| M3 Track: Racing and DE Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! |
#21 |
HellaFunctional
![]() Location: So. Cal
I'm right around 12.75" front and rear, no complaints on the track or street!
#22 |
![]() Location: Vienna, VA
Chassis height measurements made with use of fenders is not very accurate, for a couple of reasons. One is that the fender in the rear is lower on the body line than the front, naturally the rear measurement will be shorter if you measure to there. Second is that if/when your car was in an accident, the new fender may be higher or lower when replaced. You cannot get repeatability, which is important. If you want proper chassis ride heights, pick a hard point on the chassis and measure to the ground, on a flat surface. If you run 12.75 F and R, by measuring to the fender, you are actually not running any rake at all. The rear will be lower than the front. There is no such thing as "negative rake".
Nick Real race cars don't have roofs or fenders.
#23 |
If it ain't lightweight, it ain't the right weight.
![]() Location: LA/OC/SD
Where is a point you would recommend measuring from?
Current: 1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; 15" Cragar Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom 2.5" Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Monte Carlo Bar; 3200 lbs. ![]() 1995 M3; single 3" exhaust after cats; CF hood; Apex ARC-8 17x9" wheels; Conti DW 245 square; BC Racing Coilovers. SOLD: E46 M3 SMG; Intrax coilovers; ACPT CF DS; SS V1 Headers/Section 1; Zionsville Type 17 kit; VAC Ultra light pulley set; BMW MS 4.10; Evolve-R Tune; 2980 lbs.
#24 |
Obliging
![]() Location: Hollywood Hills, Poorifornia
points below the rocker panel or jack pads.
There is no need to be upset...
#25 | |
"Visor down for business"
![]() Location: Little Rock, AR
Sounds logical
#26 |
Yup, that would work. Any hard point that you know will be the same each time you measure from it, to the ground/scale pad, etc.
I am not sure what the equivalent would be, it has been so long since I have set the ride heights on my M3 that I just cannot remember. You can use the 13/13.5 as your starting point. Then get new measurements from a better place and use them moving forward.
#27 |
Seven years of college, down the drain . . . .
![]() Location: Santa Clarita
Fine as long as it hasn't 'stoved' in like mine (left rear). Fook'n design
"Molon Labe!" Democracy is two wolves and a lamb voting on what to have for dinner. Liberty is a well armed lamb contesting the vote. |
#28 |
Obliging
^^^ true, I moved a bit further inward to the frame
#29 |
Basically, if measured from the bottom/frame area, if both front and rear are the same height from the ground, its probably a good base height to start from?
#30 |
Yeah, maybe .5"of rake or so. You would have to call BW or someone like that and ask for baseline rake settings.
