Old Tue, Jun-26-2012, 07:49:11 PM   #1
M3 the dream
M3 the dream's Avatar
Reputation: 0 M3 the dream is on a distinguished road
Default 95 e36 m3 goes crazy over bumps and hard braking
Question, about the car hopefully someone can give me a place to start
as Im driving over a bumpy road or any pot hole pretty much anything to jerk the car the gas gauge drops to zero radio shuts off engine revs drop and all of this happens in less than a second and the car is normal, also have realized if i brake hard over uneven road almost 100% of the time this will happen, and then once again the car is fine after the engine corrects itself by that i mean, after the second of revs dropping the revs go up and down till the car is stable again, If you have any ideas please shoot them out, My opinion is it could be loose grounds (as this was in the past) but the car hasn't done it for months and they are all really tight or a problem with the fuel system
Jump to top M3 the dream is offline   Reply With Quote
Old Tue, Jun-26-2012, 08:01:10 PM   #2
enderw88
Craig
enderw88's Avatar
Reputation: 0 enderw88 is on a distinguished road
Default Re: 95 e36 m3 goes crazy over bumps and hard braking
What about the lights? Do the head lights dim, the interior lights as well? Is it essentially EVERY electrical item?
95 BMW M3 Current Project
Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel.
To Do: Overhaul rear suspension, front suspension
Tucson, AZ
Jump to top enderw88 is offline   Reply With Quote
Old Tue, Jun-26-2012, 08:09:21 PM   #3
M3 the dream
thats a good question about the headlights will have look out for that when driving at night also, that made me think of another thing at night with the center interior light to the middle position or auto position under hard braking that lights turns on and then off a few seconds later, ill have to be on the lookout for every electrical item when this happens again, narrow the problem
Old Tue, Jun-26-2012, 10:36:22 PM   #4
DLite
Reputation: 0 DLite is on a distinguished road
First easy check would be the ground straps and B+ junction point (the + jump connector) in the engine compartment. Make sure all those connections are clean and tight.
Jump to top DLite is offline   Reply With Quote
Old Tue, Jun-26-2012, 11:13:11 PM   #5
98///M3
98///M3's Avatar
Reputation: 0 98///M3 is on a distinguished road
First things first. Use your period key. I know it's overrated, but it will make your posts vastly more intelligible.
Second: you have an electrical issue, probably the type of problem where every little detail is pertinent. Tell us everything, we won't make (much) fun.
Third: the fact that your radio goes off and your fuel gauge drops tells me it's a main ground, not power connection. If your car is in gear, then the revs are not dropping, the tach is losing power and you are reading it as the 'revs' dropping.
Check your grounds. Get the ETM, if you don't have one already. You can find the locations in there. At any rate, Let us know.
1998 TiAg M3/4/5
Koni adjustables/Whiteline Sways/ARC-8/Pilot Super Sport
Jump to top 98///M3 is offline   Reply With Quote
Old Tue, Jun-26-2012, 11:13:40 PM   #6
enderw88
Craig
enderw88's Avatar
This. And remember just because you think your grounds were tight yesterday doesn't mean they are today. "Old German Sports Car"
Tucson, AZ
Old Tue, Jun-26-2012, 11:24:59 PM   #7
cstern
Reputation: 0 cstern is on a distinguished road
I had a similar problem. Hit a hard bump and the entire car would cut out for maybe a second, including the engine, but come right back. As strange as it is, a tail light was the problem, or at least the water trapped in it and behind it was.
My passenger tail stopped working shortly after this problem started. The entire back of the light was rusted and I found water trapped in the body behind it. I dried everything up and replaced the tail and no more problem since.
Jump to top cstern is offline   Reply With Quote
Old Wed, Jun-27-2012, 01:15:45 AM   #8
cmcon98
cmcon98's Avatar
Reputation: 0 cmcon98 is on a distinguished road
It sounds pretty elementary, and you've probably checked, but battery connections. It has to be electrical if multiple electrical items go dead at the same time the engine cuts out for a moment.
'99 M3 'vert, 5-speed, cosmos/sandbeige, bone stock except speakers. For now.
Jump to top cmcon98 is offline   Reply With Quote
Old Wed, Jun-27-2012, 01:21:41 AM   #9
M3 the dream
thanks alot so far lots and lots of great ideas for me to check out over the next days, i have alot of checking to do, also was driving today, and thought of another possible thing that is causing this, opinions on this, the screw that holds the battery in place broke so the battery has a bit of wiggle room, i remember messing with the battery and the terminal closest to the frame of the car in the compartment touched the metal and sparked, when the car was off, if this happened when the car is on could this possibly short the car out for that split second, cause under hard braking the battery could move forward and hit, not a electrical scientist just curious, once again thanks for the ideas and opinions really helpful
Old Wed, Jun-27-2012, 01:35:21 AM   #10
M3 the dream
Thanks a lot so far lots and lots of great ideas for me to check out over the next days. I have a lot of checking to do. Was driving today and thought of another possible thing that is causing this problem. The screw that holds the battery in place broke so the battery has a bit of wiggle room. I remember messing with the battery before and the terminal closest to the frame of the car in the compartment touched the metal and sparked when the car was off. If this happened when the car is on could this possibly short the car out for that split second. Under hard braking the battery could move forward and hit. Not a electrical scientist just curious. Once again thanks for the ideas and opinions really helpful. (updated grammatically correct version and not me rambling ideas with no end)
Discussing 95 e36 m3 goes crazy over bumps and hard braking in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
