E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
Looking to do my M3 over this spring, and I really want to go to a square setup. I know I am going to get the "do a search" but honestly the search function sucks and I've been researching this for days and can't find a definative answer. I am currently running OEM 18's which are 9" wide rear and 8" wide front correct? I have 225 tires up front and 255's in the rear. This car is my DD, ~10k miles a year.
My goal is either a 9.5" or 9" wide square setup, I really really love the look of 19's so I would like to go that route, but is the ride really much worse than the 18's? I am currently on OEM suspension, however I am most likely going to go with the Status Gruppe tuning coilover's with camber plates. Are camber plates are necessary for a 9.5" square setup for both 18's and 19" rims? Or just the 19's? I would like to get wheels with the same offset so I can rotate tires in the summer, although I understand spacers would be needed in the rear for this. I'm leaning towards the Sportline 19" CSL Reps 9.5" all around and wrapping them in Hankook Ventus RS-3's or Mich PSS at 265/30R19 with the SGT coilovers, 10MM spacers in the rear. Just unsure of the offset, if this will even fit, or if its too aggressive a setup for a DD. Any opinions, pictures of your setups, and advice is very much appreciated!
02 ///M3 Coupe 6MT |
Sponsored Links |
#2 | |
![]() Location: Charlotte
18" is the right way
any pics of your setup? You running OEM settings/no spacers?
#4 | |
Running OEM 18" squared with 12mm spacers in the rear. I need coils though.
#5 |
2004 E46 M3
![]() Location: Costa Mesa
If your going square you are doing it for track performance. If you are doing it for track performance, then there is no question go 18.
__________________ 2004 Mystic Blau Imola Rot ///M3 Coupe SMG Other Rides 73- 240z - L28 Block w e31 heads - prepping as a track toy 95- Legend Coupe - C32A5 block - totaled while parked 96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident |
#6 | |
donde esta mi pantalones?
![]() Location: Aventura
![]() Quote:
I was just about to ask if this car will see the track. If not, Im assuming you're trying to save money on tires? |
#7 | |
Heres a back shot of what it looks like. Getting ready to get back out to VIR
#8 |
◘ 18'' is the way to go!
2006 JB E46 ///M3 6MT Power: EVOLVE, ROUGE ENGINEERING, AGENCY POWER Suspension: KW, GROUND-CONTROL, TMS OUTS: VOLK [SQUARED], DOWNFORCE USA, ÜMNITZA, SCORZA, VORSTEINER, STRASSENTECH INS: AUTOPOWER, OMP HTE, VAC Swag;-) MFEST, PLATTE FORME A.G. |
#9 | |
Visor Down For Business
![]() Location: OC
Not to be a jerk, but clearly you didn't search. The square set up phenomenon has been the most discussed topic for the past year.
18's have more tire selections, cheaper in price, weigh less, more track oriented, and obviously look a touch smaller. You can fit a variety of square set ups on this car, 18's or 19's ranging from 18x9 - 18x10 & 19x9 - 19x10 respectively. Tire sizes can vary from 255/35 to 285/30 all around. Fitment depends on offset, ride height, and camber specs. Yes the Sportline's will fit with that set up you mentioned. OEM 18x9 Square ![]() Apex ARC-8 18x10 Square ![]() ZCP 19x9.5 Square ![]() How's that for not having to search? ![]()
E46 M3 Slicktop E70 X5 M Sport i3 RE Last edited by AP3X_FTW; Wed, Feb-22-2012 at 05:10:29 PM. |
#10 |
why are 18's better for the tack?
Bookmarks |
Thread Tools | |
Display Modes | |
