Old Wed, Apr-04-2012, 10:32:00 PM   #21
jlcool007
Reputation: 0 jlcool007 is on a distinguished road
Default Re: E46 M3: EVAP (Charcoal Canister) Delete DIY
i freaking love it when I pull into my shop and my mech goes "wtf have you done now that i don't know about" after he sees a bunch of non-oe silicone braided tube everywhere hah.
ever have to clean these canisters out?
Jump to top jlcool007 is offline   Reply With Quote
Old Wed, Apr-04-2012, 10:39:35 PM   #22
Tarmac_E36_M3
If it ain't lightweight, it ain't the right weight.
Tarmac_E36_M3's Avatar
Reputation: 0 Tarmac_E36_M3 is on a distinguished road
Haha, that's funny.
The canisters, as in the charcoal canister? No, first time I've handled one was removing it.
Current: 1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; 15" Cragar Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom 2.5" Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Monte Carlo Bar; 3200 lbs.
1995 M3; single 3" exhaust after cats; CF hood; Apex ARC-8 17x9" wheels; Conti DW 245 square; BC Racing Coilovers.
SOLD: E46 M3 SMG; Intrax coilovers; ACPT CF DS; SS V1 Headers/Section 1; Zionsville Type 17 kit; VAC Ultra light pulley set; BMW MS 4.10; Evolve-R Tune; 2980 lbs.
Jump to top Tarmac_E36_M3 is offline   Reply With Quote
Old Sun, Oct-28-2012, 05:36:25 PM   #23
delirium45
Bottom Feeder
Reputation: 0 delirium45 is on a distinguished road
question for those that have successfully removed the canister:
which is in and which is out ?
my assumption is that the larger black hose close to the blue hose flows out of the canister (assumed this because the blue hose goes to the intake so it must be under suction and i assume that both lines on this part of the canister must be under same pressure.
the other black line that is more remotely mounted goes up to open air... so it is probably an inlet tube that goes to a pre-canister filter.
is this correct ?
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
Thanks Sponsors: SCR Performance
Jump to top delirium45 is offline   Reply With Quote
Old Sun, Oct-28-2012, 09:26:10 PM   #24
Tarmac_E36_M3
I don't recall to be honest. What I did was turn on the car and felt which once was sucking my finger in a bit (very weak vacuum) and that's how I figured it out.
Old Sun, Oct-28-2012, 11:31:47 PM   #25
disapr
Drop a gear and...
Reputation: 0 disapr is on a distinguished road
is this correct ?
The one connected to the pump is the "in" line from the evap tank. The other line is an open air exit behind the wheel liner.
2012 SVT Raptor (Tow & Play)
2004 M3 (Race)
--Build Thread--
Jump to top disapr is offline   Reply With Quote
Old Mon, Oct-29-2012, 12:05:27 AM   #26
delirium45
Bottom Feeder
right, so by 'in' do you mean in-- into the evap or in-- into the canister ?
_ Garrett
Old Mon, Oct-29-2012, 01:56:04 PM   #27
disapr
Drop a gear and...
Take a look at this diagram. Line 15 is an open air exhaust behind the wheel liner. Line 3 connects to the expansion tank and this is a vacuum line from the charcoal filter apparatus. Item 6 on the exp tank is where the vent line from the fuel tank is connected.
To remove the charcoal canister you only need to filter line 3 and line 15 can be left alone or removed. Ultimately removing the wheel liner is your best bet for cleanly completing this project.
2004 M3 (Race)
--Build Thread--
Old Mon, Oct-29-2012, 02:25:06 PM   #28
Itsablurr
Reputation: 0 Itsablurr is on a distinguished road
Dumb (and illegal) modification for a car that sees street driving. There is no power to be gained, and "weight loss" of the canister assembly is inconsequential.
The only measurable change is that you are now venting more combustibles/pollutants to the atmosphere.
2003.5 M3: BBS LM - TC Kline - Vorshlag - Borla
2001 S54 M Roadster: BBS Motorsport 3pc Magnesium - TC Kline - 3.73LSD - HMS Rollbar - Stromung
1967 Chevelle 2dr Coupe: Cragar S/S - Dynomax
Jump to top Itsablurr is offline   Reply With Quote
Old Mon, Oct-29-2012, 02:46:00 PM   #29
delirium45
Bottom Feeder
Thanks for the feedback, i have already found the same about #15 and have already removed it... i was just at the point of trying to install the 1-way filter correctly for the stub of #3 that remains.
i documented my progress here:
http://www.m3forum.net/m3forum/showp...&postcount=239
you do realize that my car is a dedicated track car and that the removal of this device is to facilitate aero work. so this modification is neither dumb or illegal for this purpose... is there a reason you even posted in this thread ?
_ Garrett
Old Mon, Oct-29-2012, 02:56:43 PM   #30
Itsablurr
In that case, I am not speaking to you (as you would see from how I qualified my statement within the frame of street cars). The reason I posted in this thread was because on the previous page, there was uncertainty to the street legality of removing this piece of equipment, as well as there being a number of 'hardcore' street cars in this thread, not to mention street cars populating the majority of this corner of the forum. Settle down, Francis.
It would be sad for some poor uninformed individual to wander into the thread, see a 'mod' that yields no functional benefit in a street setting, then risk getting intimate with the long arm of the law.
Discussing E46 M3: EVAP (Charcoal Canister) Delete DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
