Old Tue, Jan-03-2012, 09:46:04 PM   #1
kihun
Reputation: 0 kihun is on a distinguished road
Default DIY: Flickering headlights, taillights, ground issue FIXED
Past few months, I had issues with my headlights flickering randomly and I was going nuts. Found out that it was ground issue that was caused in tail light section. I just went to pepboys real quick and decided to give it a try. so far so good but I still need to drive little more but here it is anyways.
stuff that you would need
0.250" blade receptacle
strip of size #18
electrical tape
utility knife
pliers
1. open your trunk and take the tail lights off. disconnect the wire and when you look at the wire, brown wire is the ground wire. it is the thickest one out of all the wires.
2. when you look at the the tali light wire, look at where brown wire is going. it should be going into #4 section and follow the metal part and attach receptacle on it. just like this
3. wire the #18 wire to receptacle and attach it to the tail light ground metal just like this.
4. after you did that, go back to trunk, slice open the brown wire and wire around the brown wire and don't forget to put electrical tape around it.
5. after that, just place back together.
Jump to top kihun is offline   Reply With Quote
Old Tue, Jan-03-2012, 09:57:58 PM   #2
Oldman MZ3
Oldman MZ3's Avatar
Reputation: 0 Oldman MZ3 is on a distinguished road
Default Re: DIY: Flickering headlights, taillights, ground issue FIXED
Hi, I have been with BMW for a long, long time, and someone said that the tail light could cause haedlights to flicker, never had that happen. And now reading your post ( I got a call today about same thing) I thank you for the tip. Your never to old to learn!!!!
Jump to top Oldman MZ3 is offline   Reply With Quote
Old Wed, Jan-04-2012, 01:39:10 AM   #3
kihun
yea it's crazy but my headlights don't flicker anymore. i was going to change whole hid set up.. =T but thank god i only spent few bucks.
Old Wed, Jan-04-2012, 02:15:26 AM   #4
WaE46
WaE46's Avatar
Reputation: 0 WaE46 is on a distinguished road
Were both headlights flickering before the fix?
Jump to top WaE46 is offline   Reply With Quote
Old Wed, Jan-04-2012, 02:47:34 AM   #5
kihun
well it started out with one headlight flickering and it got worst and both started flickering. it would always go off and on but recently once they were off, they didn't turn back on so i got worried.
if you have this issue, most likely it's your ground problem. so follow my instruction and try it. mine is working good.
E46 M3 - Sold
E92 335i - Current
Old Wed, Jan-04-2012, 07:19:12 AM   #6
¿safxtacy!
Who are we?
¿safxtacy!'s Avatar
Reputation: 0 ¿safxtacy! is on a distinguished road
Pakistan
There's a TIS on this. If you replace the actually plug it makes the problem go away as well. I replaced my plug and got new ground wires (which I still have plenty of somewhere, because I ordered too many ).
“You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose.
You're on your own. And you know what you know. And YOU are the one who'll decide where to go...”
Jump to top ¿safxtacy! is offline   Reply With Quote
Old Wed, Jan-04-2012, 06:20:53 PM   #7
TigerDave
TigerDave's Avatar
Reputation: 0 TigerDave is on a distinguished road
Interesting. Do you have the link to the TIS?
Also, does this issue apply to LED tails as well?
(I found this thread from this one.)
2011 BMW X5 35d
2010 BMW 328i Coupe
(SOLD) 2004 BMW M3 Coupe
(SOLD) 2003 BMW M3 Coupe
(SOLD) 2006 MINI Cooper S Conv.
(SOLD) 2003 MINI Cooper
Jump to top TigerDave is offline   Reply With Quote
Old Wed, Jan-04-2012, 09:28:47 PM   #8
AP3X_FTW
Visor Down For Business
AP3X_FTW's Avatar
Reputation: 0 AP3X_FTW is on a distinguished road
This has been my exact problem and I already went out and bought a new ballast After I installed my new ballast, the other side started flickering and turning off while driving. I thought I was going to have to buy another ballast. I knew that it was too much of a coincidence for both to go out during the same week or so.
Ill try this fix! Thanks
BTW, I have aftermarket LED taillights (eagle eye I believe is the brand). Wonder if this makes a difference...
E46 M3 Slicktop
E70 X5 M Sport
i3 RE
Jump to top AP3X_FTW is offline   Reply With Quote
Old Wed, Jan-04-2012, 11:23:05 PM   #9
kihun
ok, yesterday night driving and morning drive was good until i applied hard brake. now it started to flicker again. i might have to re-wire or i gotta look into it more.
E46 M3 - Sold
E92 335i - Current
Old Thu, Jan-05-2012, 08:07:50 PM   #10
TigerDave
TigerDave's Avatar
For me, last night, my passenger-side would flicker or go out momentarily while sitting idle at an intersection and be fine while doing 45MPH on a rough, bump road. So I don't think it's a grounding issue. I think it's a ballast issue. I've ordered two NEW ballasts and will report back once installed to see if there's any improvement.
2011 BMW X5 35d
2010 BMW 328i Coupe
Discussing DIY: Flickering headlights, taillights, ground issue FIXED in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
