Old Wed, Feb-15-2012, 07:20:36 PM   #31
camdinans3
Resident Rabble Rouser
camdinans3's Avatar
Reputation: 0 camdinans3 is on a distinguished road
Default Re: winter maintenance and mods
Originally Posted by unclesam View Post
14psi with Dinan tune? You'll definitely need a new clutch/pp at that point though, yeah?
Do you know if the VF intake tube would work with the RMS aftercooler and Dinan/RMS bracket? It seems the VFE bracket is what limits people from stage II, but can that nifty VF intake tube be used? I think that piece really helps add to the OEM look of the SC kit.
oh no way on the dinan tune. the dinan tune is sufficent up to 9psi and thats it. Anything beyond 9psi will require 42lb/hr injectors, 3.5hfm and a new tune. I also have the UUC ltw flywheel and e34 M5 clutch, its been working well so far so when its not enough, its not enough. i'm not going to mess with it yet.
hhmmm that is a good question. to be completely honest, i have no idea. but looking at it
i dont see why it COULDNT work, but RMS makes an equivalent thermoplastic intake tube which would appear to work just as well, i mean my dinan intake tube works too
Andrew: AVUS 1995
///95 Supercharged Club
Jump to top camdinans3 is offline   Reply With Quote
Old Wed, Feb-15-2012, 07:54:14 PM   #32
I would not assume the VFE thermoplastic will fit a Dinan or RMS kit. If you have the VFE part or can borrow it, by all means test fit it. But I would not buy one hoping it will fit -- I would buy the RMS one that definitely fits. The VFE and Dinan/RMS brackets locate the blower differently and clearance gets really tight in that corner of the engine bay.
Old Wed, Feb-15-2012, 07:59:36 PM   #33
No, none of the VF parts will work. The VF kit has the charger clocked completely different and not as deep into that corner as RMS/Dinan. You would need everything from the RMS or Dinan kit to make it work.
Old Wed, Feb-15-2012, 08:00:32 PM   #34
camdinans3
camdinans3's Avatar
yeah no kidding even worse with the HID's i have in there.
Andrew: AVUS 1995
Old Wed, Feb-15-2012, 08:18:25 PM   #35
unclesam
unclesam's Avatar
Reputation: 0 unclesam is on a distinguished road
Thanks. I had a feeling they wouldn't match up, especially after taking a close look at how the s/c is oriented in there. Too bad.
with a grain of salt
Jump to top unclesam is offline   Reply With Quote
Old Wed, Feb-15-2012, 09:13:09 PM   #36
camdinans3
camdinans3's Avatar
Well ordered it but they are on back order so won't get it for a few weeks but doesn't really matter. Took me long enough to get around to ordering it though only like 3 years.
Andrew: AVUS 1995
Old Wed, Feb-15-2012, 09:58:57 PM   #37
I significantly hacked the rear of my HID Depo to fit the RMS thermoplastic. It was sad at the time, but 4 years later I have gotten over it and the light is still working fine.
Old Thu, Feb-16-2012, 01:36:15 PM   #38
camdinans3
camdinans3's Avatar
i bought extra backing plates to the HID's with the intention of hacking them up as well, only had to cut off a little but i fear my HID's will have the same fate as yours, oh well
building the oil cooler at the moment
rally road cap
AN10 fittings
braided lines
derale 180 degree thermo
cxracing heat exchanger (quality looks ok)
i thought about running a setrab core with a fan with a switch in the cabin but from what i've heard the oil coolers are very effective and will shed enough heat without the aid of a fan, but i'll monitor temps and add a fan at a later date if necessary. i'll probably end up upgrading the aftercooler heat exchanger at some point with the addition of a fan.
Andrew: AVUS 1995
Old Thu, Feb-16-2012, 01:40:56 PM   #39
M3n00b
2012 Formula 1 Game Champion!!!
M3n00b's Avatar
Car looks awesome andrew! avus
Originally Posted by camdinans3 View Post
Currently on 100% new suspension and am making a plan for the winter modifications i hope to accomplish in the next few months. Only thing i have done recently is swap out my rear door panels to ones out of a 99.
I am so confused. What rear doors?
2013 F1 Game:
Originally Posted by propchef View Post
Ferrari to Alonso: F**k the tires, full speed ahead.
Old Thu, Feb-16-2012, 02:42:31 PM   #40
camdinans3
camdinans3's Avatar
sorry, the rear panels, i bought rear seats out of a 99, and the cards looked out of place so i replaced those as well out of a 99. so its looking good even though no one sits back there
Andrew: AVUS 1995
Discussing winter maintenance and mods in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
