Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > Other BMW M Models > M Coupe/Roadster (1997-2002, 2006-200?)
Old Mon, Aug-15-2011, 03:10:44 PM   #1
marcusk
Reputation: 0 marcusk is on a distinguished road
Hong Kong
Default E46 M3 parts=Z4M parts?
Hi All,
Anyone knows that the E46 M3 bilstein PSS9 and AP brake kit (front 6 piston with disc 355, rear 4 piston) is fit for Z4M? I have dismantled it those from my previous E46 M3.
Thanks,
Marcus
Jump to top marcusk is offline   Reply With Quote
Old Mon, Aug-15-2011, 06:31:47 PM   #2
tropicatango
tropicatango's Avatar
Reputation: 0 tropicatango is on a distinguished road
Default Re: E46 M3 parts=Z4M parts?
brake will fit bolt on...
the the pss9, i'm not sure
Jump to top tropicatango is offline   Reply With Quote
Old Mon, Aug-15-2011, 07:04:19 PM   #3
Xtreme M3
Brake.Enter.Apex.Exit.Acc elerate
Xtreme M3's Avatar
Reputation: 0 Xtreme M3 is on a distinguished road
suspension - front setup is from an E36 M so it may differ..... rear is the same.
BMW M3 ZCP
2005 - TiAg/Cinn - 6spd
Performance: CSL Headers/BMW Msport 4:10/BW Race Exh/TMS Intake/Epic Tune(GTS3)/TMS Race Pulleys/ BW Oil DV/ BW Solid Trans and Engine Mounts/ BW Oil Cooler and CR Radiator, BW Diff Cooler
Safety: Schroth Profi II 6pt Hans/Hans/4l Fire Suppression
Brakes: PFC Z45 (F), PFC DD Rear
Suspension: MCS Rear Coilover 2Way 800/425, Rogue RTAB/FCAB/RSM/RLCA/GC Camber Plates/H&R Front Sway/ F&R Subframe/PF Subframe bushings
Wheels: TR-1 18x9.5 w/ 275/35 Hoosier (R6) Apex Arc-8 Hoosier (R6)/ Apex Arc-8 18x9.5 w/ 275/35 Conti Ext Cont DW (WET)
Interior: OMP HTE/BW Solid Shifter/Jaffster Shift Knob/CF Sunroof Delete/ Full Cage (Dave Weaver)
Exterior: BW Brake Ducts/Vorsteiner Trunk and Rear Diffuser, BW Dive Planes, BW Wing, Weaver Splitter
Jump to top Xtreme M3 is offline   Reply With Quote
Old Tue, Aug-16-2011, 12:12:08 PM   #4
marcusk
Hong Kong
thanks-both.
Hi All,
Any comment on these?
Thanks!
Old Sun, Sep-11-2011, 02:42:00 AM   #5
BTM
Reputation: 0 BTM is on a distinguished road
suspension is different
Jump to top BTM is offline   Reply With Quote
Discussing E46 M3 parts=Z4M parts? in the M Coupe/Roadster (1997-2002, 2006-200?) Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
