Naturally Agitated
Almost as touchy a subject as the existence of the God (Higgs-Boson) particle, the true winner of a French civil war, or the effectiveness of nuclear proliferation in the middle east, is that of E46 ///M3 brake bias.
I aim to clear the confusion by posting rationale, equations, diagrams, and sample calculations for consumption en masse with respect only to the braking system itself. I do not aim to explain how brakes work except with relation to the formulas themselves as it's been timelessly reiterated in just as many different ways all over the Internet. I also will not factor tire widths and the coefficient of friction between various tire and surface combinations. Though I should really start with rationale and theory, I'm going to get to the core of it all -- equations, because that's what everyone wants. Please do not hesitate to contact me by whatever means necessary with corrections to any part of this post - it is meant to serve as a reference! ---------------------------------------------- Dimensions required: (default E46 M3 specifications listed in parentheses)
Constants:
Variables:
The first element necessary to get started is the individual line pressures generated for both the front and rear pistons within the master cylinder, obtained by Equation 1: Equation 1: P = Fpedal / Apiston
The Force exerted by the pedal is obtained by Equation 2: Equation 2: Fpedal = Fleg · Ratiopedal
The Area of the master cylinder piston is obtained by Equation 3: Equation 3: Apiston = pi · rpiston2
Equation 4 is used to determine the radius from a given diameter: Equation 4: rpiston = Dpiston / 2
Brake torque generated at the wheel, individually Tf and Tr, is given by Equation 5: Equation 5: T{f,r} = P · Atotal · Reffective · cF
The total combined effective area of the caliper pistons is obtained by utilizing Equations 6, 7, 8 and 9 based on their respective caliper configurations (Floating: single-piston, Floating: 2-piston, Fixed: 4-piston, Fixed: 6-piston, Fixed: 8-piston): For a Floating: single piston caliper: Equation 6: Atotal = 2 · pi · rpiston2
For a Floating: 2-piston and Fixed: 4-piston caliper: Equation 7: Atotal = 2 · pi · (rpiston_12 + rpiston_22)
For a Fixed: 6-piston caliper: Equation 8: Atotal = 2 · pi · (rpiston_12 + rpiston_22 + rpiston_32)
For a Fixed: 8-piston caliper: Equation 9: Atotal = 2 · pi · (rpiston_12 + rpiston_22 + rpiston_32 + rpiston_42)
The effective radius is calculated using Equation 10: Equation 10: Reffective = rrotor - (wpad / 2)
Finally, Equation 11 gives the ratio of the front brake torque to that of the rear and is an index reflecting overall front:rear bias: Equation 11: Bias = Tf / Tr
Equation 12: % Biasfront = (Tf · 100%) / (Tf + Tr) % Biasrear = (Tr · 100%) / (Tf + Tr)*
Calculating Brake Bias || Brake Bias Cross Reference Chart || Custom SS Brake Line Build MK60 Fault Code Descriptions || Brake Fluid Specs DIY DME (ECU) TUNING: 6MT shift lights, sport mode memory, max-speed delimiter, dyno rev limit delete, rear O2 sensor delete, TunerPro checksum correction for E39 M5/E46 M3; modify rev limits, throttle response (sport/comfort), oil temp lights, SMG Auto fix w/gear swaps, and much more - PDF Howto Last edited by p0lar; Wed, Mar-27-2013 at 01:37:30 PM. |
Naturally Agitated
This is a quick chart I've constructed using Excel to illustrate the bias generated by various combinations of brake calipers/rotors. Please eMail me any additional caliper/rotor/pad combinations you would like to see crossed, and dimensions of the pad swept area, rotor diameter and piston size and count, if possible.
Edit | 08.02.2012: Added WilWood SL6R to front calipers with 325mm rotor Edit | 08.09.2012: Added C6 Z06 Corvette to front calipers with 355mm rotor Edit | 09.23.2012: Added a multitude of calipers. Included FULL bias, inclusive of master cylinder as well as % bias front/rear. Added deviation from standard/ZCP E46 M3 biases in terms of %F (front) or %R (rear) movement - this could give more data to the layman. This was a massive update, please review to let me know if there are any issues with my calculations or data presentation. Edit | 09.24.2012: Added 4-Piston RacingBrake caliper. Edit | 03.27.2013: Removed differentiation from OEM bias charts - they were causing way too much confusion. Added charts for differences in DSC (MK60 (>09/2002) vs DSC3 (<09/2002). Also added a small table to show calculated bias results for OEM E46 M3s and a warning for those who wish to downgrade to ZCP/CSL brakes on a DSC3-based system from <09/2002. FULL BIAS INCLUDING MASTER CYLINDER PISTON DIFFERENTIATION E46 M3 with MK60-based Master Cylinder (Front: 25mm, Rear: 22mm) (post-09/2002) E46 M3 with DSC3-based Master Cylinder (Front: 25mm, Rear: 20mm) (pre-09/2002) Warning: If you replace your pre-09/2002 DSC3-based OEM E46 M3 brakes with ZCP/CSL brakes, including the rear caliper, you are doing yourself a grand disservice. This causes an almost 5% shift in rear bias from the actual ZCP configuration, which was never designed for the DSC3-based master cylinder. Consider upgrading to a MK60-based master cylinder at the same time - the MK60-based power-booster may also be required.
Calculating Brake Bias || Brake Bias Cross Reference Chart || Custom SS Brake Line Build MK60 Fault Code Descriptions || Brake Fluid Specs DIY DME (ECU) TUNING: 6MT shift lights, sport mode memory, max-speed delimiter, dyno rev limit delete, rear O2 sensor delete, TunerPro checksum correction for E39 M5/E46 M3; modify rev limits, throttle response (sport/comfort), oil temp lights, SMG Auto fix w/gear swaps, and much more - PDF Howto Last edited by p0lar; Wed, Mar-27-2013 at 03:19:37 PM. |
Naturally Agitated
Here is a sample calculation for an E46 M3 with the competition package. I apologize for converting to SAE, but most people here will comprehend ft-lbs of torque much easier than metric units.
Front Master Cylinder Pressure Calculation: Equation 4: 25mm / 2 = 12.5 mm = rpiston Equation 3: (12.5 mm)2 * 3.141592 = 490.87375 mm2 = Apiston Equation 2: 150 lbs x 3 = 450 lbs = Fpedal Equation 1: 450 lbs / 490.87375 mm2 = 0.917 lbs/mm2 = 591 PSI = Pressure (front lines) Rear Master Cylinder Pressure Calculation: Equation 4: 22 mm / 2 = 11.0 mm = rpiston Equation 3: (11.0 mm)2 * 3.141592 = 380.1326 mm2 = Apiston Equation 2: 150 lbs x 3 = 450 lbs = Fpedal Equation 1: 450 lbs / 380.1326 mm2= 1.183 lbs/mm2. = 764 PSI = Pressure (rear lines) ---------------------------------------- Front Caliper Brake Torque Calculation: Equation 4: 60 mm / 2 = 30 mm = rpiston Equation 6: 2 * 3.141592 * 30 mm2 = 5655 mm2 = 56.55 cm2 = 8.77 in2 = Atotal Equation 4: 345 mm / 2 = 172.5 mm = rrotor Equation 10: 172.5 mm - (61 mm / 2) = 142 mm = 5.59 in = Reffective Equation 5: 591 PSI * 8.77 in2 * 5.59 in * 0.36 = 10430 in•lb / 12 in = 869 ft•lbs = T{f} Rear Caliper Brake Torque Calculation: Equation 4: 46 mm / 2 = 23 mm = rpiston Equation 6: 2 * 3.141592 * 23 mm2 = 3324 mm2 = 33.24 cm2 = 5.15 in2 = Atotal Equation 4: 328 mm / 2 = 164 mm = rrotor Equation 10: 164 mm - (54 mm / 2) = 137 mm = 5.39 in = Reffective Equation 5: 764 PSI * 5.15 in2 * 5.39 in * 0.36 = 7633 in•lb / 12 in = 636 ft•lbs = T{r} ---------------------------------------- Ratio of Front to Rear Torque Calculation: Equation 11: 869 ft.lbs. / 636 ft.lbs. = 1.37:1 F:R Ratio If you neglect line pressure, since that's usually constant unless someone changes their master cylinder, and simply look at the variables that are likely to change (rotor diameter, pad width, # & size of pistons, pad compound, etc), you would arrive at Equation 11 (modified): (8.77 in2 * 5.59 in * 0.36)/(5.15 in2 * 5.39 in * 0.36) = 1.77:1 F:R Ratio Theoretically, if the cF of the pads is also not changing, or is equivalent, rather, then that could also be dropped from the equation to give a relevant base point for comparison.
Calculating Brake Bias || Brake Bias Cross Reference Chart || Custom SS Brake Line Build MK60 Fault Code Descriptions || Brake Fluid Specs DIY DME (ECU) TUNING: 6MT shift lights, sport mode memory, max-speed delimiter, dyno rev limit delete, rear O2 sensor delete, TunerPro checksum correction for E39 M5/E46 M3; modify rev limits, throttle response (sport/comfort), oil temp lights, SMG Auto fix w/gear swaps, and much more - PDF Howto Last edited by p0lar; Wed, Mar-27-2013 at 01:51:12 PM. |
#4 |
If it ain't lightweight, it ain't the right weight.
![]() Location: LA/OC/SD
Very cool.
Current: 1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; 15" Cragar Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom 2.5" Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Monte Carlo Bar; 3200 lbs. ![]() 1995 M3; single 3" exhaust after cats; CF hood; Apex ARC-8 17x9" wheels; Conti DW 245 square; BC Racing Coilovers. SOLD: E46 M3 SMG; Intrax coilovers; ACPT CF DS; SS V1 Headers/Section 1; Zionsville Type 17 kit; VAC Ultra light pulley set; BMW MS 4.10; Evolve-R Tune; 2980 lbs.
#5 |
This is all Chinese to me, pretty cool though
Sent from my iPhone using Tapatalk |
#6 |
MCLA
Sweet! I wasn't aware that the CSL rear calipers had a larger diameter piston. Do you know how they compensate for that with the rest of the setup? Larger front rotor diameter?
MCLUB | Los Angeles |
#7 |
Mechanical? Engineer?
Hear! Hear!
Thanks for putting this up.
#8 |
Naturally Agitated
Well, someone had to do it. There's more coming -- much, much more.
I wish this forum code would let you add sub/superscripts...
Calculating Brake Bias || Brake Bias Cross Reference Chart || Custom SS Brake Line Build MK60 Fault Code Descriptions || Brake Fluid Specs DIY DME (ECU) TUNING: 6MT shift lights, sport mode memory, max-speed delimiter, dyno rev limit delete, rear O2 sensor delete, TunerPro checksum correction for E39 M5/E46 M3; modify rev limits, throttle response (sport/comfort), oil temp lights, SMG Auto fix w/gear swaps, and much more - PDF Howto Last edited by p0lar; Sat, Jul-07-2012 at 12:04:36 AM. |
#9 |
![]() Location: Ontario
Wow, thanks for maintaining this chart! The calculations shown here is great for figuring out your brake bias.
I found out the Wilwood setup I'm thinking of running will put me into 1.57:1 ratio, which is VERY rear biased Thankfully, if needed, I have a set of non-zcp rear calipers sitting around, and that will put me back into the 1.8:1 range. |
