#161 | |
![]() Location: Buffalo
#162 | |
![]() /Robin |
#163 |
Buy mirrors that fold, retrofit that into ur mirrors or buy the mirror folding motor from eBay (work the same) put on ur car. Use NCS EXPERT to activate the two commands he said .
![]() | 04 Mystic Blue M3 | 07 White R6 | MY LAGUNA SECA BLUE INTERIOR DYE PROJECT BUY MY WHEELS! |
#164 | |
/ Robin |
#165 |
Oddly enough, the actual csl runs the standard calibration
#166 |
Enter FA, add $313, do FA_WRITE on both the alsz and akmb.
#167 |
should you code all the options you change on your car into the FA? is there a list of what all the $.... options are.
does it really matter? u can change it regardless... right? ie. comfort closing. should you code the FA with anything to tell the car it has it? i just went thru and changed the codes in the fsw_psw...
#168 | |
In the case of comfort closing, there is no VO setting as it's not an optional feature. It's simply enabled on euro cars and disabled on US. You could change your VO to a euro VO, but I wouldn't do that unless you converted completely to Euro. Even then, there are some oddities to deal with (for example, euro cars don't have lock/unlock chirp and the alarm siren is a different sound)
#169 |
![]() Location: North Cal
This and there translations for e46 m3 specific, thanks.
#170 |
Yeah I'll just stick to fsw psw. It's written on both the akmb and the alsz so if one were to fail u could always recover from the other..
Btw. Getting a used LSZ from 2006 M3 would throw a tamper dot after installing, correct? But going in to DIS (I think) u can wipe the LSZ, then with NCS Expert, have it copy the AKMB mileage etc. and tamper dot would go away? I really want the cycl_blah blah... Triple blink when tapping turn signal
