Old Fri, Mar-23-2012, 08:20:13 PM   #1
Boglow
Boglow's Avatar
Reputation: 0 Boglow is on a distinguished road
Default windshield wiper fluid won't spray
anyone know any DIY fixes?
or what could cost the problem? when i push the lever back it just wipes but no fluids spray out.
it's annoying doesn't affect the car thou.
Current rides
04 E46 AW M3 SMG Dinan stg 3
12 Mini Cooper S (the Mrs')
Jump to top Boglow is offline   Reply With Quote
Old Fri, Mar-23-2012, 08:22:27 PM   #2
m3freak86
JERSEY STRONG
m3freak86's Avatar
Reputation: 0 m3freak86 is on a distinguished road
Default Re: windshield wiper fluid won't spray
First, I would check to see if you have washer fluid in there. However, it should throw a light on the dash if you were low. Check under the hood where the connections are for the washer nozzles. One or both of the tubes may have come off.
2013 SWP Subaru WRX Hatch (gone)
WRX Journal
2004 Carbon Black///M3 (gone)
Mods and Specs
My Exhaust Obsession
My Journal
Jump to top m3freak86 is offline   Reply With Quote
Old Fri, Mar-23-2012, 08:32:17 PM   #3
silvr333
Reputation: 0 silvr333 is on a distinguished road
The tank for the washer fluid is located infront of the passenger side wheel take a look at it the pump might have popped out.
Dinan Exhaust, Stage 2 Software, Dinan SSK
Jump to top silvr333 is offline   Reply With Quote
Old Fri, Mar-23-2012, 08:42:23 PM   #4
Boglow
Boglow's Avatar
no lights on the dash. so must have some fluids in there.
Current rides
Old Fri, Mar-23-2012, 09:27:28 PM   #5
usdmej
if you can't hear the motor pumping then its the motor
Jump to top usdmej is offline   Reply With Quote
Old Fri, Mar-23-2012, 09:30:15 PM   #6
TPLGT
I'm Your Drinkin' Buddy
TPLGT's Avatar
Reputation: 0 TPLGT is on a distinguished road
Probably the motor. Replaced mine a few months ago...pretty easy. Search for the DIY. GL...
Jump to top TPLGT is offline   Reply With Quote
Old Fri, Mar-23-2012, 09:38:29 PM   #7
deilenberger
deilenberger's Avatar
Motor or kinked hose. The hose likes to kink where it makes the 180 degree bend by the starboard side hood hinge assembly. It has a very specific routing there in order to avoid kinks. I've added some of the corrugated wiring loom to the outside of it to keep it from making too sharp a bend when the hood is closed when I've had a troublesome one. Rather common BMW problem.. mebbe we should start a Class-Action-Lawsuit? Kidding..
Old Fri, Mar-23-2012, 10:09:03 PM   #8
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
remove passenger side plastic wheel well liner (?) and you will see the windshield wiper fluid reservoir and the pump. If you don't hear the pump running, then it's the pump.
Jump to top kkamakasi is offline   Reply With Quote
Old Fri, Mar-23-2012, 10:12:33 PM   #9
YGOSLO03
YGOSLO03's Avatar
Reputation: 0 YGOSLO03 is on a distinguished road
The connector to my windshield washer pump was broke in half when I got my M. I ordered the replacement connectors and wires and it worked. Same thing for my outside air temp sensor, except the whole sensor was missing. Pretty easy to fix. Now I just need to fix the weak stream on the driverside sprayer.
Full Black Interior For Sale
Carbon Black, meet Imola Red
Jump to top YGOSLO03 is offline   Reply With Quote
Discussing windshield wiper fluid won't spray in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
