Old Wed, Feb-15-2012, 12:34:15 AM   #1
x18999
Reputation: 0 x18999 is on a distinguished road
Default 24 lb Injector brand
Hi all,
I'm currently searching for 24lb injectors and have searched the forums before starting this thread. So I understand that bosch injectors found in mustangs with the same part number can be used. But my question is this, can other brands be used? I'm trying to find a set of used injectors but want to make sure that they are compatible. Thanks.
Jump to top x18999 is offline   Reply With Quote
Old Wed, Feb-15-2012, 01:43:45 AM   #2
Default Re: 24 lb Injector brand
Any high impedence injectors with the body size to fit the rail spacing will work. They can be newer thin bodied plastic injectors.
Old Wed, Feb-15-2012, 01:55:52 AM   #3
x18999
Great, thanks for the quick response. Planning on getting rebuilt 24 lb injectors from 95 cobra.
Old Wed, Feb-15-2012, 01:08:39 PM   #4
Richardsperry
95 SC M3
Richardsperry's Avatar
I think those would be the Ford Motorsports injectors.
I'd have them cleaned and flow tested before I instaled them...
Old Wed, Feb-15-2012, 10:41:10 PM   #5
x18999
I've read that Mr. Injectors has a good price on cleaning. Any suggestions?
Old Thu, Feb-16-2012, 02:23:13 AM   #6
hcaleman
Reputation: 0 hcaleman is on a distinguished road
I used them, seemed fine to me. In the past I've found a local place with his same equipment, but I think I paid double his price.
Jump to top hcaleman is offline   Reply With Quote
Old Thu, Feb-16-2012, 02:33:00 AM   #7
Magic M3
Magic M3's Avatar
Reputation: 0 Magic M3 is on a distinguished road
OP: are you going to be using a tune that was mapped for bigger injectors? Also do you have other mods that necessitate more fuel flow. If this is all you are doing, do not expect a big change.
"What, that?....Oh, it's Stock....ish!"
Jump to top Magic M3 is offline   Reply With Quote
Old Thu, Feb-16-2012, 04:29:14 AM   #8
x18999
I will be getting cams, porsche 803 hfm, and tune as well.
Old Thu, Feb-16-2012, 01:38:28 PM   #9
Magic M3
Magic M3's Avatar
Now you are talking! I've got the same setup with a lightweight flywheel as well. What cams are you going with?
Old Thu, Feb-16-2012, 04:29:16 PM   #10
x18999
Most likely schrick 264/256 camshafts, although I am considering a slightly higher lift one. VAC has schrick 276/270 and that is very tempting. Do you have the 803 hfm or 809 and what software?
Discussing 24 lb Injector brand in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
