Old Mon, Nov-28-2011, 06:31:45 PM   #1
kokgo20
kokgo20's Avatar
Default Is there such a Vanos test in the DIS?
I have GT1 and INPA, and i was wondering if there is a such a vanos test that can be done?
http://imageshack.us/photo/my-images/821/mycarwz.jpg/
06/2003 Tiag SMG/IR - 600 TCKline - Euro Headers & Cats - Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - Multi color AEs - Iconz one piece bumper Lip - Roof & interior trim CF wrap - Smoked Side markers - painted bumper reflectors - V1 with hard wire&Stealth one - M Track Mod - ZCP steering rack - BMW MS 4.10 - Dual LI - CSL SMG flash - Euro DME flash - CSL Style diffuser - Dinan Intake - Borla Exhaust - E9x Door handle LEd retrofit - Seibon CSL bootlid
Jump to top kokgo20 is online now   Reply With Quote
Old Mon, Nov-28-2011, 07:21:58 PM   #2
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
Default Re: Is there such a Vanos test in the DIS?
GT1 should be able to do it.
Jump to top deadlysyns is offline   Reply With Quote
Old Mon, Nov-28-2011, 07:49:25 PM   #3
kokgo20
kokgo20's Avatar
Do u know where it is on the GT1? i looked but can't find it.
Old Mon, Nov-28-2011, 09:57:30 PM   #4
kokgo20
kokgo20's Avatar
Anyone?
Old Mon, Nov-28-2011, 10:44:33 PM   #5
deadlysyns
deadlysyns's Avatar
hogger432 has gt1 and if I recall did the test.
Old Tue, Nov-29-2011, 12:00:52 AM   #6
kt22cliffjumper
kt22cliffjumper's Avatar
Reputation: 0 kt22cliffjumper has disabled reputation
If I remember right there are couple of ways to get to that part where you can test VANOS. Once you are in GT1 diagnostic and if you already have code thrown, you can follow that path and get into "expert mode" where it should give you multiple options one of which should be testing VANOS. If there is no code thrown yet, you could get into control unit fuctions and from there you can root around to find the "VANOS test" option. I think it comes from Motor electronics or Engine control something like that.
2005 silver gray | SMG | Xenon | sunroof delete | manual nappa leather/cloth seats | TC Kline D/A coilover 450F/500R with TCK camber plates and TCK RSM | BMW Motorsports 4.10 LSD | Powerflex RTAB | Stoptech 4 piston F/R BBK with slotted 2-piece rotors | BBS RS-GT 18"
Jump to top kt22cliffjumper is offline   Reply With Quote
Old Sat, Dec-03-2011, 06:01:40 PM   #7
defkom
TheInfamousDrew
defkom's Avatar
Reputation: 0 defkom is on a distinguished road
just did this literally 5 mins ago
its easy....hit me up if you want help
135i
M3 = Sold
Own an ///M?
Join me at ///Mlife
Insert exorbitant sig pic here
Jump to top defkom is offline   Reply With Quote
Old Sat, Dec-03-2011, 06:41:37 PM   #8
beam
Reputation: 0 beam is on a distinguished road
can you post a step by step diy? thanks
Jump to top beam is offline   Reply With Quote
Old Sun, Dec-04-2011, 01:34:18 AM   #9
volkswackin
Reputation: 0 volkswackin is on a distinguished road
pretty simple...go into expert mode once already in your DME and go to i think its function tests....vanos is in there
Jump to top volkswackin is offline   Reply With Quote
Old Thu, Dec-08-2011, 01:48:17 AM   #10
beam
thanks
Discussing Is there such a Vanos test in the DIS? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
