Old Sun, Jun-10-2012, 08:48:27 PM   #1
rwfisher
Reputation: 0 rwfisher is on a distinguished road
Default valve job DONE
First, kudos to everyone on M3 forum that has contributed to the DIY sections. Wouldn't have been possible without you.
A few observations:
1) The valve adjustment itself is the easiest part of this job. The real PITA is getting TO the valves.
2) Go ahead and drop the *($& fan out of there. I wasn't comfortable rotating the engine backwards (with my luck it probably would kill kittens somewhere on the planet). Get a 32 mm socket (<$9 at sears) and a 1/2 ratchet with a long handle to turn the engine. Worth the investment, I think.
3) Order the shim kit, or at least the BMW shim tool. Worth every penny.
4) Paper shop towels are your friends. Stuff them everywhere you don't want a shim (or crush washer) falling into the depths of your engine.
5) Before putting everything back together, compile a list of the torque settings...valve cover (cylinder cover according to the TIS...that makes me think of the head but whatever) banjo bolt is ~19 ft lbs, spark plugs are ~22 ft lbs, and I think that's all I used the torque wrench for.
6) I could have probably done better with a dedicated metric feeler gauge set, but you get what you pay for. I used all of the 2.24 and 2.28 mm shims from my set, and had to re-use some of my old shims. There were a few valves that I set to the minimum basically because I couldn't get a good enough measurement (or the correct shim) to hit the mid range.
Here's the final result:
Jump to top rwfisher is offline   Reply With Quote
Old Sun, Jun-10-2012, 08:52:35 PM   #2
Shimmy23
Addicted
Shimmy23's Avatar
Reputation: 0 Shimmy23 is on a distinguished road
Default Re: valve job DONE
good job bro! VA's are really easier than people think.
brandon
Jump to top Shimmy23 is offline   Reply With Quote
Old Sun, Jun-10-2012, 09:06:29 PM   #3
SliM3
SliM3's Avatar
Does BMW sell individual shims or do you have to buy the kit?
///M3 '06 Carbon Black
"Do or do not do, there is no try"
Old Sun, Jun-10-2012, 09:25:54 PM   #4
DriveSlow
DriveSlow's Avatar
Reputation: 0 DriveSlow is on a distinguished road
I'm going to be doing this soon, thanks for the tips!
NorthTexasBimmers:
http://www.facebook.com/NorthTexasBimmersClub
Jump to top DriveSlow is offline   Reply With Quote
Old Sun, Jun-10-2012, 09:41:28 PM   #5
robertg
Reputation: 0 robertg is on a distinguished road
You can buy them separate, I think they are under $5.00. A kit will only pay for itself if you are doing several cars. I did mine yesterday and didn't have to change one. A couple of the exhaust valves were +0.0005" over spec, but I'm not going to worry about it. I was quoted $1,500.00 to do it and it took me three hours. If I do it again I'm not even going to change gaskets.
Jump to top robertg is offline   Reply With Quote
Old Mon, Jun-11-2012, 01:05:48 AM   #6
stash1
I called Tischer BMW and 1 other local dealer the other day, & both refused to sell me shims separately! Total BS!
'04 AW/IR...Not Stock
Old Mon, Jun-11-2012, 01:12:10 AM   #7
stash1
Originally Posted by JWB1980 View Post
They sell individual shims.. get them to refill my kit. I have not used but the the standard ones mentioned here except when I do Camshaft swaps, then it changes the whole game and you will use ones you have never used before.
Who is 'they' because as I just posted, both Tischer & another local dealer, refused to sell me individual shims!
Old Mon, Jun-11-2012, 01:34:41 AM   #8
dafoe
Dafoe
I was able to add them to my cart on Tischer's site. But, having dealt with Tischer in person, I can easily see one of them stating something like that, Stan. The last few times I was there their customer service was... lets just say less than stellar.
I ordered parts from Turner on my Ipad in their parking lot. I only use them if they are last resort.
The part numbers for those shims we need are...
2.08 - 11 34 7 832 279
2.04 - 11 34 7 832 278
Mods: Frank Smith Custom Tune, Evolve Airbox, SGT swaintech coated headers, OEM Euro Cats, Larini exhaust, 3.91 gears, Turner Pulleys, TCKline S/A coilovers, H&R front sway Bar, Rear Sway Bar, RE Strut bar, PowerFlex RTAB's, Apex ARC-8's, Turner subframe reinforcement, Michelin PSS, Laser Interceptor, Alcantara steering wheel, Dynavin V5
Old Mon, Jun-11-2012, 02:08:14 AM   #9
stash1
Thanx bro, yeah, I ordered from Tischer on-line earlier today...should have been more clear in my posts...just PISSED that the farker told me over the phone Friday that I couldn't order individual shims! I mean, what's the difference?!?! Either you can, or you can't, whether it's on-line, or over the phone! I'm going to follow up w/the parts dept. tomorrow morning!
EDIT: Sorry for the threadjack OP! Nice job btw!
Old Mon, Jun-11-2012, 02:30:21 AM   #10
BTM
Reputation: 0 BTM is on a distinguished road
As said before, just order by the part number. Here they are:
1.72MM 11 34 7 832 270
1.76MM 11 34 7 832 271
1.80MM 11 34 7 832 272
1.84MM 11 34 7 832 273
1.88MM 11 34 7 832 274
1.92MM 11 34 7 832 275
1.96MM 11 34 7 832 276
2.00MM 11 34 7 832 277
2.04MM 11 34 7 832 278
2.08MM 11 34 7 832 279
2.12MM 11 34 7 832 280
2.16MM 11 34 7 832 281
2.20MM 11 34 7 832 282
2.24MM 11 34 7 832 283
2.28MM 11 34 7 832 284
2.32MM 11 34 7 832 285
2.36MM 11 34 7 832 286
2.40MM 11 34 7 832 287
2.44MM 11 34 7 832 288
2.48MM 11 34 7 832 289
2.52MM 11 34 7 832 290
Jump to top BTM is offline   Reply With Quote
Discussing valve job DONE in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
