Old Thu, May-05-2011, 09:48:37 PM   #1
DemonTweaks
Reputation: 0 DemonTweaks is on a distinguished road
Thumbs down Running lean on bank 1...
At least that's the only code that ever come up says.
Only happen once though.
The car however is, and have since I've gotten it, always 'missed' on really light throttle at cruising. And 'pings' some at light throttle too going up hills at low rpm.
It's not ignition, I've replaced EVERYTHING with new.
Not OEM software.
The later made it even worse after BMW 'upgraded' the software for emissions. I've installed a Shark tuner since and it was good at first but it seams that it adapts itself to run to lean or something!
Not the pedal, does it on cruise control too.
This is really annoying so anybody experience the same?
1; I'm thinking next might be pulling injectors and have them all cleaned/balanced. And throw away the K&N filter/inlet previous owner installed. (anybody want to trade OEM for it?)
2; Swap bank 1 & 2 lambda sensors (O2) to see if he messed with them too (lots of small stupid things been eefed with already...) and off course didn't get back in the right order.
(Where are the connectors for them located? Don't want to lift the whole car and pull all skidplates etc. to swap them in the pipes.)
Jump to top DemonTweaks is offline   Reply With Quote
Old Fri, May-06-2011, 12:46:54 AM   #2
bmw loe
Reputation: 0 bmw loe will become famous soon enough
Default Re: Running lean on bank 1...
its located on top of ignition coil #5 and #6 for the pre-cat
-E90 LCI M3 Interlagos Blue / Novillo Silver MS pullies, K&N filter, primary cat delete, Evolve R stage 2 tune, Evolve Servotronic mapping
-e92 335i 6MT sold
-e46 M3 6MT, sold
-e46 M3 SMG, sold
Jump to top bmw loe is offline   Reply With Quote
Old Fri, May-06-2011, 12:55:15 AM   #3
tkeane
Reputation: 0 tkeane is on a distinguished road
Another thing to check that could cause this is a dirty or damaged MAF sensor.
Jump to top tkeane is offline   Reply With Quote
Old Fri, May-06-2011, 03:14:47 PM   #4
DemonTweaks
Did clean it already. Forgot to mention it. Thanks though!
I'll check under my coil cover and will try to swap them around.
Old Fri, May-06-2011, 03:40:27 PM   #5
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
Reputation: 0 M302_IMOLA is on a distinguished road
are you throwing a P0174 code? If so, I had these code and it turned out to be a vacuum leak...I had a a slight leak where my aftermarket intake elbow attached.
02' IR/IR
Current Mods: Painted front reflectors, matte black fender gills, carbon fiber roundels, Depo smoked corners, 19" Ruff Racing wheels wrapped in Hankook Ventus V12's (245/35F & 275/30R), Status Gruppe coilovers (7K/8K), RE RSM's, Powerflex RTAB's & FCAB's, DICE, CSL Rep Diffuser, CF Hamann Rep Lip, Magnaflow exhaust, Ebay headers, Streamline filter, Afe elbow, RPI scoops, ZHP knob, and EE LED tails.
WTB: OEM Front strut bar, Evolve stage II tune, 4.10's, and CF CSL rep Bootlid
Jump to top M302_IMOLA is offline   Reply With Quote
Old Fri, May-06-2011, 04:19:58 PM   #6
bmw loe
Just FYI...I don't think the harness connector between bank 1 and bank 2 pre-cats O2 sensers are interchangeable. The harness connector is shaped differently and designed that way to be fool-proof
-e92 335i 6MT sold
-e46 M3 6MT, sold
-e46 M3 SMG, sold
Discussing Running lean on bank 1... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
