Old Wed, Jul-06-2011, 07:49:41 PM   #11
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
Default Re: Comprehensive programmable option thread
Here is the PDF for all the easy options like the keyfob etc...
http://www.m3forum.net/m3forum/attac...9&d=1307773173
I'll also add the adjustable reverse drop down. Mirror automatic memory curb needs to be set to "active." By default it is inactive, and the mirror will drop when set to the driver side in a non adjustable way. When set active it functions when set to passenger side and is adjustable in the drop down.
This gets asked on a regular basis.
2004 Mystic Blau Imola Rot ///M3 Coupe SMG
Other Rides
73- 240z - L28 Block w e31 heads - prepping as a track toy
95- Legend Coupe - C32A5 block - totaled while parked
96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident
Jump to top Foo2rama is offline   Reply With Quote
Old Wed, Jul-06-2011, 07:53:05 PM   #12
blatant
///Mthusiast
Reputation: 0 blatant is on a distinguished road
Great thread idea, should be very helpful. Thanks for the index.
RK-Tune | Alpha-N | Dyno here-> here
Jump to top blatant is offline   Reply With Quote
Old Wed, Jul-06-2011, 08:04:04 PM   #13
Reputation: 0 terraphantm is on a distinguished road
Aimable rear view mirrors
halogen highs on with xenon highs
fogs stay on with highs
tripple blink turn signals
alternate 4 way flasher flash patterns
M track mode
program car for ZCP brakes
one touch close rear windows
roll up windows remotely with key
close vert top remotely with key
Only other "popular" features I can think of are:
Parking light delete (corners don't illuminate w/ headlights)
visual confirm for lock/unlock
DRL enable/disable
ECU programable options here
euro SMG launch control
CSL SMG programming
SMG shift lights for 6 speed cars
secondary air pump sensor turned off
post cat 02 sensors turned down (but left "ready")
FWIW, the shift lights, SAP delete, and O2 delete require aftermarket tunes. I'm not aware of how to do it with the "DIY" tools that we've got access to.
Nav enhancements here
Bird's eye perspective view
anti-aliasing
zip code address entry
night mode
trapster database integrated into stock nav with audible alerts
edit nav database
You can disable the accept screen too
M track mode looks like it can't be done, tripple blink turn signals need a late 2005 or later.
I'm going to put date limitations, if any, on each option.
M-track requires the MK60 module, which is limited to M3s 2003 (09/2002) and newer. The LED isn't present in all of the cars (and it seems to be somewhat random as to which cars get it). Other members have confirmed that soldering an LED and a couple resistors does the trick to enabling it
Triple flash turn signals require an LCM from 09/2005 or later (LCM should be SW version 4.0 or 4.5). If you retrofit a new LCM to an old car (for LEDs or whatever) you can also enable triple flash.
Old Wed, Jul-06-2011, 08:05:08 PM   #14
NikolaiD
NikolaiD's Avatar
Bulgaria
I don't know if the post will stay since usually posts on the subject get deleted, but here's a summary I wrote in another thread about what I find to be the most popular options:
Originally Posted by NikolaiD View Post
Airbag Control Module:
-Useful if airbags are to be removed or for aftermarket seats to disable seat sensors. I'd say best use for people that are stripping the car down...
Instrument Cluster:
-Acoustic warnings for belts, key in ignition, frost warning - these are nice to quiet the car down a bit. If these beeps annoy you, they can be removed.
-Cluster offset. The instrument cluster reads high by about 7-8%, this can be adjusted, so it's closer to actual speed.
-Service interval. This has actually made the service interval feature useful to me. By default it's set to 25,000km or close to 15,000 miles, I've changed mine to 11,000km or close to 7,000 miles, now I can use this as my oil change interval instead of trying to remember halves.
Central Light Switch:
-Super high beams!!! You can have the halogens, bi-xenons and fog lights on all at the same time. Obviousy this is not for around town, but it's very nice in the middle of nowhere in a forest, makes your headlights twice as bright.
-Check control and warm testing lights are useful for LED tail lights retrofit. If these are disabled, you won't get a dash light or blinking anymore.
-Foglights stay on with high beams, already mentioned, but this is good for people with HID fogs to extend the life of the ignitors.
-Daytime running lights. These can be changed, activated or removed, quite a few items in this topic.
-Home shine - you can pick which lights you want for your home shine or "follow me home" lights.
-Euro sidemarkers - this disables the orange corner lights as running lights, they'll only work as turn signals, so no orange corners with the headlights on.
Rearview mirror module:
-Tilt mirror memory can be programmed, so you can adjust the mirror after it tilts down for reverse.
Convertible top module:
This module does not take coding and several people said they've burned theirs while trying to code. Shame...
General Module:
-Alarm can be enabled (it's built into the car, so even if you don't have the siren, it'll start blinking the headlights).
-One touch open/close for all windows including rear flaps on coupes.
-One click unlock for both doors.
-Open and close windows/sunroof/convertible top with remote. This can be customized.
-Automatic locking based on time or speed. Speed can be customized.
AC/Heater system:
-Automatic rear defroster. I love this, I haven't touched the button since I got my car.
Radio:
-Station key memory can be enabled, so you have different presets for different keys.
Seat Memory:
-Automatic seat adjustment based on which key unlocked the car can be enabled. I can be set to change seat position as soon as you unlock the car with the remote. I see this being useful if you're a big guy and move the seat every time you get in. I don't use it.
Post with full list HERE.
MSS54 Error Codes
(work in progress)
Old Wed, Jul-06-2011, 08:13:52 PM   #15
Adding in the appropriate field changes would be much more useful. Finding out that these things can be done, isn't hard... it's finding the appropriate field(s) to change that can be difficult.
ie; SSS settings, NCSexpert settings, etc.
Old Wed, Jul-06-2011, 08:45:21 PM   #16
casper3t
casper3t's Avatar
Reputation: 0 casper3t is on a distinguished road
I got excited when i saw the shift lights but then i saw your post
'02 Euro Tuned///M3 6spd Carbon Black cover with a layer of dust and Grey Int.
Suspension: Koni Adj with Vogtland Springs, UUC FCAB, RE RTABS and GC Street Camber Plates
Jump to top casper3t is offline   Reply With Quote
Old Wed, Jul-06-2011, 08:47:43 PM   #17
///NNM
previously: milovanov
///NNM's Avatar
Reputation: 0 ///NNM is on a distinguished road
Russian Federation
SSS is extremely easy.
NCSExpert is a different story.
Ian doesn't want us to discuss software here.
so i was being quite.
Evolve Alpha-N | SuperSprint Headers | MS: Elbow | 4.10 | TMS: Pulleys, Camber Plates & Arms, Solid Diff mounts, Studs, Front/Rear Subframe Kits | ACS Strut bar | PF RTABS | UUC: SSK3, DSSR, tranny mounts, SS clutch, brake lines | H&R Front Sway | ST coils v1 | 18" BBS RCJ | Custom Vibrant Performance Exhaust
YouTube DIY Videos Sister 98 M3 2dr; Wife 04 X3 3.0
Jump to top ///NNM is online now   Reply With Quote
Old Wed, Jul-06-2011, 09:16:22 PM   #18
Reputation: 0 Obioban has a spectacular aura about
I'm going to put up how to get to each feature, I've just been suddenly unexpectedly busy.
I don't think think there's any reason we can't discuss how to use software, just not any discussion of where to get software. Everyone should buy all required software!
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell
Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS
Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop
Selling: Suspensions, brakes, safety equipment, etc (ask away!)
Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool
Clearing out the garage: Used TCK camber plates, Imperfect fitment Scorza CSL trunk, CHEAP snow tires
Old Wed, Jul-06-2011, 09:35:32 PM   #19
Keegan99
Keegan99's Avatar
Reputation: 0 Keegan99 is on a distinguished road
Info on some things I've had done with NCS Expert. Apologies for the mediocre copy and paste:
Module Field Value Purpose
GM5 KOMFORTSCHLIESSUNG_FB aktiv Key Close Windows
GM5 KOMFORTSCHLIE_FB_O_FH_HI nicht_aktiv Key Close Rear Windows
GT LAENDERVARIANTE_GT ece Remove Nav Accept
ALSZ GED_FL_ALS_DRL nicht_aktiv Disable DRL
ALSZ BLINKIMPULS_WARNBLK wert_04 Euro Hazards
ALSZ PWM_WERT2_FL_BIXENON wert_01 Halogen High Beams
GM5 MAUT_N_ABBRECH_N_TUER_AUF aktiv Rear Window One Touch Close
GM5 FH_TUEREN_HINTEN_TIPP_ZU aktiv Rear Window One Touch Close
GM5 FH_ZTR_SCHALTER_TIPP_ZU aktiv Rear Window One Touch Close
Jump to top Keegan99 is offline   Reply With Quote
Old Wed, Jul-06-2011, 09:40:18 PM   #20
I added some more and made that the basis of which will the the NCS post...
Discussing Comprehensive programmable option thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
