but they are too short/long
Note 6: this DIY calls for disassembling a lot of parts. It seems tedious and perhaps unnecessary, but I first tried to just crack open the oil pan to fish out the tabs and I cannot stress it enough: DO NOT DO THIS. Ask me why I know
Note 7: although one could think by looking at the oil pan from the outside that you can fish things out of the oil pan by dismounting the circular part on the bottom of the oil pan, in reality this is not so. The oil pan has all kinds of surfaces in it and will not allow access. Ask me why I know
REMOVING PLASTIC UNDERBODY TRAY
As soon as you get under the car you'll notice a black plastic tray which goes right under the engine. We want to remove this. I bought new bolts as the old ones were severely damaged.
In this first pic we see the center jacking point again
REMOVING FAN SHROUD + FAN + OIL COOLER
You'll notice the fan shroud gets in your way constantly. After removing it here I will not reinstall it, it takes way too long to mount/dismount this thing every time I open the Vanos up.
It's held on by 4 torx screws, two in the top, two in the bottom.
The shroud and the fan need to be removed at the same time. You'll notice they interfere in each others ways and are quite annoying. The oil cooler also manages to get in the way, but unlike the other two it's quite simple to remove.
To make our lives more interesting, BMW engineers decided to put a part of the shroud (a small part on the right) in between a cooling tube. This means it can't be removed and just stays there annoying you as you try to remove the fan shroud. I suggest you cut a portion out to be able to install/uninstall at will.
One
Two
Three
Four
The oil cooler is also held on by four bolts, two per side
Hold the oil cooler onto the car with a cord so it doesn't bend too much
Now the shroud will be loose but it still won't come out as the fan is blocking it.
There's a special tool to remove this but I prefer the following method. Get a 1 1/4 open ended wrench.
Place it on the fan nut
Hammering time! We want to move the wrench clockwise. The pulleys make it hard to move in that direction, so by hammering it we'll get it loose. It usually takes several whacks and I suggest you first look at the path where you'll be hammering to avoid breaking stuff.
Success! However the fan is still stuck because of the shroud.
We disconnect the wiring harness from the fan shroud
And now we jiggle the shroud and fan around until we can take it out. The fan comes out through the top
And the shroud through the bottom
Now there's just that little piece of shroud that's held on by the cooling pipes
I used a hacksaw. If you do it like I did it you'll still be able to reinstall and use it. There's a push-pin on there to fasten it to the shroud, you don't want to saw it off.
REMOVING ALUMINUM PLATE
Unfortunately I don't have any pics of this.
When you get under the car you can see the plastic plate under the engine and another plate that's shiny (aluminum) that comes right after it.
This plate is held on by 10-12 bolts which are supposed to be one-time use. Many reuse them, but to each their own.
Remove all the bolts and the plate comes right off. This might be a good time to clean it as it can get dirty.
Remember that once this plate has been removed you can't drive the car until it's reinstalled. Obviously I wouldn't jack it up/down either once removed.
CAR LIFT/JACKSTANDS
If you have a lift this is very easy. Here's a pic of my brother and I.
REMOVE FRONT WHEELS
This will give you more space to work and lessen the load on the front subframe once we start remove the subframe brace
DISMOUNT PASSENGER SIDE XENON LEVEL SENSOR
This is on the passenger side and it attaches the chassis to the passenger FCA. Remove it as when we drop the FCA we'll break it
EMPTY ENGINE OIL
We don't want to dismount an oil pan that's brimming with oil. You do this by loosening a single bolt. Use care when rethreading as it's not a strong one.
This picture shows the center area of the oil pan removed. Ignore it.
ENGINE SUPPORT
This is the most important part. Go to Harbor Freight (or your preferred shop for one-use products) and buy this engine support. It's $60 and the only way to do this properly.
You support it on the sides of the engine bay as seen here
A chain is included in the box. You wrap it around the thermostat or you can insert the hook directly into the thermostat housing
As I don't trust these cheap things very much I attached the second hook for additional safety
Now, turn the nuts attached to the hooks on the engine so it 'lifts' the engine ever so slightly. Later on we will have to lift it more, I recall around 10mm.
UNBOLT TRANNY BOLTS
There are 3 bolts that go from the tranny to the oil pan. We will remove all of them.
UNBOLT OIL PAN BOLTS HIDDEN BY TRANNY
Here you can see two holes where there are bolts. Remove them. [Ignore the open part of the oil pan, that isn't necessary]
DISMOUNT STEERING GUIBO/COUPLER
This can be a good time to replace it if it's necessary. This bolt probably has red loctite on it. If it doesn't, when you reinstall make sure to put some on. You do not want to lose steering by accident!
It uses a torx female or you can just use a 8MM socket which also works.
DISMOUNT STEERING RACK
This is held on by two long bolts that you see attached to the subframe brace that go through it and are held on the top by two bolts. You'll need open ended wrenches for the top.
It fits 'inside' the subframe place. Once you remove the bolts you can slide it out.
Once loosened it's still attached to the PS pump and reservoir so it won't just move out of the way happily.
Placing undue pressure on the hoses that connect it to the car will make your steering rack very unhappy. I don't recommend it as those pipes are expensive.
Instead, unbolt the various banjo connectors which you see are causing the problem. PS liquid will leak out.
DISMOUNT FRONT SWAY BAR
You don't have to remove the endlinks, just undo the 2 bolts per side that hold it to the chassis.
It will just hang lower as it's still attached by endlinks
DISMOUNT FCAs
It isn't necessary to dismount them fully, just these bolts on each side like if we were replacing bushings. Not a bad time to do this BTW
REMOVE SERPENTINE BELT
Next we remove the serpentine belt that attaches to the PS pump.
To do this, use a torx head to de-tense the tensioner and remove the belt.
There we go
DISMOUNT PS PUMP + ASSOCIATED HARDWARE
This is necessary as there's an oil pan bolt which can only be accessed once this is removed.
The pump is held on by two bolts which are on its top side. Notice those bolts are 8.8. What does this mean? Don't tighten them like if they were a component of a bridge when reinstalling.
When you remove both bolts it will fall down and place undue stress on the pipes. Disconnect the banjo bolts to avoid destroying your PS system.
I also held it up using an octopus which I attached to the top of the radiator
You can also dismount the this part, which holds one of the PS lines in place and also conveniently blocks access to a couple bolts on the engine pan.
DISMOUNT SUBFRAME BRACE
This is why you need the engine support. Once this part is out the engine would be relatively free to drop to the floor. I say relatively because it's still partially attached to the tranny.
It's held on by two really fat bolts per side.
Aditionally, there's another smaller nut on each side which connects to your engine mounts. Remove them. This way the engine mounts will stay connected to the chassis.
Once the small nut is removed, completely remove the two big bolts on each side
The subframe will come right down
DISMOUNT OIL BREATHER (AKA pipe that goes from the mainfold to the oil pan)
You just pop this off both sides. Mine looked like it wasn't happy, so I bought a new one.
DISMOUNT DIPSTICK TUBE
Only on the bottom of the engine. You can dismount the entire thing as it will be easier to reinstall the oil pan like that.
The dipstick's entrance to the oil pan is supported by a single nut. Remove it and you should be able to remove the dipstick tube.
By the way, this is a possible source of water entering the engine. It's not 100% sealed so be careful with those puddles!
REMOVE OIL LEVEL SENSOR CONNECTOR
Here you also see how you'd replace it if it's faulty: just undo those 3 bolts and it comes right out. Again, ignore that center part that's dismounted as it isn't necessary.
DISMOUNT ENGINE OIL RETURN LINE
This is that hateful banjo bolt you have to dismount when you take out the valve cover. It's on the passenger side of the engine.
All you have to do is loosen the crimp-style connector you see in the pic. Later on you can reuse it.
REMOVE ALL OIL PAN BOLTS
There are 20 if I remember correctly. Remove them and note which long ones go where. There are two which are much longer, but just in the little ones there are two different lengths.
Once you've dismounted them all the oil pan should come off. If it doesn't, you've forgotten a bolt. Don't go apesh!t trying to pull it off, those 8.8 POS bolts will rip out
Now you should be able to easily fish out whatever you dropped in here in the first place.
A note of caution: the oil pan design changed sometime during the M3 run. This means that if you break it you need to update other parts too, with a cost approaching $1000.
This is what the evil oil pan looks like once dismounted
And this allowed me to find:
PICS OF THE ENGINE'S BOTTOM END
Once here, if you listen carefully you'll hear the rod bearings saying 'change me, change me'. I wanted to, but I had been M-less for almost a month and had had enough.
I will come back and do another DIY of the rod bearing change, it can't be that hard and as our cars are getting older it's a smart thing to do.
The oil pump!
ENGINE MOUNTS
I hadn't planned to do this, but I had previously observed that my engine mounts were 'not quite 100%'.
I considered the RE ones, but they told me they'd drive me nuts if used on a DD so I went back to OEM.
You may (and probably will) have to raise the engine a bit so these fit. You can do it through trial and error, just raise a bit, see if the subframe will fit on, if it doesn't raise a bit more. Remember, we're replacing old, smashed up engine mounts and they new ones are thicker.
Once you remove the front subframe brace as explained above you can see the engine mounts hanging around
The mounts are held on by a single bolt each. You can access it with your hands and with a socket wrench.
A quick comparison to the new ones shows they really were on their way out. This is a 2002 M3 with 103k.
We borrow the shield from the oil passenger side one and put it onto the new one we'll put in the passenger side. This is designed to protect it from the headers which are nearby.
Both engine mounts are identical. The ones you take off may not be though, as the passenger side one was more 'smooshed' than the drivers side.
You put the new ones in in the same way as the old ones. They use poke-yoke so it's hard to do it wrong.
Finally, a sneak preview of what it will look like once you mount it back up:
REINSTALL IT ALL FOLLOWING THE REVERSE ORDER
You will have to replace the oil pan gasket and use RTV sealant all around it.
I put a layer of RTV on the top of the oil pan gasket and 'stuck it' to the engine, then applied another layer of RTV to the bottom part of the gasket that mates with the oil pan. This way I was free to move the oil pan (which you'll have to do quite a bit to reinstall) without worrying about the gasket.
Mind you I did not wait for the RTV to dry on the top or the bottom.
Old Fri, Jul-20-2012, 04:40:57 PM   #2
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Default Re: DIY: Oil pan removal + engine mounts
To only swap engine mounts, complete the steps outlined in:
CAR LIFT/JACKSTANDS
REMOVE FRONT WHEELS
(skip a step)
ENGINE SUPPORT
(skip a step)
DISMOUNT FCAs
(skip a step)
(skip a step)
(skip a step)
(skip a step)
(skip a step)
(skip a step)
(skip a step)
ENGINE MOUNTS
Old Fri, Jul-20-2012, 04:41:18 PM   #3
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Reserved 2
Old Fri, Jul-20-2012, 05:14:47 PM   #4
chalaka
Reputation: 0 chalaka is on a distinguished road
Taiwan
Great write up!!! thanks for taking the time to share this .. i am sure i will come back to this article when the time comes
Jump to top chalaka is offline   Reply With Quote
Old Fri, Jul-20-2012, 05:23:55 PM   #5
akashyap
akashyap's Avatar
Reputation: 0 akashyap is on a distinguished road
Thanks man. I will be using this in the future.
M3
CDV Delete, Auto Solutions 30%, SGT Coilovers, TopSpeed Exhaust, APEX EC-7
X5M
Stock
Jump to top akashyap is offline   Reply With Quote
Old Fri, Jul-20-2012, 05:47:37 PM   #6
see.m3.go
see.m3.go's Avatar
Reputation: 0 see.m3.go is on a distinguished road
Great DIY
2003 TiAg/Imola SMG to 6MT: AST 4100, Vorshlag Camber Plates, Status Gruppe Headers, Status Gruppe Muffler, Recaro SPG, VAC Floor Mounts, TiAg Kirk Roll bar, G-force 6pt Harnesses, Evolve Tune, TMS Power Pullies, AKG DTM Shifter, Macht Schnell Stage 1 Intake, Hardwired V1, MH Stud Conversion, APEX ARC-8, AKG 75D Subframe Bushings, 95A Diff Bushings, BMW Motorsport 4.10 diff
My Journal
Jump to top see.m3.go is offline   Reply With Quote
Old Fri, Jul-20-2012, 05:52:35 PM   #7
///M3Fresh
Motorsport
///M3Fresh's Avatar
Reputation: 0 ///M3Fresh is on a distinguished road
Great Write up man!! I didnt read every little detail but I dont think I saw that you mentioned that you got the tap out? I am assuming you didnt do the work to do the DIY and you were trying to get the exhaust tab out of the pan?
CLICK
Jump to top ///M3Fresh is offline   Reply With Quote
Old Fri, Jul-20-2012, 06:08:45 PM   #8
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Originally Posted by see.m3.go View Post
Great DIY
You're welcome guys, I hope it's useful when the time comes to open the oil pan up hehe
Thanks
Are you referring to the tab? I had already fished one out by cracking the oil pan open, but I was missing one which I just couldn't find.
In the end, taking the entire thing off was orders of magnitude easier than the letsnotdismountthings approach I had been using earlier.
By taking the whole thing off I found the second tab I'll include a pic in the DIY hehe
Old Fri, Jul-20-2012, 06:14:06 PM   #9
blatant
///Mthusiast
Reputation: 0 blatant is on a distinguished road
Great writeups! I appreciate you taking the time to take the pics and go step by step. They are definitely very helpful!
RK-Tune | Alpha-N | Dyno here-> here
Jump to top blatant is offline   Reply With Quote
Old Fri, Jul-20-2012, 06:25:45 PM   #10
nippiexfam
Reputation: 0 nippiexfam is on a distinguished road
thank you for taking the time for this detailed writeup!
Jump to top nippiexfam is offline   Reply With Quote
Discussing DIY: Oil pan removal + engine mounts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
