#11 | |
Mid-Atlantic ///M's
![]() 2002 Phoenix Yellow/Black M3 6Spd Manual Wheels: OEM Style 67 18" Squared Wrapped With 255/35 Michelin PSS tires Aesthetic: LED Angel Eyes, Painted Reflectors, Sharkfin Dummy, LED License Plate Lights, Custom Rear Seat Delete Exhaust: Custom OEM Muffler Suspension: Powerflex RTABS/FCABS/Sway Bar Bushings, TC Kline S/A Coilovers 600F/700R, Ground Control Race Camber Plates, Ground Control Adjustable End Links From Hampton Roads, VA? Email me at hrmowners@gmail.com for more information about the Hampton Roads ///M Owners Group. |
#12 |
The Captain
![]() Location: Cookeville
Hey Zach, quick question.
I just took about a fifty mile drive to see if I could get the car to spray coolant (as mentioned in the thread I started). I took B roads, driving, shall we say, spirited, and ended the trip on highways back into town. How long did it take you to notice your leak? I'm still hoping that maybe the issue has been addressed prior to my ownership, and they didn't clean up the mess left behind. Both upper and lower radiator hoses look somewhat fresh, ie. not the original parts, and I can still clearly read the sticker on the radiator fan itself. Any thoughts on that? I'll say it again, fantastic write-up!
![]() Eisenmann||Dynavin||Rogue||AP |
#13 | |
Mid-Atlantic ///M's
I noticed my leak probably 2-3 days after it became noticeable, meaning the visual evidence was there inside the engine bay in front of my eyes. Who knows, the water pump could have had a small leak before that and it was so minute that it wasnt spraying in the engine bay. I would say my leak probably occured within 1-2 weeks of having noticed it of when the pump actually became faulty. Edit: Come to think of it, I had the low coolant light come on once in November and I topped off what little bit of coolant was missing with BMW coolant. So in between Nov and Jan, there wasnt anything visually noticeable, but Im sure the water pump was starting to go then. Every now and then I would start the car and get belt squeal like bearings were bad in a pulley but I had replaced my pullies in May so I never thought anything of it...Just that it was a combination of the cold air and condensation on the belts.
![]() 2002 Phoenix Yellow/Black M3 6Spd Manual Wheels: OEM Style 67 18" Squared Wrapped With 255/35 Michelin PSS tires Aesthetic: LED Angel Eyes, Painted Reflectors, Sharkfin Dummy, LED License Plate Lights, Custom Rear Seat Delete Exhaust: Custom OEM Muffler Suspension: Powerflex RTABS/FCABS/Sway Bar Bushings, TC Kline S/A Coilovers 600F/700R, Ground Control Race Camber Plates, Ground Control Adjustable End Links From Hampton Roads, VA? Email me at hrmowners@gmail.com for more information about the Hampton Roads ///M Owners Group. Last edited by bimmerfan08; Sat, Jan-28-2012 at 10:51:46 PM. |
#14 |
The Captain
It does! You mentioned your pump had a stamp date on it, is this visible without pulling the pump out?
#15 | |
Mid-Atlantic ///M's
My old pump was stamped 12/01 and my new one was stamped 02/11. We'll see how long the new pump lasts. It would be nice to have it last the same time frame as the old pump. 10 years is something I can manage haha.
#16 |
The Captain
Well crap. Guess I'll just have to keep an eye on it for the next week or so. Still seeing no spike in temperature, even gradual. So hopefully my hypothesis is correct.
I'll quit cluttering this thread now lol. Thanks again, Zach!
#17 |
![]() Location: Austin
Bro thanks a lot for this one.
CDV Delete, Auto Solutions 30%, Koni Yellows, Vogtland Springs, TopSpeed Exhaust
#18 | |
Mid-Atlantic ///M's
No problem, glad I could help.
#19 | |
![]() Location: Bay Area
04 BMW M3 6spd - Alpine White/Black BBS LM w/ Michelin Pilot Super Sport's, Apex ARC-8 w/ Nitto NT-01's, TCKline D/A Coilovers, TCKline Camber plates, SPC Rear Trailing Arms, Reinforced Subframe, Brembo BBK (355mm front, 345mm rear), Rogue Engineering Transmission Mounts, Rogue Engineering RTAB's, Treehouse Racing FCAB's, SGT Headers, SGT Section 1, Dinan Exhaust, Vorsteiner V-CSL Bumper, Vorsteiner V-CSL Trunk, Vorsteiner V-CSL Diffuser, Kirk Racing Roll Bar, Recaro SPG, Scroth Profi 2 Harness |
#20 |
Mid-Atlantic ///M's
Probably in the summer or fall of this year. I meant to do them last time I did a valve adjustment.
