| E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} |
Hey all,
I have a 2011 plate m3. What E would this be? Im not too sure? I want to get a performance exhaust for it but the akraprovic are silly prices of £4500 which I understand that you get what you pay for but I can't justify spending that! Would anyone recommend a good alternative that produces good results? And also comes with black or carbon tailpipe ends to match my existing black pipes? Thanks for reading John |
#2 | |
E36 M3 (sold) on to something new! E90 M3 Sedan Eisenmann race -Black lines -AA filter -IND cosmetics - KW Sleeve over -BC Forged HB29's- Macht Schnell Tow Strap- You bet Jerez its black and i'll never go back |
![]() Location: Livermore
As for "what E", did you mean the chasis designation?
e90=sedan e92=coupe e93=convertable (for 2008-present) |
#4 |
CSL (finished) inside
#5 |
Piraña Powered
![]() Location: Westchester/Boston/Windham
If all you want is power, Turner Test Pipes give you a lot of that for cheap.
Power is gained by removing CATS or going to HFCs Sound is gained by any aftermarket exhaust system. It's also possible to mod the stock system to get more sound
Vanos hub / bolts DIY Oil Pan Removal DIY Foam subframe reinforcement DIY Plastics Renewal DIY Spacer DIY ESS NA Tune Review Tools: -Shim kit -Timing tool -Engine support -Grainger foam applicator gun DIY stuff -Available in the NY/MA/NH area |
#6 |
There are many system's available for your application.. If you want sound you can just change out the mufflers or if you want power then you can replace the rear section pipping to gain some hp.. I also carry a flash for it also that will gain you some Hp & Tq..
Ahmed @ Vividracing Ph 480-966-3040 ext 231 AIM- Ahmed@vividracing.com Email-Ahmed@vividracing.com www.vividracing.com Best prices on Brembo, Volk Racing, Advan Racing, Stoptech, BBS, HRE, Vorsteiner, Agency power, Eisenmann, Meisterschaft, KW Suspension, K&N and a lot more!!! "Join Our VR Facebook Fan Page" use URL - http://www.facebook.com/vividracingcom |
