Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > Other BMW M Models > M Coupe/Roadster (1997-2002, 2006-200?)
Old Fri, Apr-15-2011, 11:37:06 AM   #1
jrbm3
jrbm3's Avatar
Reputation: 0 jrbm3 is on a distinguished road
Default M coupe with S54 v e46 M3 valve adj
I have an e46 M3 with the S54 and I have done the valve adjustment in the past on my e46. I have a friend who has an M-coupe with the s54 and he wants me to do the valve adj on his. Q: Any major differnce between the Mcoupe and e46 M3 that I should know about? It appears to be straight forward in fact cylinder 6 looks to be easier to get to than in my e46.
thanks
j
Jump to top jrbm3 is online now   Reply With Quote
Old Sun, Apr-17-2011, 03:33:58 AM   #2
kaiv
SoCal vanos/valve specialist :D
France
Default Re: M coupe with S54 v e46 M3 valve adj
It's the same thing, with less parts in the way! Only difference is you have to remove the electric fan to gain access the crank pulley (to rotate the engine). Very easy.
AW S65 E92 6MT
past: AW S65 E90 6MT- LSB S54 E46 6MT- JB S52 E36 5MT
Kaiv's SoCal Feedback! [M3Forum] [iTrader] [Bimmerforum]
Old Sun, Apr-17-2011, 04:08:58 AM   #3
RAFF112
Reputation: 0 RAFF112 is on a distinguished road
cant you just use a 32mm wrench
VCSL Front, 18/13 Spacers, Full Borla exhaust, K&N drop-in with custom tube, BMW Performance shift knob, Vogtland springs, depo corners, RE rear camber arms,
CF Hood, LED DRLs, Dynavin and air horn
Jump to top RAFF112 is offline   Reply With Quote
Old Sun, Apr-17-2011, 10:36:15 AM   #4
kaiv
France
There's no mechanical fan on the E86M so no 32mm fan clutch nut. The electric fan slides out after removing a couple screws and connectors on top.
AW S65 E92 6MT
Old Sun, Apr-17-2011, 12:12:25 PM   #5
jrbm3
jrbm3's Avatar
Hummm OK good to know, thanks.
j
Old Sun, Apr-17-2011, 12:18:19 PM   #6
jrbm3
jrbm3's Avatar
What size wrench will I need to move the crank in a Z4MC? I'm doing this for a friend so I don't own one to compare to the e46 M3.
j
Old Mon, Jun-13-2011, 01:23:51 AM   #7
BTM
Reputation: 0 BTM is on a distinguished road
The engine hardware is identical. Access is different, as noted, but otherwise they are the same engine, provided you aren't messing around with the DME, which you aren't.
Jump to top BTM is offline   Reply With Quote
Old Tue, Jun-14-2011, 06:25:14 PM   #8
e46<3
e46<3's Avatar
Reputation: 0 e46<3 is on a distinguished road
good to know.. im considering trading for a z4m
Do you listen to Progressive House/Tech House?
Have a listen to my SoundCloud
https://soundcloud.com/bryanisaac
Jump to top e46<3 is offline   Reply With Quote
Old Wed, Jun-15-2011, 09:13:40 PM   #9
Jbss
Jbss's Avatar
Reputation: 0 Jbss is on a distinguished road
Kaiv did the valve adjustment on my car. He said it was the same procedure once you got to the engine!
2007 ///M Coupe BSM/Black Extended/Fully Optioned | RPi GT Exhaust w/custom gloss black tips | Michelin PS2s 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob | RPi Scoops/Air Filter
Jump to top Jbss is offline   Reply With Quote
Old Mon, Jun-20-2011, 10:08:07 PM   #10
kaiv
France
j
You rotate the crank using a 32mm socket.
AW S65 E92 6MT
Discussing M coupe with S54 v e46 M3 valve adj in the M Coupe/Roadster (1997-2002, 2006-200?) Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
