| Faults, Fixes and DIY Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! |
Jimmies: Not Rustled
![]() Location: Indiana
I haven't seen any official DIY for this. I know there's not much need for it since it's pretty straightforward, but I've seen a number of people ask for pictures. So, here's a quick DIY with some pictures I took while I did this today. It only takes maybe 20 min. if this is your first time doing this but it is quite effective!
The problem: Excessive vibration/rattle, etc. from rear deck shelf for those with HK sound system. The solution: Tennis balls. ![]() Tools needed: 8 mm socket or nutdriver, flat head screwdriver or plastic pry tools, 3-5 tennis balls. Step 1: Open trunk and fold down the rear seats. You don't have to lay down in the trunk but I did to make it easier on my back. With the seats folded down, climb in the backseat and lay down in the trunk with your head to the back of the car and feet inside the car. Step 2: Unscrew 4 screws (8 mm) holding HK speakers in place, as indicated by yellow arrows. There are 2 towards the rear of the car and one on the left and right side of the unit. The unit should NOT drop down once you undo the last screw, but brace it just in case. ![]() Step 3: Unclip white clips. These are very similar to the type of clips used on the door panels. Grab a flat head screwdriver or even the plastic door panel pry tools if you have them (I do but didn't think to grab them). Pry as close to the white clip as possible so as to avoid stressing the black plastic of the speaker unit too much. It takes a little force but the white clips will pop right out. Disregard the fact that the screw is still in place, I took this pic after I was done. ![]() ![]() Step 4: Once both white clips are popped out the unit will slide to the rear of the car slightly and drop right out. The tabs indicated by orange arrows are what hold up the backside of the unit. (see picture) Unplug wire harness as indicated and set the speaker unit aside. ![]() Step 5: Next, get your tennis balls. Shove one into each hole as far to the left (and right) as you deem necessary to put sufficient pressure on the deck. You want the tennis balls as far to the back of the car as possible so that the back of the deck is pushing up against the rear window and can't vibrate. One on the left... ![]() One on the right... ![]() And one in the middle. ![]() Step 6: Reinstall everything in reverse order. Plug the wire harness into the speaker unit, slide the rear tabs up into the top of the trunk, and snap the white clips back in. Screw the 4 screws back in and test your work! Now that you've removed and reinstalled the speakers you know what to do if you ever need to make an adjustment.![]() |
![]() Location: San Francisco
Great DIY, I did this recently and was shocked that it actually does work!
Track: TRG 2011 Rolex Grand-Am GT3 Cup Daily: 2006 M3 ZCP |
random
#4 |
Does it look different on the inside of the car after the balls are in there?
#5 | |
I know! I turned the bass all the way up and cranked the volume up louder than I would normally put it and still no vibration. |
#6 |
I have the rear sunshade option on my car, will the t-ball still fit?
#7 |
![]() Location: Minneapolis
I've had the car a month and it's by far the most annoying thing to be unable to listen to rap because of the vibration.
Thanks for this.
#8 |
Thanks for this!
#9 |
Addicted
![]() Location: Maple Valley
I'm gonna run to Big 5 on the way home...
#10 |
BMW M3
![]() Location: OC/Co
hey is there any solution to the rattle the subwoofer makes for the verts?
