![]() Location: South Florida
every time i get out of the car, there is scritching noise coming out from rear driver side tire where the shocks are. could be my shocks or bushings. or something that might need to be lubricated. has any one had that issue?
Is your park brake on? Mine squeaks every time if it's on.
yeah i do put my brake on, but it does not sound like its the brake.
#4 |
![]() Location: DFW
lose some weight......j/k
#5 |
No Gods -- No Masters.
![]() Location: Fort Leonard Wood
I had the same issue with my previous E46. Try letting the parking brake off on a level surface and get in and out a few times to see if thats the problem. I never did find a fix for the issue but at least you know its nothing major.
#6 |
In for pics...
+1. Was going mention to try this. Mine does this too. If you don't hear any noise after trying you may want to concider replacing the parking brake shoes are have them adjusted.
2002 E46 M3 ~ SMGII VMR V710 : TR MT01 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey |
#7 |
![]() Location: Memphis
My brand new parking brake shoes does the same thing, i think all E46 do the same thing even my 325Ci same noise.
06/2003 Tiag SMG/IR - 600 TCKline - Euro Headers & Cats - Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - Multi color AEs - Iconz one piece bumper Lip - Roof & interior trim CF wrap - Smoked Side markers - painted bumper reflectors - V1 with hard wire&Stealth one - M Track Mod - ZCP steering rack - BMW MS 4.10 - Dual LI - CSL SMG flash - Euro DME flash - CSL Style diffuser - Dinan Intake - Borla Exhaust - E9x Door handle LEd retrofit - Seibon CSL bootlid on the way
#8 |
![]() Location: Long Island
My '87 635csi did the same thing!
If that is your problem, you can try engaging the E-brake a little bit while driving to rub off some of the rust.
'03 M3 Dinan S2, Carbon Black. Bored left-foot (SMG)
#9 |
interesting, ill give it a try. thanks
#10 |
could be susp springs
